primalscreem opened this issue on Jul 05, 2008 · 3 posts
primalscreem posted Sat, 05 July 2008 at 8:22 AM
i have photoshop7 and imageready and was wondering if aneyone knows how i can use them to compile several pdf files into 1 ebook. thankyou
retrocity posted Sat, 05 July 2008 at 8:53 AM
you'll need a PDF writer to be able to output to PDF (the writer installs itself as a "printer subsystem" and enables PS or IR to create PDF documents).
after that you'll need an app that open the PDFs to merge/combine your files (if you're using WIN, you can get PrimoPDF - http://www.primopdf.com/primopdf_free_idx.htm - for free, it has a combine feature ).
you can also try the EXPORT script in PS:
The files in the Source Files window are used to generate the pages in the PDF presentation, starting with the topmost file for the first page and progressing down the list for subsequent pages. To change the sequence, select a file and drag it to a new position in the Source Files window.
hope this gives you something to work with,
retrocity
primalscreem posted Sun, 06 July 2008 at 9:04 AM
thank you worked like a charm
