Cybertenko opened this issue on Jul 08, 2008 · 9 posts
Cybertenko posted Tue, 08 July 2008 at 1:31 PM
Hallo to everybody. I can use some help how to correctly base models in poser 7 - meaning putting them on ground so they not floating no drowning in the ground. I am trying to set collision detection on on scene, ground, and both feet of model, but still figure hangs in the air or diving in the ground. Is there some trick or python script for easy basing?
bagginsbill posted Tue, 08 July 2008 at 1:36 PM
Press ctrl-D
Cybertenko posted Tue, 08 July 2008 at 2:25 PM
this command seems a little bit unprecise for me since it sinks boots into ground.
bagginsbill posted Tue, 08 July 2008 at 2:57 PM
It does? Then the figure you're using is messed up.
What Ctrl-D does is drop the item precisely so that the lowest part of it is exactly on the ground.
It has always worked for any prop or figure I've used it on. I use it all the time. I drag something to a new position and drop it.
Cybertenko posted Tue, 08 July 2008 at 3:41 PM
OK, I will it try once more. Thanks for your help.
JOELGLAINE posted Tue, 08 July 2008 at 4:49 PM
Ctl+D will always sink boots into the ground plane. It's a well known glitch. If you select the main figure (IE: Mike3,Vic3,etc) ANY footware will sink below the lowest part of that figure because the footware remains conformed to the main figure.
If you elevate the main figure and select the footware and go Ctl+D the footware will fall to the floor, NOT the main figure. There is no "Smart Drop" like in Vue in Poser where groups can be dropped like one figure. I wish there was.
I cannot save the world. Only my little piece of it. If we all act
together, we can save the world.--Nelson Mandela
An inconsistent hobgoblin is
the fool of little minds
Taking "Just do it" to a whole new level!
bagginsbill posted Tue, 08 July 2008 at 5:20 PM
Ah - I guess that's true. I don't encounter that too often.
Cybertenko posted Wed, 09 July 2008 at 12:48 AM
JOELGLAINE: yes thjat is exactly what I mean. Any solution for that?**
Purrdey posted Thu, 10 July 2008 at 7:03 AM
make sure you have ground shadows off (display ===> ground shadows
sometimes P7 makes things look like they are below ground when they aren't.
Also, with the outfit containing the boots, there is sometimes a foot pose for the model to make the boots sit correctly. That might help.
