chris1972 opened this issue on Jun 14, 2008 · 6 posts
chris1972 posted Sat, 14 June 2008 at 7:38 AM
I am creating a sky dome backdrop that should not show shadows at any time. But the rest of the scene objects should. Is there a way to accomplish this?
Chris
geep posted Sat, 14 June 2008 at 8:13 AM
Select the sky dome "Properties" and UNcheck "Casts shadows."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
bagginsbill posted Sat, 14 June 2008 at 8:13 AM
The sky dome shader should not use any of the lighting nodes, or the built-in diffuse or specular.
If you have an image to attach to it, put it into Alternate_Diffuse - this channel is a straight pass-thru to the render, so whatever you plug in there is not modified by lighting or shadows.
Geep, that is how to stop casting shadows.
That will not stop you from showing shadows that fall on the dome.
chris1972 posted Sat, 14 June 2008 at 8:24 AM
Alternate_Diffuse worked perfectly!
Thank you much
Chris
geep posted Sat, 14 June 2008 at 10:04 AM
@ chris 1972
Oops, sorry, my bad ... :unsure:
That'll teach me to read too fast and answer B4 coffee.
@ bagginsbill
Thanks for the correction my friend.
Glad to have you around to keep the ol' geepster honest. :biggrin:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
