kionde opened this issue on May 03, 2008 · 13 posts
kionde posted Sat, 03 May 2008 at 4:38 PM
Mazak posted Sat, 03 May 2008 at 5:12 PM
Do you have the latest update?
If your objects imported from Poser try this link
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2390404
and here another maybe helpful thread.
http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2727884
Mazak
dlk30341 posted Sat, 03 May 2008 at 5:12 PM
Was the above items saved in V5/V5I by any chance? I've only had this happen when I've used various items(not all) that I had saved as .vobs back in those days. If I imported the item fresh as an OBJ/PZ3/3DS etc the problem disappeared.
Edit to add a pic & to note on this particular items the highlights were white & at 100% for all but 1 which had a green highlight. This items was saved in V5I as a .vob
Dang I wish I could find EONS reply & I can't remember what they said either :(
gillbrooks posted Sat, 03 May 2008 at 5:44 PM
Ooh - I had this happen with Flinks Flowers. I contacted Flink about it and we worked out that I was using vobs that I'd imported and saved in Vue 5. I re imported the original obj files in Vue 6 and it cured the problem and they now render perfectly
Gill
Powertec posted Sat, 03 May 2008 at 6:23 PM
I had this happen once a while ago but don't remember what the fix was... Sorry...
Nice work though!
silverblade33 posted Sun, 04 May 2008 at 12:02 AM
Try adjusting the highlights, sometimes, it's the way highlights work
i.e. change slider for anisotropic highlights to the other end of scale :)
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
kionde posted Sun, 04 May 2008 at 4:20 AM
***Quote - I've only had this happen when I've used various items(not all) that I had saved as .vobs back in those days. If I imported the item fresh as an OBJ/PZ3/3DS etc the problem disappeared.
all items were 3ds and obj before. i stored them as vue vob files, and imported in that scene.
you mean that, if they stay original files than this problem doesent happen?
its also starange that i just had a few artefacts before, and the number rised up with the new objects i brought into. they are all converted into vob objects.
dlk30341 posted Sun, 04 May 2008 at 9:18 AM
Just various ones saved in V5I - not all of them by any means.
Tried silverblades suggestion to no avail - thanks for the suggestion. No big deal though can re-import.
silverblade33 posted Sun, 04 May 2008 at 1:50 PM
well, when I had that problem, it was a specific material that caused it, in that case, a wooden plank material (texture based)
"I'd rather be a
D&D items, stories.
checkthegate posted Sun, 04 May 2008 at 2:10 PM
great image...might try rendering separate layer passes? ...background...foreground...midground...AO ...diffuse...etc....
kionde posted Sun, 04 May 2008 at 3:35 PM
in my render it seems to be the glow material on several light emitting surfaces. if i switch out the glow, i get less artefacts, but they dont disappair.
we do it for this: www.banthapoodoo.de
croxie posted Mon, 05 May 2008 at 2:53 AM
I've had this happen as well, with a freshly upgraded Vue 6 xStream, and it is due to certain materials.
I suggest that you start taking a closer look at the procedural materials you have in your render and replace them if possible.
In my case, I had to replace every single material and then still do the render in sections to avoid the black dots from appearing.
Hope this helps and good luck :)
C.
"Keep smiling, it makes people wonder what you're up to."
kionde posted Tue, 06 May 2008 at 4:39 PM
thanks for nthe answers
