ladyperiwinkle opened this issue on Apr 11, 2008 · 8 posts
ladyperiwinkle posted Fri, 11 April 2008 at 5:33 PM
Can someone please tell me what BitRock Instal Builder for Windows is?
Thank you
ghonma posted Fri, 11 April 2008 at 5:46 PM
It's an open source tool to create an 'installer' of your stuff. Installers are those small apps (like setup.exe, install.exe etc) that the user who buys/downloads your software runs to install the various files and registry settings that your software needs to run correctly:
http://bitrock.com/
ladyperiwinkle posted Fri, 11 April 2008 at 7:35 PM
But i have tried to do it but this is what I get:
When used with Poser TM, Victoria 4.2 Morphs++ must be installed to the same directory as the application executable:due to restrictions on support file locations
Please slect the directory that contains your Poser executable.
jonthecelt posted Sat, 12 April 2008 at 2:54 AM
The 'aplication executable' in question is your poser folder, not bitrock... bitrock is the program DAZ have used to create their installers...
JonTheCelt
ladyperiwinkle posted Sat, 12 April 2008 at 5:53 AM
I have Frontier Poser 7 that was bought for me as a Christmas gift. I don't understand , Where do i fine or locate the application executable file. It came with the base figure for Victoria
jonthecelt posted Sat, 12 April 2008 at 7:05 AM
What you need to do is browse to the folder that contains the file 'poser.exe', and se;ect that as your install folder. That should do the trick.
JonTheCelt
Kaji posted Sat, 12 April 2008 at 9:08 AM
If you want to install it to an external runtime, make a text document and rename it to "poser.exe", and place it in the external runtime.
coldrake posted Sat, 12 April 2008 at 1:12 PM
Set your Target Application to DAZ Studio instead of Poser (All Files) and you can install anywhere you want. No need for a "poser.exe".
Coldrake
