Subject: How Do I Get Rid Of Undesirable Light Artifact ?
mathman opened this issue on Jun 25, 2008 · 10 posts
mathman posted Wed, 25 June 2008 at 9:03 AM
Hi all,
In the attached picture, you can see the problem in the subject's lower eyelids, and also (to a lesser extent) his lower lip.
I've tried a few lighting combinations but cannot get rid of it.
Any help appreciated.
Thanks,
Andrew
vincebagna posted Wed, 25 June 2008 at 9:22 AM
AO would get rid of those :)
Miss Nancy posted Wed, 25 June 2008 at 11:39 AM
there are a number of threads here on how to eliminate nostril glow,
from poser 4 thru the current version.
stewer posted Wed, 25 June 2008 at 12:03 PM
It looks to me like you don't have shadows turned on?
bagginsbill posted Wed, 25 June 2008 at 5:17 PM
If you already have shadows on, then you may need to decrease your shadow min bias. You may also need to increase your shadow map size (for depth-mapped shadows). Do not use 256 - ever. Go to 1024 at least.
Raytraced shadows are the best of all. However, they don't behave well with displaced surfaces so sometimes you have to use depth-mapped.
mathman posted Wed, 25 June 2008 at 7:05 PM
bagginsbill,
When you say "shadows on", are you referring to the checkbox in the Render settings which says "Cast shadows" ?
thanks,
Andrew
bagginsbill posted Wed, 25 June 2008 at 7:35 PM
Yes and also on the light. They both have to be on.
If you're using raytraced shadows, you also have to enable raytracing.
mathman posted Thu, 26 June 2008 at 4:44 PM
Bagginsbill,
If you have a large number of lights, do you have to check that each one has shadows turned on ? ... is there a quicker way, e.g. do you know of a python script ?
thanks,
Andrew
bagginsbill posted Thu, 26 June 2008 at 4:55 PM
Uhoh. You have a large number of lights? Hmm.
A Python script could be built to automate that. However, the bigger question is, why do you have a large number of lights?!?
Which Poser are you using? In particular, are you using a large number of lights because you're in Poser 5 and do not have IBL?
Faking ambience with a large number lights is just not the way to go with Poser 6 and up. You should be using IBL.
Many Poser 5 light sets were created with a ton of lights and no shadows on most of them, because making 20 or 30 good-quality shadow maps would take a loooong time. Light sets like that will always produce those glowing surfaces.
If you're using Poser 6 or better, you really only need two lights for basic even lighting of a single figure. Sometimes you use one more as a rim light (from behind). You never need more than 4 to do a portrait.
After you come back and tell me which Poser you have, we can talk about what to do. If you have Poser 6 or better, I'll show you how to use IBL and one or two directional lights for good portrait lighting.
mathman posted Thu, 26 June 2008 at 7:19 PM
Bagginsbill,
I have P7 SR2.1. The "large number of lights" was a hypothetical scenario, seeing as I have a lot of light sets with a ton of lights. Maybe I should throw them out ?!
Unfortunately, I have forgotten which light set I was using to produce the image in my first posting in this thread.
Just need to get rid of those glowing artifacts, and produce a truly realistic render - traditionally it has been nostril or inner mouth glow, but in my case I have been getting glowing lower lip, lower eyelids and tear ducts.
Thanks again.
regards,
Andrew
