Subject: Help Please Victoria 4.2 Morphs -- having trouble installing
ladyperiwinkle opened this issue on Apr 11, 2008 · 4 posts
ladyperiwinkle posted Fri, 11 April 2008 at 4:47 PM
I jsut purchased the Victoria 4.2 morph package from  Daz.. I have Frontier Poser 7. I cannot load it in. Can someboby give me step by step directions. I cannot do it from the Poser 7 content room, because they are not zip files. I tried doing it the other way, but I do not know what the executable files are or where to put them. 😕
Thank you,
ladyperiwinkle
lesbentley posted Fri, 11 April 2008 at 5:45 PM
If it's like the other DAZ stuff that I have seen, just put the executable files in a temporary folder(any folder should do). Run the executables and they should install the content. You don't need the executables after that. You can back them up to a CD, then delete them from the hard drive.
ladyperiwinkle posted Fri, 11 April 2008 at 7:40 PM
I don't know what to do, before I would just make a folder on my desktop put everything in then zip it up with winzip and go to my contents page  in Poser 7 and unzip them there, and everything go where they should
I have  tried to do it but when i go to my Poser 7 files I get this message:
When used with Poser TM, Victoria 4.2 Morphs++ must be installed to the same directory as the application executable:due to restrictions on support file locations
Please slect the directory that contains your Poser executable.
coldrake posted Fri, 11 April 2008 at 8:33 PM
Set your Target Application to DAZ Studio instead of Poser (All Files) and you can install anywhere you want.
Coldrake
