Subject: Help getting started with Poser post work for genitals - V4
3DNeo opened this issue on Jun 06, 2008 · 12 posts
3DNeo posted Fri, 06 June 2008 at 1:16 AM
 I could use some help and advice on doing post work for my renders to add genitals to V4. I can get realistic renders from V3 using a modified figure available at the other render site. M3 is not an issue either. However, what I am having trouble with is finding a way to do this with a fair amount of ease and without issues. By that, I mean that I have tried several of the V4 solutions at that other render site and they just don't work well. I always get unmatched textures, seams, etc. that requires post work anyway. So, I thought why not save myself a lot of time and headaches and just do it in post work to make it easier and more realistic?
What I need advice on is getting started doing the post work and how best to handle this. If you could use a modified figure like on V3 there would be little if any post work required. However, what I need to know is:
  1. Do I edit the texture for the figure in Photoshop? I thought this would be the best to paint on or clip from image and paste, smooth, etc. then save the new texture.
  2. Will I need to create many texture versions for the different types of genital designs I need using that texture. In other words, say texture-1 I am working with and modified it, now, don't I need to modify and save again for each genital design I need or want? Like texture-1, texture-2, etc.
  3. Do I need to do this for varied V4 poses? I'm thinking it will need to be different for standing, kneeling, from behind, etc. So I should paint on different ones for each like texture-1-kneeling, texture-2-standing, etc.
The only problem I see is this could add up to a lot of texture versions for just one character. Otherwise this should work correct? If not, how would you do this?
Any other tips or pointers appreciated, as I think it is a real SHAME on Daz to NOT make their V and M figures with anatomy already built-in. Goodness knows why since that's how God made everyone and artists have been doing nudes for centuries now.
Thanks for the reply on this and any help/advice.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 & Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB 800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
David.J.Harmon posted Fri, 06 June 2008 at 7:26 AM
should have got Alice 2, but you could go to Renderotica and see if they have some gens.
David J Harmon
davidjharmon.com
3DNeo posted Fri, 06 June 2008 at 8:40 AM
Quote - should have got Alice 2, but you could go to Renderotica and see if they have some gens.
Thanks for the reply but it didn't help any at all - I'm sorry but please read my OP on this as I am looking for detailed feedback and advice from those doing this in a pro way. :)
  1. I know about Alice but most don't use that figure and I have WAY too much invested in V4, hundreds worth of add-ons for cloths, props, etc.
  2. As noted in my post, I know about that site and have seen all of them and find no PROFESSIONAL solution like you can get with V3. I have even tried "Amber" but find some faults with her.
  3. I don't like any of the pre-fab post work items on that other render site as they look bad, too fake, etc.  plus I am wanting to do them on my own in post work for the scene that requires it. That means I will need something like Photoshop CS3/CS4 to do this and modify the character textures I own for V4 as outlined in my original post.
 If anyone can help on this for advice, software/brushes and techniques you recommend for Photoshop CS3 or how you do it in post work yourself it would be appreciated. You can send me a PM on this if you prefer as well.
Thanks.
Jeff
David.J.Harmon posted Fri, 06 June 2008 at 9:23 AM
well with Alice 2 you can set the dials to 0 for her but you still have the gen morphs, I think their is about 8 of them. Plus you can add other morph sets to her...  And now with some of the textures you can get a nice detail of the gen area.
David J Harmon
davidjharmon.com
patorak posted Fri, 06 June 2008 at 9:31 AM
Have you tried the overpainting technique?
David.J.Harmon posted Fri, 06 June 2008 at 9:33 AM
Quote - Have you tried the overpainting technique?
psst (don't tell anyone but I always do it...)
David J Harmon
davidjharmon.com
patorak posted Fri, 06 June 2008 at 10:23 AM
*psst (don't tell anyone but I always do it...)
Oops!  I let the cat out of the bag.  I hope the render purists don't see this post.
Hey 3DNeo
Check out this link.  http://forums.cgsociety.org/showthread.php?f=199&t=359226&highlight=overpainting
David.J.Harmon posted Fri, 06 June 2008 at 10:28 AM
Quote - psst (don't tell anyone but I always do it...)
Hey 3DNeo
only thing is the other photo(image) is my own...   I blend different images together. the problem is I was ask to start doing animation again and now I have to do it all in 3d.
David J Harmon
davidjharmon.com
patorak posted Fri, 06 June 2008 at 10:37 AM
*I blend different images together. the problem is I was ask to start doing animation again and now I have to do it all in 3d.
Speaking of animation.  Did you know they had trouble with specularity in the new Hulk movie?
markschum posted Fri, 06 June 2008 at 10:44 AM
at renderotica there are a bunch of V4 gens and a modified V4 figure.
The one from RajDarge (Gspot) is mapped the same as the v4 hip so the v4 skin texture applies and there is a blend map supplied to merge the two textures fairly seamlessly.  DrTaj also has a postwork kit comprising a variaty of stuff as psd layers , with instructions on adding and blending them in .
I am hopeless at postwork so Thats all I can suggest .
David.J.Harmon posted Fri, 06 June 2008 at 10:45 AM
patorak: no I didn't what program they use?
David J Harmon
davidjharmon.com
patorak posted Fri, 06 June 2008 at 11:35 AM
Not sure.  Here's the link.  http://forums.cgsociety.org/showthread.php?f=2&t=633463&highlight=hulk
I know my friends at the Embassy Visual Effects used Lightwave for the cave scene in IronMan.
