Forum: Carrara
Subject: Carrara wont open saved files
jackhalsey opened this issue on Jun 06, 2008 · 6 posts
jackhalsey posted Fri, 06 June 2008 at 3:19 PM
Hello
I am working on an animation and Carrara 6 (and I finally got it to update) will open the pz3 scene just fine and render it.  However when I save it as a car file..it appears to save it but it will not open the saved file.
It will load it and note the percentage progression and then when it gets close to 100% it just hangs.  It does this with all files yet will almost instantly import any pz3 file.
Any suggestions and thank you.
Pinklet posted Fri, 06 June 2008 at 3:27 PM
 I have had Carrara do this on a couple of files. Try opening a blank document and importing your file. This might work.
jackhalsey posted Fri, 06 June 2008 at 3:58 PM
Had my hopes up for it didnt work..just hangs.  Thank you for the suggestion.
Sueposer posted Fri, 06 June 2008 at 5:14 PM
I just tried this with C6 std. I imported the P7 scene, then deleted the poser ground and lights and cameras (important) before saving as a C6 file. C6 opened the new scene file just fine.
It might matter whether your P7 pref's are set to allow binary external morph targets and have compression turned on.
jackhalsey posted Fri, 06 June 2008 at 5:29 PM
Thank you I will try that.  The problem is that it used to import these same scenes....
Sueposer posted Fri, 06 June 2008 at 8:16 PM
The evil inconsistent problem bug. That was how I discovered that the binary morph option in P7 matters. I have a utility that requires it be turned on. .. and another that requires it be off. Aargh!
