Subject: Python errors suddenly appeared!
cspear opened this issue on May 16, 2008 · 6 posts
cspear posted Fri, 16 May 2008 at 10:39 AM
I've started to get persistent Python errors in Poser 7, all of which end with:
"This probably means that Tcl wasn't installed properly."
Can anyone tell me, is there a quick fix for this, or should I do a full re-install?
PoserPro 11 - Units: Metres
Adobe CC 2017
ockham posted Fri, 16 May 2008 at 11:08 AM
Normally a full re-install is best, because there's no good way to tell
which of the many little pieces of Python is messed up.
First try re-installing the latest SR, which will redo Poser's
system registry entries and renew some of the Python stuff,
without all the trouble of the main install.  Sometimes this error comes
from the PythonPath in the registry pointing to the wrong place.
My python page
My ShareCG freebies
cspear posted Fri, 16 May 2008 at 11:37 AM
Applying the updaters didn't work, now preparing for a re-install. Groan.
Adobe CC 2017
ockham posted Fri, 16 May 2008 at 12:42 PM
My condolences!
My python page
My ShareCG freebies
nruddock posted Fri, 16 May 2008 at 2:48 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2724430
One cause of this error message is if you have installed the standalone version of WW2 into the Poser Runtime by mistake.
cspear posted Sat, 17 May 2008 at 6:03 AM
Quote - One cause of this error message is if you have installed the standalone version of WW2 into the Poser Runtime by mistake.
Which is exactly what I might have done. But I've now re-installed P7 and all is well.
Adobe CC 2017
