Subject: Can you successfully delete frames from the begining?
jackhalsey opened this issue on Jun 23, 2008 · 8 posts
jackhalsey posted Mon, 23 June 2008 at 11:05 PM
Hello
I know you can shorten an animation by deleting frames like you had 500 frames you can delete the last 200 etc.
Can you take away frames from the front of the animation.  For example I have an animation where the character lands in a certain position I want to cut away and then cut back to the character in that same certain position and more action resumes.  Or would it be easier to just click on that character and save as?  ....And what do you suggest I save it as?  Thank you very much.
muralist posted Tue, 24 June 2008 at 12:53 AM
Yes.  Set keys on the frame after the cut before you chop the front end.  Alternately you can go to that frame and save as a single-frame pose, or save the set of frames whose poses you wish to keep.
jackhalsey posted Tue, 24 June 2008 at 4:05 PM
Thank you.  I am still not sure how to chop off the front end.  I can do the back end at the frame counter but still am clueless about chopping off the front end.  Please clarify and thank you so very much.
markschum posted Tue, 24 June 2008 at 4:09 PM
decide what you want to trim , say from 1 to 60, keyframe frame 61 so that position is recorded.
then drag and select all keyframes from 1 to 60 , hit delete .
then drag and select all fromes from 61 to end , and drag the entiire block back to frame 1 .
jackhalsey posted Tue, 24 June 2008 at 5:17 PM
That worked thank you.
svdl posted Tue, 24 June 2008 at 8:03 PM
Another option:
My gallery   My freestuff
jackhalsey posted Wed, 25 June 2008 at 12:23 PM
Wow  thank you very much
Silke posted Wed, 25 June 2008 at 1:46 PM
I usually do nothing at all to the first frame, because I find myself messing up... and then having to delete. If I applied a pose on frame 1, then I usually regret it bigtime. :)
Silke
