Subject: Poser 7 Material Room Setting Question
ladyperiwinkle opened this issue on May 24, 2008 · 2 posts
ladyperiwinkle posted Sat, 24 May 2008 at 1:48 PM
What settings would I use to make material see through?
Thank you.
IsaoShi posted Sat, 24 May 2008 at 2:15 PM
The simple answer is set the Transparency and Transparency_Edge dials to 1.0.
If you get weird shadow effects from the invisible material in your raytrace-enabled renders , it's because the transparency dials do not make the material transparent to raytracing.
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
