Forum: MarketPlace Showcase
Subject: Khia for A4/V4
rebelmommy opened this issue on May 09, 2008 · 1 posts
rebelmommy posted Fri, 09 May 2008 at 11:47 AM
Attached Link: Khia for A4/V4
[ Khia for Av/V4 is now available in the marketplace!](http://market.renderosity.com/mod/bcs/index.php?ViewProduct=64338)
A true photo realistic dark skinned beauty she is perfect for everydaay renders, pin ups or sci-fi/fantasy.  Bring Khia home to your runtime today and see the difference true photo realism makes in textures!
She comes with 2 head morphs with INJ/REM poses for each for both A4 and V4 that means you get 2 head morph choices for both A4 and V4!  A custom body mazde to easily work within standard V4 clothing morphs is included as a seperate INJ/REM pose so that you can use haed and body morphs together or choose one or the other to suit your needs.  She comes with a belly ring torso texture and without, both included in easy to use MAT poses. Shader and non shadered versions of all poses and her very own smart proped simple hoop earings!  5 make up options, 2 lash settings and 4 eye choices round out Khia's options.
Renderosity's "problem Child"
Support Hydrocephalus research.. because a Shunt is NOT a cure!
