Solo761 opened this issue on May 16, 2008 · 4 posts
Solo761 posted Fri, 16 May 2008 at 8:55 AM
Does anyone remember this? I just dug it out from some old CD and tried it in P7, doesn't work. I get this error message
Traceback (most recent call last):
File "I:_Poser 7RuntimePythonposerScriptsWeirdJuiceDrops.py", line 40, in ?
import DropsP5
ImportError: DLL load failed: The specified module could not be found.
There is Dropsp5.pyd file in it's directory.
I checked their site, http://www.weirdjuice3d.com/products/drops.php , and unfortunately updated version is not available. Did anyone managed to get it working in P7? In P6 it starts normally.
nyguy posted Fri, 16 May 2008 at 9:28 AM
Cannot be used with Poser 7. It has to do with the way the latest Python script for Poser 7 works and cannot read some older python scripts. There is a product by WeirdJuice3D called Metaforms and that won't "run" in poser 7 but I have found if you create a scene using it in Poser 6 you can open it in Poser 7 with some parts work and others not.
Poserverse The New Home
for NYGUY's Freebies
Solo761 posted Fri, 16 May 2008 at 9:45 AM
Dang :/, if it only wasn't compiled. This way there's no way to look at source of PYDs. Thanks anyway.
momodot posted Fri, 16 May 2008 at 10:56 AM
I was thinking of loading PoserProPack to run it but I never could fix the 'jaggy" artifacts created on the edges and joins by the random vertice placement... PhilC's Poser Tool Box tools 'smooth' and 'align vertices' helped a little bit.
Has anyone ever succeed in doing cool stuff with this tool? Can you show?
