nyguy opened this issue on May 27, 2008 · 7 posts
nyguy posted Tue, 27 May 2008 at 7:27 AM
I am working on a figure in 3d Max 7 and wanting to export it to a few different apps for use. It is a four legged animal with a long tail. The issue I am having is with the tail, I would like to make it as flexible as possible but with out having to create too many bones. How would I go about this and also make it possible to export for use in Poser?
Poserverse The New Home
for NYGUY's Freebies
Teyon posted Tue, 27 May 2008 at 9:43 AM
Okay, if your intent is to take it into Poser, you won't need to rig it in Max at all. So, just make the tail with as much detail as you feel it needs. Once you've done that, then you'll have to figure out how many groups it will take to get the effect you want. Keep in mind that these days, things like tails in Poser are often done with ERC's, which help give the impression of smooth and flexible bending between groups.
Of course, the more groups the more fluid it may be but the more bones it will take. It's really up to you, you'll have to look at the density of the mesh, figure out how much bending the tail will really need to do and then create the groups/bones to match. A really long tail should have more than 4 sections to allow for smooth bending. Six is usually good but again, it depends on the creature and the mesh...some even have as many as 10 sections.
more a setup question then a modeling one :)
manoloz posted Tue, 27 May 2008 at 9:45 AM
AFAIK, Poserwise, there are two basic ways for that:
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
nyguy posted Tue, 27 May 2008 at 10:08 AM
I am planning to use it in both Poser and Max. I was hired to rig this model for use in max, since I thought it would make a good poser model I put in the contract for permission to use in Poser with all rights for said poser file to go to me. problem I am having is getting enough flex with the tail to meet the client's need. He wants it (the tail) to be able flexible as a whip. I am not sure if the current mesh is capable of that with out some major refinements. I had to take the original mesh that was supplied and add some polygons in order to make the legs when bending without looking like blocks of wood.
manoloz posted Tue, 27 May 2008 at 10:20 AM
You can of course, rig Max-wise to take into account SDS, so to lower the polygon count a bit.
As to rigging for Max specifically, I haven't touched Max in ages, so I cannot give you up-to-date advice
Visit my blog! :D
manoloz posted Tue, 27 May 2008 at 10:26 AM
I just finished rigging some tentacles for Poser with 95 joints in each arm. Ok, they have um... fingers, but still, they're quite long and supposed to be made from metallic parts, so lots of joints was a must.
I presume you'll get an easier time with your tail ;-)
Visit my blog! :D
odeathoflife posted Thu, 10 July 2008 at 9:23 AM
in poser you can use the 'curve' thingy (very technical term there) in the parameters of the joints to curve the group between the joints. you will need a few more poly segmants there to make this look good about 5 or 6 I would figure between each joint but it is an easy way to make it look believeabilly (lol) flexable.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
