Subject: The Paint 3d program that came on the P4 cd.
MistyLaraCarrara opened this issue on May 16, 2008 · 14 posts
MistyLaraCarrara posted Fri, 16 May 2008 at 10:32 AM
It's going to take me all day to find that old CD.
But, I was wondering if I painted a figure with the old program, does it automatically make a UV map and image I could then touch up in a regular paint program?
If I find it, I'll post what happens.
Cheers,
Lara
nimos100 posted Fri, 16 May 2008 at 10:42 AM
Dont know what paint program you are referring to, but dont think you should expect it to automatically create a UV map for you.
The normal way of doing it, at least the way i do it :) is to create a UV map and then export it with the OBJ file or whatever file type you might be using that store UV cords into your 3d paint program. and then paint the figure.
Otherwise you might risk that the UVs are collapsed on top of each other and you pretty much paint randomly with no control of where the colors are going.
But anyway, i dont know what program you are talking about so it might be able to do it :)
MistyLaraCarrara posted Fri, 16 May 2008 at 10:58 AM
Poser 4 came with 2 CDs.  There was a Paint 3d program on it.  Probably an LE version.
I still haven't found it yet.
Conniekat8 posted Fri, 16 May 2008 at 11:13 AM
3D paint program that's bundled up with Cinema 4D is Body Paint. A model will have to have been UV mapped already in order to paint on it. Making a UV map is a separate process from making a texture, and a good UV map usually takes a bit of time and significant user input to make.
For making textures, Body Paint is a really sweet program. It does have a little bit of a learning curve to it. Once you get the hang of it, it's a really powerful tool.
Hi, my namez: "NO, Bad Kitteh, NO!"  Whaz yurs?
BadKittehCo Store  BadKittehCo Freebies and product support
Doctor Destruction posted Fri, 16 May 2008 at 11:18 AM
The Poser CD bundle (when it was owned by Metacreations back in the day) included demo versions of Canoma (a proggie where you could make quasi-3D landscapes from 2D pics) and Paint 3D, which was what you could use to paint on 3D models.  Or that's at least what I can remember, that is.
Conniekat8 posted Fri, 16 May 2008 at 11:34 AM
Oh, the P4 CD... LOL, too close to C4D acronym before my morning coffee.
I had canoma way back, and could never get it to run stable enough to do much with it :(
SeanMartin posted Fri, 16 May 2008 at 12:01 PM
I would wonder if it could actually do that, if it came with P4. Remember: this was a loooooooong time ago, and I dont think we had the technology then. I could be wrong, but I suspect the paint program that came with P4 isnt quite what you think it is.
docandraider.com -- the collected cartoons of Doc and Raider
jeffg3 posted Fri, 16 May 2008 at 12:36 PM
It was probably Painter 3d, and it probably won't run.
Helgard posted Fri, 16 May 2008 at 1:58 PM
The paint program that came with P4, if it is the same version I have, will not run on XP or Vista. It was made for Windows 95, and when I try to run it on XP it fails.
The other options are:
Argile - about $100 - can do diffuse and bump, no specular or displacement channels:
http://www.n-sided.com/3D/argile.php?rub=1
3D Coat - about $120 - can do everything:
http://www.3d-coat.com/
Body Paint, ZBrush and Mudbox - more professional, can do lots of things other than paint, but this comes at a higher price and a steep learning curve.
There are a few other options, like Blacksmith 3D, which I haven't tried.
Your specialist military, sci-fi, historical and real world site.
odeathoflife posted Fri, 16 May 2008 at 4:19 PM
I have painter3d running on my xpPro...:)  you need to update it to work with anything more then poser propack though, and I do not think that poser is including the designer export anymore since 5 at least..
It will create UVMaps, but along the lines of UVMapper Classic...not too great.
It will import the figure with texture templates though, and you can choose the size to work it with.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
R_Hatch posted Sat, 17 May 2008 at 12:07 AM
Poser 6 is the last version to feature the "Export:Detailer Text" function.
raven posted Sat, 17 May 2008 at 8:22 AM
Attached Link: http://dev.depeuter.org/
Try this link for a file to get Painter 3D running on XP. It helped odeathoflife to get his Painter3D running on XP in this thread http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2913349
Marque posted Sat, 17 May 2008 at 8:11 PM
May have to dig it out and have another look...lol
I had Canoma as well, I actually got it to work, but lost interest in it.
jerr3d posted Sat, 17 May 2008 at 8:53 PM
if i remember right you open the obj in the paint program and paint right on the obj in 3d space but painting in 3d space takes some getting used to. i only used it a few times and found it difficult to do
