bigbearaaa opened this issue on May 18, 2008 · 4 posts
bigbearaaa posted Sun, 18 May 2008 at 11:00 AM
The regulations here for posting artwork are that the thumbnail can't be more than 15kb and has to be 100 x 100 pixels. I can't seem to get 100 x 100 pixels into any less than about 24k no matter how low I set the settings for the output jpeg.
Any idea as to what I need to do to cut the file size by about 25%?
ejn posted Sun, 18 May 2008 at 11:25 AM
If your using photoshop just go to file>save for web...and adjust the image file size to less than 15k.
Everything is easy if you know how :-)
bigbearaaa posted Sun, 18 May 2008 at 3:45 PM
Thank you. I'm giving Essentials a trial run but I did notice that option in the file menu.
So much to learn and so little tinme to learn it in. ;)
EagleWing1000 posted Tue, 17 June 2008 at 8:39 AM
I usually just goto save it as normal then increase the compression number on JPEG settings.
either works.
Dell XPS M1730
Intel Core 2 Duo T9500 2.6Ghz
500GB (2x 250GB) RAID 1 Sata HDD
4GB RAM
Nvidia GeForce 9800M GTX SLI
