Subject: poser pro and path to files in the pz3 problem
estherau opened this issue on May 21, 2008 · 127 posts
estherau posted Wed, 21 May 2008 at 6:49 PM
 Hi there,
did you see that poser pro saves the relative path not the absolute path.  How is Vue supposed to know where all the textures etc are in the external runtimes.  the old poser used to save the absolute paths.  Is there a way to fix this without manually adjusting each pz3, or am I doing something wrong?
Love esther
MY ONLINE COMIC IS NOW LIVE
kuroyume0161 posted Wed, 21 May 2008 at 9:56 PM
Is it only saving relative paths for the default or current Runtime -or- for all Runtimes used?
It may be that Poser's search feature is supposed to overcome pure relative paths according to added Runtimes.  Sounds a bit like what I'm doing for iPP.  I don't have Poser Pro so cannot test any propositions for validity here.
 -- Bjarne Stroustrup
estherau posted Wed, 21 May 2008 at 10:02 PM
 it would be fine if it was just saving relative paths for the default pathway as that is how the old poser 7 used to behave.  However it is saving a relative path (incorrectly of course) for every texture and obj in the pz3.  I can only surmise that poser must search through every runtime to find the correct textures etc.  And what happens if two things are the same name?
(I wonder if this is why poser is so slow when I switch from the render view back to the preview view, maybe it is searching for and reloading all the textures again?)
this is very distressing as I use vue with poser a lot!  I know there are work arounds, but not really for my normal workflow and things that I want to do with it.
Love esther
LostinSpaceman posted Wed, 21 May 2008 at 10:08 PM
This has been a much requested fix to Poser because people want all freebies and products to only have relative paths in them. Nobody stopped to think about Carrara or Vue trying to search runtimes. They just fixed Poser Pro's deep search and path save feature.
kuroyume0161 posted Wed, 21 May 2008 at 11:02 PM
I think that it is a good idea as well but it does require that you have all of the needed Runtimes added or it will not find the references - as one should expect.
And this isn't good for other support which doesn't reference Runtimes like iPP and now Poser Pro.  Interesting situation with this.
estherau posted Wed, 21 May 2008 at 11:03 PM
 there should be a preference to choose!!!
love esther
kuroyume0161 posted Wed, 21 May 2008 at 11:31 PM
That would be the best compromise here: have a setting that uses Poser 7 or Poser Pro style referencing.
grichter posted Thu, 22 May 2008 at 1:04 AM
Have not tried this myself with Vue and I assume you might be on a Mac. But you might try putting all textures and geometries in the default PPro runtime like I have.
PPro will find them there, and I assume Vue will too. If you think this method will slow down poser as it has to go back to your main runtime for textures and object files, the use a program like make symlink (which I believe I got for free) to make symlink folders of the texture, reflection maps and geometries folders out to your various runtimes. That makes all references to files it is looking for back the main runtime as these function as smart alias directories under OSX.
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
kuroyume0161 posted Thu, 22 May 2008 at 1:15 AM
If I know estherau, that might be a Herculian task.  Iirc, she has many, many Runtimes.
estherau posted Thu, 22 May 2008 at 9:38 AM
 Well I was thinking I could just merge all my external runtimes into the one poser pro runtime, but still leave all the external ones for creating my Cr2s  and working in poser.  Then when vue looks it would find things in the correct place.  It would waste a hell of a lot of space, and it would mean everytime I create a new external runtime, I would have to remember to do the mergey thing as well, however at least vue would work with poser.  I feel sad though that poser has lost what was great funcionality.
I can't understand why they still even have the option to make external runtimes and add them.  what's the point if the pathways aren't correct.  You might as well organize everything using their collections facility.
Love esther
grichter posted Thu, 22 May 2008 at 10:02 AM
I broke my runtimes off originally by character and other items by categories: like buildings and vehicles. Finally felt I was wasting space by having the same hair texture and geometry sets in several runtimes as one example.  So I put all textures, geometries and reflection maps in the main runtime. Keep in mind I manually install all content and place it under folders that make sense to me. But that broke WW2. as it wants the geometry file in the same runtime as the CR2. So that is why I symlinked everything in the first place. I even have a symlinked geometry and texture folder on my desktop where I drop all new content and then place the cr2's, etc in their appropriate runtime. Works like a champ for me. But might not be right for everybody.
Gary
estherau posted Thu, 22 May 2008 at 10:11 AM
 i use kaveman's ditto gui for installing my runtimes when I do merge them.  So I have one external runtime called V4 and another called boxing and another called sport etc.  I have a lot of content.
But I think rather than just moving some stuff, it will be far easier for me to just hit ditto each time I create a new runtime and put it all straight into the main poser runtime as well.  that way I will have my poser stuff taking up twice as much space as it used to (unfortunately) but at least vue will work I think.  This will never be undoable as the pz3s cannot ever be converted back to absolute pathways ever again.  It is tragic.
I am soooo upset about this.
Love esther
LostinSpaceman posted Thu, 22 May 2008 at 3:20 PM
Quote -   This will never be undoable as the pz3s cannot ever be converted back to absolute pathways ever again.  It is tragic.
Just keep Poser 7 installed and reopen and save your stuff with it if you want absolute references.
kuroyume0161 posted Thu, 22 May 2008 at 5:05 PM
That sounds like a plan. :)
estherau posted Thu, 22 May 2008 at 7:52 PM
Nice idea but sadly i already tried this...
If i use poser 7 then what happens to that gamma which i so wanted to look at imported into vue keeping poser shaders.
even worse poser 7 doesn't like the relative path either because then it thinks the path starts in the poser 7 folder.
love esther
kuroyume0161 posted Thu, 22 May 2008 at 8:40 PM
See, this is what three straight days of 5 hours sleep does to you - it adles the brain.  That is so true here.  You may need to stick with the merging of your separate Runtimes into the main one then.  I would definitely discuss this issue with SM directly since it seems to be something of an oversight on their part - Carrara, Vue, and other software are assuredly assets to their assets so they might not want to invalidate them (and I'm not sure that these other software will get about rectifying this themselves all too quickly).  You may also want to mention this to E-on so that they are aware of the change in referencing.
LostinSpaceman posted Thu, 22 May 2008 at 10:01 PM
Quote - Nice idea but sadly i already tried this...
love esther
I dunno. Why don't you do a test PZ3 of a cube with Gamma on it and see if Vue even recognises the gamma correction? I'm certainly not going to defend Poser 7 but Poser 6 can find my stuff no matter which runtime it's in using relative paths as long as the runtime has been linked properly. Just one more reason Why I prefer Poser 6. That and it imports to Vue and Carrara pretty consistantly.
estherau posted Thu, 22 May 2008 at 11:12 PM
 yes I could certainly try a cube.
I did tell smith micro but I got an automated response about what to do if your pz3 won't import into vue that talked about compressed files etc which is not my problem.
I don't know if e-on knows about this but you would think they would wouldn't you.
You would think these two software companies would realize how they help one another and communicate better.  I only got into poser in the first place because I had vue and wanted to populate my scenes.
Well I better go and buy a new 1 TB harddrive to put all my poser stuff on, because I am going to need it I think.
Love esther
svdl posted Thu, 22 May 2008 at 11:36 PM
Don't be too quick about that new drive. This is one thing that can easily be solved using PoserPython.
I'll find some time over the weekend to write a little script that'll convert the relative paths in your .pz3s to absolutes. I'm going to use Python so it'll be cross platform.
My gallery   My freestuff
estherau posted Thu, 22 May 2008 at 11:42 PM
 You really think that is possible?  That would be totally awesome.  It couldn't convert once the pz3 is created because all paths then start with the word runtime. It would have to save a pz3 itself somehow instead of saving via poser.
Love esther
kuroyume0161 posted Thu, 22 May 2008 at 11:46 PM
With svdl, all things are possible (in Poser with Python scripting)! ;)
svdl posted Thu, 22 May 2008 at 11:51 PM
I know. Here is how the script will work:
It'll take an original .pz3 and write out a new .pz3 with absolute references.
THe script will run from inside Poser, since it then can access the list of linked libraries.
estherau posted Fri, 23 May 2008 at 12:22 AM
 that sounds good.
Love esther
aeilkema posted Fri, 23 May 2008 at 1:15 AM
Sounds great! I'm encountering the same problem also and that script would be a huge help!
Food for thought.....
estherau posted Fri, 23 May 2008 at 6:29 PM
 my communication with smith micro so far:-
Dear Riesa,
The reason we chose to make all paths relative was to facilitate moving the main Runtime out of the Poser folder. Poser Pro can locate files regardless of their location (although it may take a bit longer in some cases) but this does admittedly create issues with applications like Vue that use an older version of the Poser SDK which can't properly locate all required source files without absolute paths. This is unfortunate but we're working with e-on to provide an updated SDK wich should allow them to create a Vue update which better handles files created in Pro.
Just to be absolutely clear, there's no way to force Poser Pro to write absolute paths in PZ3s, nor do we intend to allow this; for the moment Vue users will need to continue creating PZ3 files in Poser 7 to ensure compatibility. I very much apologize for the inconvenience but this should be a temporary situation.
Regards, Colin Gerbode
Technical Support
The thing is though that in the previous versions of poser the path was relative for the main runtime which can easily be merged with the new poser.  All one has to do is first merge the new runtime into the old runtime so no old things will overwrite the new things, then copy that runtime back into the new version of poser.
Not only do the relative paths slow everything for people with multiple runtimes, but when object files or texture files have the same name, poser is going to make mistakes.  I am very sad that you are not allowing the absolute paths.
estherau posted Fri, 23 May 2008 at 6:32 PM
 Dear svdl  this is how the paths are written in mac pz3s to work properly with vue:-
SAM HD:Applications:PoserAll:Poser_Victoria4:Runtime:Geometries:DAZPeople:V4_2remap.obj
textureMap "/Applications/PoserAll/Poser_Victoria4/Runtime/textures/ThorneWorks/Tanith/4_v4TanithM.jpg"
bumpMap "/Applications/PoserAll/Poser_Victoria4/Runtime/textures/ThorneWorks/Tanith/4_v4TanithB.jpg"
do you suppose that poser changed so that other software that they don't have deals with such as carrara and dazstudio will be struggling to import?
Love esther
nruddock posted Fri, 23 May 2008 at 7:10 PM
Quote - do you suppose that poser changed so that other software that they don't have deals with such as carrara and dazstudio will be struggling to import?
One possible reason this was changed for PPro is the network rendering feature (as paths could easily be different on the render machines).
Another possibility is that it makes it easier for PZ3 to be shared within an organisation where the content will likely be setup differently on each artist's machine.
The consequences for other software that imports PZ3s, is that they now need to emulate Poser's search algorithm for all content location not just for files that could have relative paths in previous versions (which was everything but PZ3s).
markschum posted Fri, 23 May 2008 at 7:10 PM
I have a program that may help you if you drop me a pm I will see what I can do with it .
Poser doesnt need to search as such, it just needs to append the relative path with the runtime paths and test for file existance , althougyh Poser file searching will find it even if its in the wrong place .
kuroyume0161 posted Fri, 23 May 2008 at 7:52 PM
This is exactly what my software does.
First it tests the path given (good for absolute paths only of course), then the path is stripped down to the relative path (where possible) and all available runtime paths are prepended to test.  If that fails, and content is being loaded, it checks the folder wherein the content resides.  If it's a scene or content, then the appropriate runtime folders are searched (textures/reflection maps for images files and geometries for obj files).  I don't do a full Runtime folder search as that would be ludicrous. ;)
estherau posted Fri, 23 May 2008 at 8:12 PM
 from smithmicro:-
I'm sorry to be the bearer of bad news in this case- but explicit paths really caused a lot of problems, especially in non-scene files (CR2s, PP2s etc.) Although using only relative paths does allow for confusion if source files have the same names and file paths- which they shouldn't if the content is properly created and set up- I hope you can see a bit of our point of view. It was also essential to make all paths relative as a part of allowing the main content Runtime to be located outside the Poser Pro folder (to satisfy Vista's access constraints, among other reasons.)
Now, as to the issue with Vue- we have provided e-on with our updated SDK some time in the past, and I think they have created updaters to Vue that use the new SDK, which should resolve the problems you've seen with Pro scenes. It's probably a good idea to ensure that you've got the latest Vue build installed. We'll also follow up with e-on to ensure that they have in fact made such an updater available.
Again, I do apologize for the inconvenience but I hope you can see the logic involved in our decision, even if you don't agree with it.
Technical Support
svdl posted Fri, 23 May 2008 at 8:13 PM
The weird thing is that full folder searches don't have to take that long. I'm working on a little project in .NET for poser library management, and one of the features is that it can search for available Poser installations on the entire system.
The disks on my system are fast (2x WD Raptor in RAID 0 + 1 SATA-II 300 GB + 1 SATA-II 750 GB), but loaded with folders, applications and data. A full drive scan for anything called Poser.exe or PoserPro.exe takes less than half a minute.
estherau posted Fri, 23 May 2008 at 9:05 PM
 sounds very interesting.
I have another question which i should know the answer to but I can't remember. Maybe it is related to this topic.
After I render, when I switch back to the posing window there is always a considerable delay.  Is poser relooking for textures during that delay?
love esther
kuroyume0161 posted Fri, 23 May 2008 at 9:28 PM
svdl, but what about everyone else. ;)  My boot drive has 330,000 files on it and data drive has 490,000 files.   Probably 50,000 folders between them.  And I consider this moderate.  Someone with 10 drives with 1,000,000 files on each is going to take a long time - at least in respect of finding references.  Drive speed matters but so does the number of files.  Windows is notoriously slow when dealing with many, many files.  MacOS is much better in this regard.
manoloz posted Fri, 23 May 2008 at 10:51 PM
Quote -  sounds very interesting.
love esther
You should do a background render to get the full benefit of Poser pro. But anyways, I think the delay can be memory optimization. That is, when not rendering to the background, you don't need to see the viewports updated, so that part of memory is freed to be used for the renderer.
That's my theory, anyway.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
aeilkema posted Sat, 24 May 2008 at 3:46 AM
*It was also essential to make all paths relative as a part of allowing the main content Runtime to be located outside the Poser Pro folder (to satisfy Vista's access constraints, among other reasons.) *
I never liked Vista..... probably never will.
kuroyume0161 posted Sat, 24 May 2008 at 3:53 AM
Quote - *It was also essential to make all paths relative as a part of allowing the main content Runtime to be located outside the Poser Pro folder (to satisfy Vista's access constraints, among other reasons.) *
Agreed. ;)
What I've encountered is that files in the same location as the 'program files' (whatever it's called in Vista) are read-only.  This is rather ridiculous.  I had to make a special update to my plugin to write preference/data files to the Users folder to circumvent this limitation since these files are normally stored in where the plugin is installed (in the Cinema 4D plugins folder).
With Vista, it may be that the Runtimes actually exist outside of the Poser install.  Nice move, Microshit. ;)
svdl posted Sat, 24 May 2008 at 1:03 PM
"What about other users"
Ths search facility ran within half a minute on a system with over 1,500,000 files. The computer and the drives are quite fast, admitted. And I could speed things up for systems with multiple drives - one worker thread per drive, threads running in parallel (searches are not CPU intensive).
About the program files folder being read-only, that's actually a good move. Altering your program executable should only be possible in unusual situations (such as a signed update from the vendor). Unix/Linux based systems usually protect their executables too.
I like the idea of separating executable, config/preferences and data into separate locations with separate access control.
Under Vista it is sort of mandatory.. Under XP, it has been recommended best practice for years.
I do not like Vista, but not for this reason. There's other reasons (graphical bloat, DRM crap).
kuroyume0161 posted Sat, 24 May 2008 at 3:16 PM
Unfortunately, nobody was listening to MS about this. ;)  Even Cinema 4D is encountering similar issues since it stores preferences and browser files in the program install folder.  I rectified this in my plugin by simply looking for the Users folder and copying/referencing my preferences and other data files from there instead on Vista.
I think that the 1GB stolen by OS, Draconian hardware requirements, and DRM crap - as you so eloquently put it ;) - are some of my main reasons for avoiding Vista at this stage.  My computer, being less than a year old, should be fully up to hardware specs - but then one never knows.
estherau posted Sat, 24 May 2008 at 7:40 PM
 You know smithmicro probably has no idea how much poser content some people have in their external runtimes.
LostinSpaceman posted Sat, 24 May 2008 at 8:05 PM
Hehe.... I doubt Smith Micro even knows what an external runtime is with all the software that company has absorbed!
estherau posted Sat, 24 May 2008 at 8:11 PM
 you may be right.  So hmmm, how many eyelashtr.jpgs do you think are in all my runtimes, and silver.jpg and concrete.jpg and wall.jpg etc  and is poser pro just going to take the first one it finds then once it possibly can't find this in the default poser runtime?
love esther
markschum posted Sat, 24 May 2008 at 8:55 PM
there are relative paths in poser that are worse than just starting at runtime . Some of the file referances seem very cryptic , but actually start at runtime:textures ..
Its fine for Poser , but nasty if you want to import 8in another application.
Smith micro is quite correct though , any third party application should be able to evaluate those paths . Its an excellent reason though NOT to have duplicate names in your runtimes that are not identical files .
kuroyume0161 posted Sat, 24 May 2008 at 9:06 PM
Well, but, erm, uh.  The problem is that neither SM nor the user has real control over filenames used by content - this is something that the content providers must work out.  And there aren't many guidelines enunciated in this regard.
I would think that as long as the relative path is not "eyelashtr.jpg" but instead ":Runtime:textures:BoobasFiles:eyelashtr.jpg" there will be no troubles in finding the correct file.  But it does depend upon two things: Does Poser do this specific test before doing a blind search (we hope it does) and will content creators be so kind to make their references this clear?
svdl posted Sat, 24 May 2008 at 11:10 PM
Naming was a concern with the package I released at DAZ too. They suggested prepending a code before each and every filename, since "body.jpg" or "sword.obj" are far too generic.
The people at DAZ suggested using a short (3 to 4 letters and/or numbers) prefix for everything. I used my screen name, so you'll have texture files like svdlBody.jpg. The chance that Poser picks the wrong texture/geometry then will be far, far less.
So there are guidelines (sort of).
By the way, each and every object I've ever made has been run through CorrectReference and contains the correct relative paths to geometries and textures. As a content provider, I pride myself on delivering trouble-free and user friendly content, either free or commercial.
Might be something for the marketplace testers - check for generic filenames. Or maybe they already do that.
markschum posted Sun, 25 May 2008 at 12:29 AM
if the resolved pathname exists then it is used , no searching done , but it looks like Poser searches the default runtime , then the others in the order they were added. In python thats poser.Libraries().     Then Poser searches , and may the good fairy sprinkle you with happy dust if you have many silver.jpg or anything else that arent exact duplicates.
Content providers could use Daz Studio to test file referances , because it doesnt search , if the file isnt where the relative path says you get an error .
kuroyume0161 posted Sun, 25 May 2008 at 12:47 AM
In that case, as long as the path is unique (per my BoobasFiles example), then it shouldn't matter in which Runtime it looks.  That is, if the same textures exist in multiple Runtimes distinguishable by their unique paths, it should resolve to one of them as it does its reference checks.  As you say, if the reference isn't found or is incomplete, then may the fates smile upon you.
An interesting question arises: Does Poser still use absolute references to files outside of any Runtime (say a texture image file from another source stored someplace which you picked yourself)?  I would hope and imagine that this is the case.
kuroyume0161 posted Sun, 25 May 2008 at 12:52 AM
I should note that in my case, being that my plugin isn't running from Poser, I have two strategies for reference resolution.  Users add all of their Runtimes to my 'Runtime Explorer'.  If none exist, they are prompted during scene import to add at least one.  If Runtimes exist, they can limit the check/search scope by enabling Runtimes - only the enabled Runtimes are used in resolution.  Or, if none are checked (or all checked) the resolution goes from top to bottom of the Runtime list (which is rearrangeable as well).
This strategy can reduce import times when dealing with many Runtimes wherein the user knows those of interest for the importing scene.
estherau posted Sun, 25 May 2008 at 10:26 PM
 Any luck svdl?
love esther
svdl posted Mon, 26 May 2008 at 1:53 AM
Sorry, been more busy than I expected. Will try to finish the script tonight.
estherau posted Mon, 26 May 2008 at 2:18 AM
 I thought it might have had some glitch where it wouldn't work.  No rush.
Love esther
svdl posted Mon, 26 May 2008 at 3:48 PM
Got it. Works like a treat in Windows, should work on MacOSX and Mac OS 9 too.
Here's the script. Save as ConvertToAbsolute.py in a convenient location (I suggest a subfolder of the :Runtime:Python:poserScripts:ScriptsMenu folder).
The script will ask the user for the .pz3 file to convert, and it'll create a new .pz3 file with 'Absolute' appended to the file name, containing only resolved absolute references.
kuroyume0161 posted Mon, 26 May 2008 at 3:57 PM
One thing missing - that I'm dealing with at the moment: an associated PMD file.  The user can simply copy it and rename it or replace the old pz3 with the new one.  Just making this possibility known.
estherau posted Tue, 27 May 2008 at 2:16 AM
 thanks svdl will keep u posted
svdl posted Tue, 27 May 2008 at 2:28 AM
One thing I'm concerned about is case sensitivity. I can't test that on Windows, but I do know that file names in Unix (and thus probably in Mac OSX) are case sensitive.
I've tested the script on a Poser Pro test .pz3 that contains items from multiple runtimes, and on my system the script can resolve each and every reference.
I hope it'll work on the Mac. But I cannot be sure.
estherau posted Tue, 27 May 2008 at 6:10 AM
 I didn't think case sensitivity would be a problem because it isn't a problem for the finder on my mac when I do searches.  There is some sort of problem though.  The script opens and asks me to chose the pz3 and when I locate the pz3 Iwant, it creates a new pz3 but there is just a spinning beachball in poser(unless maybe my runtimes are so massive I just haven't waited long enough or something??) and then I have to forcequit and the new pz3 your script has made doesn't seem to have any changes to the paths with external runtimes, but just to the paths for the cameras which were in the poserpro folder.
Love esther
estherau posted Tue, 27 May 2008 at 6:15 AM
 does it matter that all my external runtimes are in a folder called poserall which is separate to the poserpros folder Love esther PS here's just part of the poserall folder.  One of the folders is open so you can see the runtime inside it.  Each subfolder of poserall has a runtime
svdl posted Tue, 27 May 2008 at 2:59 PM
The script does take some time to run (about one minute on a 100 Mb pz3 with objects from 6 separate runtimes), that's why it prints progress to the screen (one line for each 1000 lines of .pz3 it processes, plus every object/texture reference it encounters). It works perfectly on Windows, and the script does not ue any OS specific routines.
I have never used a Mac, so I don't know whether printing to the debug windows works.
You have quite a lot of external runtimes, and each time the script encounters a relative reference for the first time, it'll scan those runtimes until it has found the reference. As soon as the script finds the reference, it'll stop searching the remaining runtime, and it'll store the reference in an in-memory dictionary.
The second time that it encounters the same reference it'll find it in the in-memory dictionary first, and so it doesn't scan the runtimes. Which is a definite speedup for the script.
Depending on the size of your scene and the speed of your Mac I'd expect the script to take from 3 to 30 minutes to complete. I expect the script to be slower on your Mac mainly due to the amount of runtimes you have (I've got 10 external runtimes, you've got over 30), and the fact that my disk systems are faster than Mac disks.(unless you have a $5000+ MacPro system, that is).
LostinSpaceman posted Tue, 27 May 2008 at 6:09 PM
Thanks for another fine script even if I don't have Poser Pro. ;)
kuroyume0161 posted Tue, 27 May 2008 at 6:19 PM
svdl, maybe you can take a hint from what I explained my code doing above and let the user order and select the Runtimes to use for resolving references rather than using all of them in the order given?  It really can expedite the process even though it does require some user configuration.
estherau posted Tue, 27 May 2008 at 7:07 PM
 I think maybe the script isn't working at all.  Because nothing comes up in the script window and the ball spins for ages.
Is it because I don't have the external runtimes in the poser folder.  Is it looking for them in there or just somewhere on my harddrive or somewhere on all my 4 internal hard drives?
Love esther
PS That is a good idea Robert
kuroyume0161 posted Tue, 27 May 2008 at 7:17 PM
If he's getting the Runtimes from the LibraryPrefs.xml file like the feature that you requested, then it should be capable of working with all of them no matter where they reside (as long as anything on an external drive is available).  Don't remember if Poser Python enumerates available Runtimes.
svdl posted Tue, 27 May 2008 at 9:40 PM
Quote - If he's getting the Runtimes from the LibraryPrefs.xml file like the feature that you requested, then it should be capable of working with all of them no matter where they reside (as long as anything on an external drive is available).  Don't remember if Poser Python enumerates available Runtimes.
It does, in Poser 7 and up. And the script uses that feature.
It may be broken on the Mac - I don't know. I do know that I've avoided Tkinter, since it's flaky on PC and broken on Mac (at least, it has been for several versions).
svdl posted Tue, 27 May 2008 at 9:44 PM
Esther, could you try the following script?
# Test print statements and Libraries() function
import poser
libraryList=poser.Libraries()
for library in libraryList:
        print library
# end script
If it works, it prints a list of your external runtimes to the screen, in a simple text popup window. If not, then that part of Python is broken on Mac, and I'll have to do something else.
estherau posted Tue, 27 May 2008 at 10:49 PM
 do i just paste the whole thing into a text  doc, then change extension to.py ?
kuroyume0161 posted Tue, 27 May 2008 at 10:55 PM
Yes.  And put it in the proper place like the other script.
svdl: Ok.  I was looking at the Poser 6 Python doc and couldn't find it there.  So, this will be limited to Poser 7+ then.
estherau posted Tue, 27 May 2008 at 10:56 PM
   File "/Applications/Poser Pro/Runtime/Python/poserScripts/ScriptsMenu/svdl/test2.py", line 1
    {rtf1ansiansicpg1252cocoartf949cocoasubrtf270
SyntaxError: invalid token
estherau posted Tue, 27 May 2008 at 10:57 PM
  File "/Applications/Poser Pro/Runtime/Python/poserScripts/ScriptsMenu/svdl/test.py", line 1
kuroyume0161 posted Tue, 27 May 2008 at 10:58 PM
rtf = run time file/function (?)
cocoart = Cocoa run time file/function (?)
Which version of MacOS are you running?  Though I haven't had any problems with Poser 7 or Poser Python on MacOSX 10.4.11 or 10.5.2.  Let me double check the latter.
svdl posted Tue, 27 May 2008 at 11:11 PM
Hmm, looks like a paste error, Python can be nitpicky about empty lines or spaces. Here's the same script in a text file (save as testLibs.py), with the correct line spacing and indentation.
svdl posted Tue, 27 May 2008 at 11:12 PM
kuroyume: this script is targeted at Poser Pro, it solves a problem that only occurs with Poser Pro. So I didn't make it backwards compatible with P6 or earlier.
kuroyume0161 posted Tue, 27 May 2008 at 11:20 PM
Gotcha and true. :)  It could be useful as a way to rereference PZ3s to changes in Runtimes (path or whatnot).  I've added this to my plugin as well - so that people sharing C4D scenes with Runtime-related texture references, the required content, but different paths to their Runtimes can have them re-resolved. Or, if they've reinstalled to different drives on a new system perhaps (etc. and so on).  ;)
I had no problem with scripts on 10.5.2 in Poser 7 - my script was written on Windows and it works on MacOS.  Hopefully there isn't some problem with Python scripts on Mac with Poser Pro!
dadt posted Wed, 28 May 2008 at 3:24 AM
This problem is not just with PZ3 files but also with character,prop,hair,material collections   - in fact any type of file saved from PP.
dadt posted Wed, 28 May 2008 at 4:39 AM
I've just done some tests with interesting results.
I set up a scene in Poser 7 with a V4 character  ,clothes jewellry and a few assorted props. None of these are in my P7 or PP runtimes and the character has its obj and textures in other runtimes than where the CR2 file is located. I ran 3 cloth room and one dynamic hair simulations then saved the scene as a PZ3.
I then loaded it into PP and saved the scene from there, then did some tests on how they loaded. In each case I loaded the scene into a freshly started program so that no info was left in temp files.
Poser 7 loaded the P7 version of the file in 12 min  40 secs. No problems
Poser 7 loaded the PP version in 11 min 30 sec, It found all items and textures without any queries.
Poser Pro loaded the P7 version in 5 min 40 sec. No problems,good speed gain.
Poser Pro loaded the PP version in 10 min 0 sec.
Carrara 6 loaded the P7 version in 50 sec. No problems
Carrara 6 loaded the PP version in 60 sec. I was pleasantly surprised that it found everything with no problems.
estherau posted Wed, 28 May 2008 at 9:07 AM
 svdl
this part is working really well!!
 here's the cut and paste of the result;-
/Applications/Poser Pro/Downloads
/Applications/PoserAll/Poser_pankoVC_combat
/Applications/PoserAll/Poser 5/Poser 4
/Applications/PoserAll/Poser 6
/Applications/PoserAll/Poser_Hair
/Applications/PoserAll/Poser_military
/Applications/PoserAll/Poser_GI_CombatGear_V3
/Applications/PoserAll/Poser_GI_CombatGear_M3
/Applications/PoserAll/Poser_schlabber
/Applications/PoserAll/Poser_shadowdancer
/Applications/PoserAll/Poser 5/newRuntime
/Applications/PoserAll/posermildollarbaby
/Applications/PoserAll/Poser_BDUV3-1 Folder
/Applications/PoserAll/Poser_V3streetfighter
/Applications/PoserAll/Poser_ppletexnmorphs
/Applications/PoserAll/Poser_combatmedicposes
/Applications/PoserAll/Poser_trucks
/Applications/PoserAll/Poser_M3everydaywear
/Applications/PoserAll/Poser_M3BDU
/Applications/PoserAll/Poser_daz desert soldier
/Applications/PoserAll/shadownet_test_buttondress
/Applications/PoserAll/shadownet_furtest
/Applications/PoserAll/Poser_streets
/Applications/PoserAll/Poser_stonemason
/Applications/PoserAll/Poser_Miki2_Complete
/Applications/PoserAll/Poser_World
/Applications/PoserAll/Poser_school
/Applications/PoserAll/Poser_casualwkendV3
/Applications/PoserAll/Poser_SciFi
/Applications/PoserAll/ziggieICUsept06
/Applications/PoserAll/Poser_BCMiki2
/Applications/PoserAll/Poser_junglevines
/Applications/PoserAll/Poser_Tribal
/Applications/PoserAll/Poser_Animals
/Applications/PoserAll/Poser_BCVickie4
/Applications/PoserAll/Poser_shadownet
/Applications/PoserAll/Poser_Peasant_tex
/Applications/PoserAll/Poser_Teenmike3
/Applications/PoserAll/Poser_M3denemjeansnjckt
/Applications/PoserAll/Poser_realstreetclothes
/Applications/PoserAll/Poser_jungleV4
/Applications/PoserAll/Poser_Boxing
/Applications/PoserAll/Poser_universalmagicmags
/Applications/PoserAll/Poser_Jeanz_V4
/Applications/PoserAll/Poser_skeletons
/Applications/PoserAll/Poser_knight
/Applications/PoserAll/Poser_aikoBC
/Applications/PoserAll/Poser_V4Cowgirl
/Applications/PoserAll/Poser_G2
/Applications/PoserAll/Poser_Apollo
/Applications/PoserAll/Poser_hairtotalupdo
/Applications/PoserAll/Poser_G2morphsuit
/Applications/PoserAll/Poser_HighStakes-DoubleDown
/Applications/PoserAll/Poser_bar
/Applications/PoserAll/Poser_Freak
/Applications/PoserAll/Poser_M3suit_Beowulf
/Applications/PoserAll/Poser_Velvet Rope
/Applications/PoserAll/Poser_bullking
/Applications/PoserAll/Poser_architecturalinteriors
/Applications/PoserAll/Poser_Margharita
/Applications/PoserAll/Poser_mouse
/Applications/PoserAll/poser_jmmpack Folder
/Applications/PoserAll/Poser_shadowdancerV4
/Applications/PoserAll/Poser_hairtotalupdo2
/Applications/PoserAll/Poser_Panko_AssaultWeapons_4
/Applications/PoserAll/Poser_IngenueV3
/Applications/PoserAll/Poser_Minotaur
/Applications/PoserAll/Poser_Panko_AssaultWeapons_1
/Applications/PoserAll/Poser_bookcasenclock
/Applications/PoserAll/Poser_BVHshacklensswat
/Applications/PoserAll/Poser_M3loungewear
/Applications/PoserAll/Poser_casualM3
/Applications/PoserAll/Poser_totaleyes
/Applications/PoserAll/Poser_Secretary
/Applications/PoserAll/Poser_Aeroplanes
/Applications/PoserAll/Poser_Panko_AssaultWeapons_2
/Applications/PoserAll/Poser_MilDragon
/Applications/PoserAll/Poser_Mitsu_hair
/Applications/PoserAll/Poser_USPS Mailbox
/Applications/PoserAll/Poser_Big_Casino
/Applications/PoserAll/Poser_City Block-1
/Applications/PoserAll/Poser_firearmDAZpack
/Applications/PoserAll/Poser_Clothes_Accessories_misc
/Applications/PoserAll/Poser_Gym
/Applications/PoserAll/Poser_Food
/Applications/PoserAll/wwconverted
/Applications/PoserAll/Poser_Hair_Cecile2
/Applications/PoserAll/Poser_MuscleCar
/Applications/PoserAll/Poser_RealisticParlor
/Applications/PoserAll/Poser_Music
/Applications/PoserAll/Poser_FantasyHistory
/Applications/PoserAll/Poser_AmusementPark
/Applications/PoserAll/Poser_lauralukeclothes
/Applications/PoserAll/Poser_Eyes
/Applications/PoserAll/YA_VivLaura
/Applications/PoserAll/Poser_Panko_IHMS
/Applications/PoserAll/Poser_AirBase
/Applications/PoserAll/Poser_RealJeans
/Applications/PoserAll/Poser_MercenaryBase
/Applications/PoserAll/panko_test
estherau posted Wed, 28 May 2008 at 9:22 AM
 I am running leopard. ie OS 10.5
Love esther
kuroyume0161 posted Wed, 28 May 2008 at 11:22 AM
Quote - This problem is not just with PZ3 files but also with character,prop,hair,material collections   - in fact any type of file saved from PP.
True as well.
svdl posted Wed, 28 May 2008 at 2:57 PM
Esther: you've got over a hundred runtimes in your system. That's quite a lot. The way the script is written, I expect the total running time to be almost linearly dependent on the number of runtimes.
On my system, I use 12 separate runtimes, so that would mean the script would run 10 times as slow on your system.
Another factor is the speed of the system itself. I tested and ran the script on an Intel Q6600/8 GB RAM / multiple SATA-II disk system, the runtime folders being located on another physical drive than Poser itself or the operating system. Operating system XP 64 bit. On that basis I expect the script to run 20%-50% faster than on a midrange to high end Mac.
Then again, it's strange that the script doesn't report to the screen. It SHOULD do so, for every texture/object reference it encounters, plus once for every 1000 lines read (a Poser scene file can contain over 10 million lines).
estherau posted Wed, 28 May 2008 at 8:01 PM
 guess what - i left it running all night, and when I went to bed there was a spinning beachball, but this morning it had reported to the screen and the last line says:-
Handling line  6628000
Done
Off to try the pz3 in vuenow.
will keep you posted.
Love esther
svdl posted Wed, 28 May 2008 at 8:07 PM
Okay, then I know what's going on. On the Mac, the screen doesn't update as it should. But the script (most probably) works.
estherau posted Wed, 28 May 2008 at 8:27 PM
 Hi svdl,
well the new pz3 file that your proggie created now imports into vue but there is a problem finding textures - it comes in without any.   I checked the new pz3 and found this sort of pathway for the textures
textureMap ":Runtime:textures:Panko:Modern_1:L85A1_v1.jpg"
this texture is actually in an external runtime.
Love esther
svdl posted Wed, 28 May 2008 at 8:52 PM
That is weird.
Here's how the script works:
On Windows, it works for every path in the .pz3, be it an object reference, a texture reference, a readScript reference or a .PMD reference.
Why it doesn't work on Mac is beyond me.
estherau posted Wed, 28 May 2008 at 8:55 PM
 maybe because the textures need to be separated by : instead of / ???
estherau posted Wed, 28 May 2008 at 8:58 PM
 this is the last part of the screen
Testing for file '/Applications/PoserAll/Poser_Panko_AssaultWeapons_1/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Panko_AssaultWeapons_1
Testing for file '/Applications/PoserAll/Poser_totaleyes/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_totaleyes
Testing for file '/Applications/PoserAll/Poser_Secretary/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Secretary
Testing for file '/Applications/PoserAll/Poser_Aeroplanes/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Aeroplanes
Testing for file '/Applications/PoserAll/Poser_Apollo/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Apollo
Testing for file '/Applications/PoserAll/Poser_Panko_AssaultWeapons_2/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Panko_AssaultWeapons_2
Testing for file '/Applications/PoserAll/Poser_MilDragon/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_MilDragon
Testing for file '/Applications/PoserAll/Poser_Mitsu_hair/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Mitsu_hair
Testing for file '/Applications/PoserAll/Poser_USPS Mailbox/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_USPS Mailbox
Testing for file '/Applications/PoserAll/Poser_Big_Casino/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Big_Casino
Testing for file '/Applications/PoserAll/Poser_City Block-1/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_City Block-1
Testing for file '/Applications/PoserAll/Poser_firearmDAZpack/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_firearmDAZpack
Testing for file '/Applications/PoserAll/Poser_Clothes_Accessories_misc/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Clothes_Accessories_misc
Testing for file '/Applications/PoserAll/Poser_Gym/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Gym
Testing for file '/Applications/PoserAll/Poser_Food/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Food
Testing for file '/Applications/PoserAll/wwconverted/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/wwconverted
Testing for file '/Applications/PoserAll/Poser_Hair_Cecile2/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Hair_Cecile2
Testing for file '/Applications/PoserAll/Poser_G2/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_G2
Testing for file '/Applications/PoserAll/Poser_MuscleCar/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_MuscleCar
Testing for file '/Applications/PoserAll/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Testing for file '/Applications/PoserAll/Poser_RealisticParlor/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_RealisticParlor
Testing for file '/Applications/PoserAll/Poser_Music/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Music
Testing for file '/Applications/PoserAll/Poser_FantasyHistory/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_FantasyHistory
Testing for file '/Applications/PoserAll/Poser_AmusementPark/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_AmusementPark
Testing for file '/Applications/PoserAll/Poser_lauralukeclothes/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_lauralukeclothes
Testing for file '/Applications/PoserAll/Poser_Eyes/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Eyes
Testing for file '/Applications/PoserAll/YA_VivLaura/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/YA_VivLaura
Testing for file '/Applications/PoserAll/Poser_Panko_IHMS/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_Panko_IHMS
Testing for file '/Applications/PoserAll/Poser_AirBase/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_AirBase
Testing for file '/Applications/PoserAll/Poser_RealJeans/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_RealJeans
Testing for file '/Applications/PoserAll/Poser_MercenaryBase/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/Poser_MercenaryBase
Testing for file '/Applications/PoserAll/panko_test/Runtime/textures/PW texture files/SP3-Business suit/SP3 business suit blouse-TEX3-PW.jpg"'
Not present in  /Applications/PoserAll/panko_test
Done
estherau posted Wed, 28 May 2008 at 9:00 PM
 In the mac (os 10) all the texture paths have : seperators for some reason even though the .obj files don't.
Love esther
":Runtime:textures:Quarker:RadiantJaguarHair:RJH_Brown.jpg"
svdl posted Wed, 28 May 2008 at 9:03 PM
The only thing that I can think of is symbolic links messing up the script. The fact that it leaves the texture references unmodified means that it could not resolve the relative path to an absolute path, and I've read something about Unix symbolic links messing up the "exists" function in Python.
estherau posted Wed, 28 May 2008 at 9:09 PM
 but the .obj paths work fine on your script.
Is it the : separaters causing the problem?
Love esther
estherau posted Wed, 28 May 2008 at 9:10 PM
 /Applications/PoserAll/Poser_V3streetfighter/Runtime/Geometries/Panko/L85A1.obj
example of object path  - the separaters are different on the mac to the texture paths.
svdl posted Wed, 28 May 2008 at 9:12 PM
I found something in the file listing, and I think I know what's wrong. The texture file name has been enclosed in double quotes, and one of those quotes got included in the search expression.
Now that I know what is going wrong, I can fix it.
estherau posted Wed, 28 May 2008 at 9:12 PM
 yee ha!!
svdl posted Wed, 28 May 2008 at 9:40 PM
I made a new test.pz3, explicitly using texture references enclosed in quotes mixed with unquoted references, and tested the new script. It works. All references get converted to absolute. The new script is in the link.
P.S.: I'm glad I made the script as verbose as it is, it allowed me to find the error.
svdl posted Wed, 28 May 2008 at 9:46 PM
Quote - > Quote - This problem is not just with PZ3 files but also with character,prop,hair,material collections   - in fact any type of file saved from PP.
True as well.
Beg to differ: items stored in libraries SHOULD have relative references! Saving them with absolute references is an error, and items with absolute references are (rightfully) rejected by the marketplace testers here and at DAZ.
svdl posted Wed, 28 May 2008 at 9:54 PM
Esther: considering the amount of runtimes you have, I think I'd better make the script somewhat smarter. Here's what I'm going to do: the script will first search in a list of "preferred" runtimes, and if it cannot resolve the reference using that list, it'll use the full list. As soon as it finds the reference, it'll add that runtime to the "preferred" list.
I think that checking for file existence is one of the more time consuming parts of the script, and this way I can reduce the amount of existence checks.
kuroyume0161 posted Wed, 28 May 2008 at 9:58 PM
Quote - > Quote - > Quote - This problem is not just with PZ3 files but also with character,prop,hair,material collections   - in fact any type of file saved from PP.
True as well.
I beg to differ further - if someone uses references from different Runtimes and saves, say, the figure to the Figure library then what - eh? ;)
As originally noted, whether you save a PZ3 or anything to the library, the same exact rules apply.
Though I'll agree with you on commercial products requiring relative references.
estherau posted Wed, 28 May 2008 at 10:07 PM
 trying the new script.  will go to work soon and let you know when I come home tonight.
Love esther
markschum posted Wed, 28 May 2008 at 10:09 PM
You can get the files full path if the scene is loaded to Poser , but Poser doesnt seem to save that info in the pz3. There are some comments from curious labs from Poser 5 that say, Do not have duplicate file names  in multiple runtimes because of the possibility that the wrong one gets picked.
Heres the script I wrote that checks each runtime for the file and replaces the full path
Just rename from txt back to the py
Its a non-elegant brute force approach
estherau posted Wed, 28 May 2008 at 10:20 PM
 hi it actually finished before I went to work - guess what!!  IT WORKS!!!  Everything imports perfectly into vue.  yipppeeeee!
love esther
PS thank you muchly svdl - you are a champion
estherau posted Wed, 28 May 2008 at 10:38 PM
 mark- i will have to try this tonight when i get home from work
love esther
Mazak posted Thu, 29 May 2008 at 7:33 AM
bookmark ;-)
Mazak
Google+ Bodo Nittel
estherau posted Thu, 29 May 2008 at 10:45 AM
 Mark - I just tried your script - it works very well indeed.  And very fast too.  I didn't try it on the same file that I tried with svdl script but I have a feeling yours may be faster.
I will have to try it on a more complex scene to see if that is correct.
Thankyou very much to everyone - this is great.
Much vue happiness because of this.
Love esther
PS it definitely is a very fast script!  Just checked.
PPS any chance of a standalone one that doesn't need poser open to fix the file or maybe could batch fix them?  Not essential by any means.  what we have already is wonderfully great!!!!!!
markschum posted Fri, 30 May 2008 at 2:57 PM
thanks , note the bit about non-elegant brute force solution :)
there may be some references that the program wont handle .
it creats a filename_new.pz3 with the changes . I hate changing the original files in case something bad happens .
written in python to run from poser but the pz3 does NOT have to be loaded , I just use poser to get python running .
LostinSpaceman posted Fri, 30 May 2008 at 2:59 PM
Nice work guys!
ccarol01 posted Sat, 26 July 2008 at 4:27 PM
Quote - You can get the files full path if the scene is loaded to Poser , but Poser doesnt seem to save that info in the pz3. There are some comments from curious labs from Poser 5 that say, Do not have duplicate file names  in multiple runtimes because of the possibility that the wrong one gets picked.
I could not change the file extension to .py in Vista. It keeps its notepad association. All the other Python scripts say file type py and have an program association of Windows shell common. i just can not find this file type to change the program association to make this work. Can anyone help me?
markschum posted Sat, 26 July 2008 at 5:05 PM
Since you have trouble with the file I have put up a zip file containing the properly named .py file extension. Unzip to your poser/runtime/python folder anywhere .
Another person had an issue with the rename because they had the default folder option set to "hide known file extensions" which conceals the actual file type .
Hope this solves the problem.
here the sharecg link for the script www.sharecg.com/v/27564/script/script-to-fix-file-paths
ecccoman posted Wed, 20 August 2008 at 7:08 PM
Mark
I downloaded this .py file that you put in sharecg. Below is url.
http://www.sharecg.com/v/27564/script/script-to-fix-file-paths?division_id=11
Pardon the ignorance of a relative newbie, but where do I put this python and what do I do with it???
Good for P7 as well as PP??
I certainly need it and appreciate your efforts.
Thanks
estherau posted Wed, 20 August 2008 at 7:59 PM
 you only need it for p7 if you have installed the Sr3 update into P7.  it is good for poser pro  install here poserscripts -> scriptsmenu
adorety posted Thu, 21 August 2008 at 9:12 PM
So I've tried the Scripts_to_fix_the_path utility and it works eratically. I want to try svdl's script but it's just a text file. How do I put it into a python script? I'm not a dummy, but I have no experience in python or any other scripting. I feel this is close to being fixed, but I'm missing something or lack the know how.
Thanks, Art
IsaoShi posted Fri, 22 August 2008 at 11:56 AM
adorety - paste the text into a new file with a .py file extension; for example: svdlfixpaths.py. You have to make sure that the .py is the file extension, i.e. it must replace the .txt that you would normally see on the end of a text file. To do that, you might need to go into Tools / Folder Options / View (this is on a WinXP PC, btw) and untick the box that says 'Hide extensions for known file types'.
Save that file in your default Poser runtime under:-
RuntimePythonposerScriptsScriptsMenu
Then start Poser, and you can run it direct from the Scripts menu.
Or you can save it in another location and run it using File > Run Python script.
(edit) by the way, Python scripts use line indentation for nesting/structure, so the cut and paste of text must be accurate.
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
estherau posted Fri, 22 August 2008 at 9:21 PM
 got my first error with mark's script:-
 /Applications/PoserAll/Poser_Crowd
/Applications/PoserAll/Poser_Always-A-Lady
/Applications/Poser 7
/Applications/PoserAll/Poser_Panko_AssaultWeapons_3
/Applications/PoserAll/Poser_azlcrowdkit
/Applications/PoserAll/Poser_Ballroom
/Applications/PoserAll/Poser_Motorbikes
/Applications/PoserAll/Poser_V4_WLeatherJacket
Traceback (most recent call last):
  File "/Applications/Poser Pro/Runtime/Python/poserScripts/ScriptsMenu/markschum/fix_scene_paths.py", line 29, in ?
    fi = file(mypath,"r")
TypeError: 'str' object is not callable
IsaoShi posted Fri, 22 August 2008 at 10:38 PM
I just noticed that the path I posted above did not include the separators.
It should have been:
adorety posted Sat, 23 August 2008 at 12:03 PM
Thanks IsaoShi I got the script to process, but it's not helping much. Vue continues to ask for the path to the textures, etc. I'm going back to Poser 7 for now. I hope I didn't waste $200 :-(
estherau posted Sat, 23 August 2008 at 6:05 PM
 YOu also have to point vue at the poser pro folder in vue preferences
adorety posted Sat, 23 August 2008 at 11:37 PM
I know about the preferences. Even though there is no Poser Pro preference choice I pointed Vue to Poser Pro in the browse. Not sure what's up. I use Win Vista 64 4GB RAM and Centrino Duo. I use Vue Pro Studio and the latest version.
estherau posted Sun, 24 August 2008 at 1:13 AM
 gosh - it actually works for me.
you realize with svdl script you get a new pz3 with the word absolut in it don't you?  ie don't use the original pz3.  open the one with absolute and check the paths in a text editor.  otherwise try mark schrum's script.
love esther
adorety posted Sun, 24 August 2008 at 4:43 PM
Yes. When I have time to reinstall, I'll check it out again. Thanks.
dadt posted Thu, 18 February 2010 at 1:37 PM
I downloaded the "fix scene paths" script a couple of days ago and it works brilliantly with Poser 8 and Vue 8. One problem has turned up though, if the scene contains a dynamic cloth item then the dynamics are lost and the item imports into Vue as a complete mess.
  Without the script the dynamics are OK but you can spend forever trying to find the textures.
Can anyone suggest a cure for this?
adorety posted Thu, 18 February 2010 at 2:17 PM
I've been using the utility in Poser (8) to collect scene inventory and saving it to a folder. When I import into Vue from this folder, everything works perfectly.
dadt posted Thu, 18 February 2010 at 2:37 PM
Tried that, works fine,thanks.
graphyx posted Tue, 31 March 2020 at 2:38 AM
I'm using Poser Pro 11 and today I downloaded and installed v11.3 but when I tried to open a couple of files I've been working on it made me re-like all of my geometries and all of my textures which required more than a couple of hours. I've now discovered that I will have to do this for all of the things I'm working on . . . so why is this happening . . . I'm using an iMac Pro and OS Catalina . . . PLEASE HELP ME HERE!!!!
NikKelly posted Fri, 03 April 2020 at 4:01 PM
Sorta tangential to PZ3 issues...
"Quote - This will never be undoable as the pz3s cannot ever be converted back to absolute pathways ever again. It is tragic."
http://www.philc.net/PZ3editor.php { Recently updated for latest Win'10.}
PhilC's full PZ3 Editor ($10 registered) can pull the bundled models out of PZ3, similar to how GeomStripper can convert a PP2 to PP2+OBJ.
And, in passing, probably let you edit the paths...
graphyx posted Sat, 04 April 2020 at 3:56 AM
Thank you and, oh brother, this will become a total nightmare . . . well thanks again . . .
graphyx posted Sat, 04 April 2020 at 3:59 AM
. . . I see that's a PC app, I should have mentioned I'm using an iMac Pro with OS Catalina, is there an app for Mac, thanks . . .
bagginsbill posted Sat, 04 April 2020 at 11:11 AM
12 year old necropost - probably the best I've ever seen.
EldritchCellar posted Sat, 04 April 2020 at 11:30 AM
graphyx posted at 12:21PM Sat, 04 April 2020 - #4385410
That's the classic lament of Mac users trying to utilize Poser related utility apps. They're all windows. I just recently started using a windows machine, had left off at poser 8 on a Mac. Now many of the things that required external thingamabobs are automated within Poser. I'm also surprised that many of the old Poser utilities that were windows only will run in windows 10, but they do. Mac users are SOOL on that front, and I know this from first hand experience, especially in the Poser content creation helper front...
W10 Pro, HP Envy X360 Laptop, Intel Core i7-10510U, NVIDIA GeForce MX250, Intel UHD, 16 GB DDR4-2400 SDRAM, 1 TB PCIe NVMe M.2 SSD
Mudbox 2022, Adobe PS CC, Poser Pro 11.3, Blender 2.9, Wings3D 2.2.5
My Freestuff and Gallery at ShareCG
EldritchCellar posted Sat, 04 April 2020 at 11:46 AM
Dimension3d's PFO is windows only as is philC's PFE. Dimension3d passed away and philC has "retired?" so windows users are likely to face the same dilemma in due time on that front...
EldritchCellar posted Sat, 04 April 2020 at 11:51 AM
Strictly my opinion, having been away for a few years, but it feels like there's a "circling of wagons" thing going on in the Poserverse. People seem less friendly, less knowledgeable, less helpful, and just less in general. Not a hostile critique, just an observation. But what do I know? I'm probably a "troll" lol.
EldritchCellar posted Sat, 04 April 2020 at 1:10 PM
graphyx posted at 1:47PM Sat, 04 April 2020 - #4384933
Not sure if this is what your looking for but Netherworks Creator's Toybox let's you fix path references within Poser via a python script... it's in the file optimizer palette and can be used to make corrections to scene pz3 files, amongst a million other useful features. The offending pz3 must be located in a Runtime:Libraries:Scene folder in order for the tool to access it...
Think it might do the trick. You might need to run Poser as an administrator to get some of the features in the Toybox to work (at least I did with the Runtime Rodent).
https://www.renderosity.com/mod/bcs/creators-toybox/116432
EldritchCellar posted Sat, 04 April 2020 at 1:24 PM
Disregard my "run as administrator" suggestion, that's a windows issue, forgot you're on a Mac...
