Forum: Carrara
Subject: Feet won't stay on floor
morphious opened this issue on Apr 29, 2008 · 10 posts
morphious posted Tue, 29 April 2008 at 5:11 PM
Why won't the feet stay on the floor when I try to animate a figure bending down. In Poser the feet stay on the floor when you move the hip downward. But in C6, they won't stay still. Any suggestions? Thanks.
Dwarg posted Wed, 30 April 2008 at 10:37 AM
I was really hoping someone more knowledgeable would answer this as right now I am experimenting with different character setups myself.
If you go to create a new document and click on the presets button then click the Animations option on the left-side column you will see a simple character as the last scene to choose from. Select Character and click OK.  You'll see the character has some green null objects around it and the foot shaped objects should prevent foot slipping and keep them from passing through the floor.  In other words you should be able to create your own null objects and attach them to your character's skeleton to do what you need.
Although with that said my results have been less than stellar so far. So I'm still experimenting.
I hope this helps.
morphious posted Thu, 01 May 2008 at 10:30 AM
Thanks, but I need to do this with poser figures within carrara. I guess the same applies, so I'll try it out. If anyone else has some suggestions, I would appreciate it.
Dwarg posted Thu, 01 May 2008 at 9:37 PM
Quote - If anyone else has some suggestions, I would appreciate it.
Same here.  I'd love to hear about character animation workflows in Carrara from anyone that knows something about it.
sfdex posted Tue, 06 May 2008 at 10:59 AM
This will be a bit vague, as I'm at work and don't have C6 here, but hopefully it'll point you in a useful direction:
When you're importing a Poser figure into Carrara from the browser, an option pops up with something or other about using target helper objects.  I don't recall exactly what it's called, but do import the target helper objects.  Then, you'll have the green boxes that Dwarg mentions; they're at the end of IK chains on the characters.  You can manipulate those to handle foot movements via inverse kinematics.  If you don't move the helper object associated with a foot, the foot won't move.
That's not entirely true, though.  The foot will not tesselate, but it will rotate.  So, I've had to go back and clean up the rotation of the feet, but their positions stay pretty well locked down.
Hope that's helpful.
 - Dex
morphious posted Tue, 06 May 2008 at 3:21 PM
Yea, thanks, but I don't import the figure, I load it directly in C6 from the browser wich is conected to the Poser runtime. I guess, I'll just have to create my own trarget helpers. What a pain in the ass. Thanks.
SimonWM posted Fri, 23 May 2008 at 1:28 PM
Why is IK  with content so difficult in Carrara? The target helpers work inconsistently. Sometimes they prevent the foot from going thru the floor sometimes they stop working. Also when it works the foot may stay in place but it will rotate, like sliding around its Y pivot.
morphious posted Sat, 24 May 2008 at 7:36 AM
Yes, I agree, they SUCK!!!!!!! I wish Daz would fix this if he want's tro compete or replace poser with Carrara.
SimonWM posted Sat, 24 May 2008 at 7:46 AM
There is no way I will animate with Carrara instead of Poser when the IK is so weak. I hope Carrara made content doesn't behave like this because if it does I pity the Carrara animators. I too thought I could start using Carrara for animation instead of Poser but so far it has been disapointing. A pity since Carrara has many other features that Poser doesn't have. IK is basic for character animation and Poser's seems rock solid by comparison.
morphious posted Sat, 24 May 2008 at 8:03 AM
Yea, I agree. Even animation done in poser, saved as a pose, imported into Carrara, still is flaky at best. Carrara just renders so much nicer and faster. Oh well, I'll keep waiting for DAZ to ketchup with the real world.
