Subject: How to keep xyz value the entire animation..
jackhalsey opened this issue on Jun 23, 2008 · 5 posts
jackhalsey posted Mon, 23 June 2008 at 8:05 PM
Hello
I have an animation and have had to lower the boxing ring to the floor.  I did the first frame and it keeps popping back up so do I have to go thru it frame by frame and keyframe it.  I tried using the graph but I cant get the line perfectly straight.
Thank you
PhilC posted Mon, 23 June 2008 at 8:22 PM
You can click and drag in the animation graph window to select all but the first frame. Once selected click the delete key frame button. Now all you need to do is correctly set the first frame.
See http://www.philc.net/tutorial7.htm for a screen shot of the animation windows.
jackhalsey posted Mon, 23 June 2008 at 9:05 PM
Thank you very much.
muralist posted Mon, 23 June 2008 at 9:34 PM
jack,
Unless you want the boxing ring position to change during the animation, delete all of its keyframes and set it to the height you want.  Unless you set a key it will not move.
jackhalsey posted Mon, 23 June 2008 at 11:02 PM
Thank you muralist.
