Forum: Vue
Subject: memory
checkthegate opened this issue on May 12, 2008 · 9 posts
checkthegate posted Mon, 12 May 2008 at 1:26 PM
Im using windows xp professional.....is there a way to boost Vues Ram usage?
Im working with a populated scene...and I get crashes
Powertec posted Mon, 12 May 2008 at 5:06 PM
I believe that the only way one can benefit from additional ( over 2mb ) memory is to have 64 bit.......
Peggy_Walters posted Mon, 12 May 2008 at 5:34 PM
Use layers and then hide the layers that you don't need to see.  Plus, turn off auto-update on the camera preview window (right-click on it).  Those two tricks help me squeeze the most out of my computer.
LVS - Where Learning is Fun!
stormchaser posted Mon, 12 May 2008 at 5:49 PM
That preview window sure is a memory killer!
chippwalters posted Tue, 13 May 2008 at 3:57 AM
Also, try turning off background draw threads as well. While Vue renders an unprecedented number of polys, it's sometimes really hard to work with them.
ashley9803 posted Tue, 13 May 2008 at 4:29 AM
My personal favourite is the Purge Memory button.
It may not really do anything, but is sure makes me feel good when something appears to be happening.
I always press this little fella before I do a final render. (and cross my fingers, pray to Allah and say 6 Hail Mary's that I won't get the "out of memory" message.)
BTW, what does "Purge Memory" actually do? Purge your memory I suppose.
stormchaser posted Tue, 13 May 2008 at 5:19 AM
Check your memoy allocation in your taskmanager, purging can really release alot of memory back to you. I know 3D apps store alot of data in memory, I guess purging releases the memory used for this until it's needed. I guess.
Just to add, I find it's the texture maps which kill the memory the most so purging in Vue for me is essential with only 1 GB RAM.
ashley9803 posted Tue, 13 May 2008 at 5:25 AM
Good to see I'm not just going through the motions.
Thanks stormchaser.
I might suggest that turning the undo level down to just one could help with memory.
Seems logical.
stormchaser posted Tue, 13 May 2008 at 7:10 AM
Yeah, I was thinking about doing this but I like the handiness of having a few undos. Otherwise it would mean having to save after every one or two changes you make.
