Darboshanski opened this issue on Apr 26, 2008 · 6 posts
Darboshanski posted Sat, 26 April 2008 at 8:46 AM
I am sorry but I am not understanding this I was at Cornucopia purchasing an item and below it states to update to this version of Vue 6 Pro Studio but when I go the get it e-on states it's a Beta?
Do I download it or not? Is it stable?
Do I need uninstall version 6.05 or can I just install 6.60? I want to be able to use my purchases...lol!
Thanks!
Victoria_Lee posted Sat, 26 April 2008 at 10:48 AM
The beta just means it's still in testing. If you aren't comfortable downloading a beta version wait for the final release. I have the beta installed and haven't had any problems so far. To install, you just install right over your existing Vue version.
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
Darboshanski posted Sat, 26 April 2008 at 10:57 AM
Thanks muchos! LOL!
Thelby posted Sat, 26 April 2008 at 11:32 AM
I also have Vue 6 Pro Studio 6.5 and everything I have including the New Items are compatible with this build. You will not have a problem with 6.5 and should not with 6.6, but you never know ;^)
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
wolf359 posted Fri, 02 May 2008 at 9:26 AM
Just FYI the 6.6 Update for vue Easel "Broke" My Copy
(Crashes Upon launch) so i had to go back to Version 6.5
I will NEVER update unless I truly "have to"
MAC OS 10.4.11 intel duo core 2.16 GHZ mac book
2 Gigs Of RAM.
Red Dog posted Fri, 02 May 2008 at 9:55 AM
I have run across a few bugs with Vue Pro 6.6 update when dealing with Eco-Systems.
- Removing Eco-system layers does not remove the plants from the terrain.
- Distribution maps do not map the same in all layers.
- Eco-systems in mixed materials with a function for the distribution of the two materials sometimes bleed over to the other material.
But everything else seems to be working well. It might be because I updated to 6.6 before I upgraded from Vue 6 Esprit to Pro. But when I downloaded the Pro update, it was the same file, same size...
