wildfire203 opened this issue on May 30, 2008 · 3 posts
wildfire203 posted Fri, 30 May 2008 at 9:05 AM
I know this question has been asked before but I didn't understand the answers very well....So lets assume I just got Daz and it's been installed and everything is finished with it set up. I just bought the outfit sugar form littlefox it come in two files to download I unziped both files what do I do now?
Thank you for you help.
TheHalfdragon posted Fri, 30 May 2008 at 12:16 PM
ok open the file you unzipped them to ... then also open your main daz folder usually in C;program files/daz studio, or something to that effect
then you drag and drop the folders into the proper content or runtime folders to get them where they need to go
i don't have that product per say but it works with all the freebies i have.
daz mats and mat presets ( specifically for daz files/folders) go int the content folder and if you put even poser content into the runtime folder in there you'll keep it less confused
and well hail i'm no expert but new enough to not really know the technical aspect of it all. hope this helps out
faeriemajikk posted Sun, 01 June 2008 at 12:38 AM
Just thought i would add ...
Different types of files will help you determine where to put them
Clothing usually cr2 generally goes into figures folders and if you got textures with them they are usually a pz2 file which then goes into pose folder.
It can get a little confusing trying to work it all out sometimes.
But if you familiarise yourself with the types of files it will help you to add them to the correct folders and also help you find them again when you want them!
