Smaker1 opened this issue on Jun 19, 2008 · 7 posts
Smaker1 posted Thu, 19 June 2008 at 3:11 AM
Hello,
I am currently reinstalling all my stuff (P3DO/Poser 7/Prpcd) to a new PC (Windows XP) and have two questions:
-1: using PRPCD I have now a temporary message ".png The file extension is not registered for processing". Everything is loaded in Poser but I can't find from where this message is coming
-2: I can't remember the process to have a direct "open in poser" with the right clik instead of the "send to/...."
Thanks for your help!
EnglishBob posted Thu, 19 June 2008 at 3:52 AM
(From memory) You get the PNG message only if you try to go from P3dO to Poser via PRPC, because P3dO associates each library item with its thumbnail - so this method tries to send both at once, and PRPC has no mechanism for loading a PNG into Poser.
Use the inbuilt PoserPython in P3dO instead. It's in the right click menu for any library item. You still need to start up the receiver script in Poser, of course.
Smaker1 posted Thu, 19 June 2008 at 7:07 AM
Thanks!
But I can't find inbuild python with the right click (in any library). Do you know what did I miss during my installation process? (I use P3DO Pro)
EnglishBob posted Thu, 19 June 2008 at 7:23 AM
I'm not sure - I'm not near my main installation of Poser at the moment. If nobody else chimes in in the meantime, I'll try to check it out when I get home.
Smaker1 posted Thu, 19 June 2008 at 7:48 AM
No problem, I'm also not near any Poser runtime! :-)
Smaker1 posted Thu, 19 June 2008 at 3:24 PM
I Found it!!
I downloaded the V1.9.5 plug-in pack but it's not complete! The Rsr2png, Poser python,... plug-ins are in the 1.9.2 pack.
Both my problem are resolved!
Thanks again
EnglishBob posted Thu, 19 June 2008 at 4:26 PM
Cool!
