efstarlet opened this issue on Jul 09, 2008 · 156 posts
efstarlet posted Wed, 09 July 2008 at 7:00 PM
Smith Micro Software, Inc. and the Poser team are pleased to announce that the Poser 7 English Service Release 3 (SR3) is now available for both Macintosh and Windows. SR3 will update any previous version of Poser 7 English to the latest version 7.04. SR3 offers several enhancements and addresses known issues present in the following areas:
In order to download Poser 7 SR3 or receive technical support for the product, you must have registered your Poser 7 application serial number. If you have not yet done so, please register now.
With your registered your Poser 7 serial number, you can access and download SR3 for Windows or Macintosh.
In the following post is the full list of Poser 7 English SR3 enhancements and fixes, by category.
efstarlet posted Wed, 09 July 2008 at 7:01 PM
Poser 7 English SR3 enhancements and fixes, by category:
-Improved stability after morph targets have been injected.
-Now updating conforming figure preview after applying Figure symmetry.
-Now preserving parenting when undoing Point At.
-Improved text width calculation for multi-byte characters (Mac OS X only).
-Improved stability upon deleting figure with parented camera.
-Enabled undo for changes 'Casts shadows' property.
-Enabled undo for changes to Parameter settings.
-Now also prepending morph target channels created via 'Split morph' to avoid distortion when applied and figure is bent.
-Fixed case where pressing Home or End keys could cause Poser to exit.
-Now pre-selecting text in text entry fields whenever possible.
-Now preventing side effects when duplicating light source.
-Now keeping focus on Graph palette while clicking & dragging beyond palette boundaries.
-Making QuickTime movie with 2D Motion blur now works properly (Mac OS X only).
-Enabled 2D Motion Blur for Image Sequence rendered in Poser (Mac OS X only).
-Memory dots and custom UI preferences now stored in language-specific sub-directory to facilitate concurrent installation of multiple Poser versions.
-Fixed case where problems with shadow camera parenting would prevent depth map shadows from getting rendered.
-Fixed case where polygon group got accidentally discarded if there were > 32 groups in an OBJ file while multiple group names were specified in the same line.
-Cmd-S shortcut for saving scene now more reliable.
-Improvements to texture map location for preview and rendering
-Fixed case where rendering multithreaded could cause artifact in first bucket (Windows only).
-Now properly reading greyscale 16-bit TIFF images during shading. Improved loading of EXIF tags in TIFF images.
-Improved quality of raytraced shadows.
-Fixed case in which rendering raytraced reflections with depth-mapped shadows in a separate process could cause instability.
-Now mapping textures more accurately at render time (FireFly only).
-Fixed case where rendering in separate process would cause freeze (Mac OS X Panther & Leopard only).
-Fixed case where some buckets weren't processed during multithreaded rendering.
-Fixed case where applying an HDR IBL set while an animation layer was active would fail.
-Now properly restoring current animation layer selection after applying walk to a new layer.
-Improved multithreaded rendering performance with large textures.
-Improved reliability of FireFly render engine when rendering complex scenes.
-Improved reliability of rendering in a separate process when 3D Motion Blur is enabled.
-Fixed case where HDR images were discarded from render cache early (Windows only).
-Fixed case where certain shader would cause render to fail.
-Fixed case where small-scale features applied to bump or displacement channels would produce rendering artifacts.
-Fixed case where running out of memory during raytracing database setup would cause instability.
-Fixed case where switching off texture filtering would cause artifact to appear at seams of high-res tiled textures.
-Fixed case where line segment geometry could cause instability in OpenGL preview.
-Improved line width (Intel OpenGL only).
-Improved transparency map resolution in Preview mode.
-Fixed case in which redundant Center of Mass props were written.
-Now consistently writing relative, platform-neutral paths whenever possible.
-Now preserving start frame of new layer upon re-opening saved file.
-Now preserving text when settings are adjusted.
-Improved stability when applying to conforming figures without head morph targets.
-Now preventing event handling problems after entering text field values on Parameter palette.
-Now preventing instability when recursive value operations on an object's parameters are present.
-Improved stability of Hierarchy editor.
-Enabled creation of figures from Hierarchy Editor.
-Fixed case in which using Space Navigator device in Face room could cause freeze upon applying face.
-Fixed case where repeatedly undoing changes would cause Face Shaping parameters to become inaccessible.
-Fixed case where simulation data would be lost after re-opening a file with multiple simulators.
-Corrected text field locations (Mac OS X only).
Improved quality of dynamic hair simulation results for Bend Resistance values >0.
-User_Defined node now handles its parameters properly.
Fixed case where adding the skeleton of a figure with dynamic hair from the library would cause instability.
-Increased flexibility of automatic content installation.
-Updated to Tkinter 8.4. (Windows) NOTE: Please contact script developer if compatibility issues with Tkinter are encountered.
-Enabled PoserPython-driven morph target injection from external Runtime libraries.
-PoserPython method scene.SetBackgroundImage() now more reliable.
-Enabled JPEG quality parameter for scene.SaveImage()
-Improved stability of PoserPython undo/redo system.
-Now using the standard content search method for finding referenced Python files, depending on the user's specified search policy preference.
-Now accepting any type of value to specify scale factor upon import.
-Improved stability by preventing reinitialization while script-based dialog is showing.
-Now accepting any type of value <= 0 to disable scaling upon import. Omitting kImOptCodePERCENTFIGSIZE will result in import at the last size specified.
-Fixed case where Collect Scene Inventory script would omit certain referenced files.
-Enabled script-based cloth dynamics calculation for scene with multiple simulators.
-Added Poser.Quit() method to enable script to terminate the application.
-Added MovieMaker.SetMovieRenderer() and MovieMaker.MovieRenderer().
-Added Scene.SetRenderDimAutoscale().
-Added Scene.Resolution() and Scene.SetResolution() methods.
efstarlet posted Wed, 09 July 2008 at 8:29 PM
Here are some helpful notes about a few improvements in the SR3 updater and how they may affect you.
File I/O
The SR3 updater incorporates an important change when working with referenced content found in Poser scene files. Poser 7.0.4 saves files with relative, platform-neutral paths for content components such as geometries and textures whenever possible. In previous versions of Poser, paths were written that may have been either relative or absolute. This could potentially create problems when opening up scene files in a cross platform environment or when working across machines with different runtimes.
Poser 7.0.4 now writes consistent paths. The benefits to this change include:
- Backward compatibility with older versions of Poser on OSX
- Better portability when moving files from Mac to Windows, or vice versa, from one machine to another if the runtime locations are not identical, and when runtimes are moved on a system (such as when a new hard drive is added).
- Less clean-up will be required before sharing a newly created library item with other users.
Poser 7.0.4 now searches for referenced files such as geometries and textures next to the PZ3/PZZ that is being opened, if those referenced files cannot be located in either the current or main runtime directories. If your runtime files are messy and contain duplicate file names, the search process results may be unpredictable. Creating files with unique names with a runtime directory structure that resembles the standard Poser runtime setup will help alleviate future issues.
When adding an external runtime to Poser 7.04, the key word “Runtime” must be in the path for the search engine to properly locate your referenced content. In simple terms, your content’s directory structure should duplicate the standard Poser Runtime naming structure. At the top level, content should be in a directory named Runtime, which includes subdirectories that follow Poser’s naming conventions.
FireFly Render Engine
In the development of Poser 7.0.4, we measured several instances of increased FireFly rendering performance; however there are isolated cases where the improved quality of raytraced shadows, Ambient Occlusion, and Displacement/Bump mapping effects can result in slower renderings at similar quality settings. In those isolated cases we’ve improved, the final rendered results are far superior to renderings from previous versions of Poser 7.
Gareee posted Wed, 09 July 2008 at 8:32 PM
Also, not sure if it made it into the final release, but I just used a v4 with a clothing item, and the clothing crosstalk feature was restored!
Tiny had some hair room issues, got them to iron out those issues, and now she can release good quality furred critters for poser 7+!
Greywolf Starkiller posted Wed, 09 July 2008 at 8:55 PM
Not a good start. I've had Poser 7 registered since I bought the SE version when it first came
out, yet the site doesn't recognize the serial number. I registered the number with SmithMicro,
assuming I had to do it again with the new owner. Still no dice. I don't have the time to keep
dealing with efrontier, and now SmithMicro screw-ups. Please let me know what the problem
could be. Poser has been collecting dust because of it's instability. If this has been solved, I'd
like to get back on the horse. :)
Greywolf
LadyMari posted Wed, 09 July 2008 at 9:01 PM
sigh Go figure, they aren't accepting my Serial No. even though I registered it when I got the program and have had absolutely no problems in the past downloading the updates. Just my luck.
dlfurman posted Wed, 09 July 2008 at 9:05 PM
Now if only the validator at Smith-Micro was working.....
space
Khai posted Wed, 09 July 2008 at 9:09 PM
worked fine for me... accepted my serial and I'm now running OK
I suggest copying your serial from your CP account (Mystuff) and pasting that directly... it'll stop any mistakes from happening...
but the validator is working.. that I can confirm...
PilotHigh posted Wed, 09 July 2008 at 9:16 PM
Too bad it won't let me download. It won't accept my valid serial number. I had to email SM about it. So now I play the waiting game...
edit: I did copy and paste!!!
ockham posted Wed, 09 July 2008 at 9:18 PM
"-Now keeping focus on Graph palette while clicking & dragging beyond palette boundaries."
Yay! This was a very serious problem. I'm happy that they finally paid a little
bit of attention to animation!
zollster posted Wed, 09 July 2008 at 9:19 PM
well....i clicked the link....dint put my serial number in cos i couldn't be bothered to go search it out ...... i just hit the download link and sr3 is downloadin as i type
edit to say : d'oh...i hit the wrong link :P
ockham posted Wed, 09 July 2008 at 9:21 PM
Serial number no go. Says "must be all capital letters", but they are all capital letters.
LadyMari posted Wed, 09 July 2008 at 9:26 PM
I cannot find my serial number listed at CP. I bought and registered my copy of Poser 7 directly through e-frontier. Maybe that's the problem.
nickedshield posted Wed, 09 July 2008 at 9:26 PM
Watch out for oh's and zeros, dont type O by mistake.
Gareee posted Wed, 09 July 2008 at 9:30 PM
My guess would be a call to smith micro or an email would resolve your issues far faster then a forum post.
When I upgraded lightewave, I had to call them 3 times to get the proper info to make my dongle work properly. (And was on hold long distance for 20 minutes each time, no less!)
When I upgraded Vue6I, I ran into the same issues, the servers were flooded, so I couldn;t even download the patch, and after I had it and tried installing it, I STILL had to call Eon and again wait forever on hold until they could sort out my serial number issues.
Odds are, and email to them, or phone call tomorrow when they are open will resolve it quickly.
LadyMari posted Wed, 09 July 2008 at 9:30 PM
I quadruple checked what I entered. It simply is not being accepted. This is ridiculous. I'll deal with it later. Got better things to do at present.
Greywolf Starkiller posted Wed, 09 July 2008 at 9:37 PM
Ditto. I'm not so enamoured of Poser at present, that I'm willing to jump through hoops to
get what I paid for. At Present, I use Poser only for rigging. Other programs in my Toolset
are superior renderers. If I can't get SR3, Poser gets to stay as my rigger only, at least until
DS gets rigging. :)
Greywolf
Darboshanski posted Wed, 09 July 2008 at 9:53 PM
Took my serial number no problem and I have downloaded the update maybe the problem with the serial numbers are fixed?. But I won't install it yet until I clear some jobs out I am working on.
Greywolf Starkiller posted Wed, 09 July 2008 at 9:59 PM
No, according to what I've read here, and on the DAZ forums, some are accepted, some
aren't. Since the numbers not being accepted are registered, many from pre-orders of the
SE edition from efrontier, it might be that THAT is what is causing the problem. If so, they'd
better fix it. This is hardly the way to keep customers who were already pissed by eFrontier
screw-ups of this nature.
Greywolf
uli_k posted Wed, 09 July 2008 at 10:00 PM
If you experience difficulties downloading Poser 7 SR3, please contact Smith Micro tech support via my.smithmicro.com/support/index.html and let us know what updater you were trying to access, and what your serial number is. We'll try to address any issues there might be as quick as possible. We apologize for the inconvenience.
Darboshanski posted Wed, 09 July 2008 at 10:04 PM
Quote - No, according to what I've read here, and on the DAZ forums, some are accepted, some
screw-ups of this nature.Greywolf
Maybe I just lucked out my copy was a pre-order SE addition. Wow I actually got lucky at something.
Gareee posted Wed, 09 July 2008 at 10:11 PM
Good to see an official post in the thread here within minutes of an issue report! Obviously they are burning the midnight oil keeping an eye on things...
Greywolf Starkiller posted Wed, 09 July 2008 at 10:13 PM
No thanks. SmithMicro tech support pages are like many others, a PITA to navigate through.
I'm just not interested enough to go through the trouble, though I encourage others to do so.
I haven't used Poser, except for rigging, since it came out, due to stability issues, and have
since moved on to other software. I had thought to get SR3 and try again, since Starlet's post
mentioned that the stability issues had been addressed, but no. I have jumped through
customer service hoops many times, and it is always an exercise in frustration. Thanks
for the info, but I'll pass.
Greywolf
Gareee posted Wed, 09 July 2008 at 10:14 PM
Sounds like someone has some personal issues.. LOL!
Doctor Destruction posted Wed, 09 July 2008 at 10:18 PM
No go with the updates here. And mine's an SE version, as well.
I mean... couldn't they have put up a copy for download at their other Rendo-like site (won't put the name of the place here, but its first letters are "C" and "P")? I've never had any trouble getting updates using that method.
Something's obviously FUBAR at the Smith Micro site.
ratscloset posted Wed, 09 July 2008 at 10:18 PM
Anyone that has a problem getting their Serial Code to be accepted can also contact Customer Support at Content Paradise with their Serial Code. Support@contentparadise.com
NOTE: the SR is for English Language only currently. If you are MAC make sure you are on the MAC Page, not the Windows Page. If you are non English, you will need to wait for that release. Also, make sure you are entering it in the Serial Code Field for the Service Release, not the Upgrade Purchase.
ratscloset
aka John
Greywolf Starkiller posted Wed, 09 July 2008 at 10:28 PM
Not really, Gareee. It's just frustration talking. Customer service, the times I used it, provided
little sevice and major headache, with service reps who knew diddly squat. :) I'll fire off an
email to the above addy. I'm willing to give SM a chance. After a tough day, I kinda snapped. :)
Greywolf
Gareee posted Wed, 09 July 2008 at 10:47 PM
I hear ya.. it's very easy to do, and you can tell when people are posting, but also having real life issues.
FWIW, after I saw Uli's post here, I fired off an email to Poser's dev team, so they also had a head's up when they get in tomorrow that something is amiss somewhere.
Believe me, I went nuts when I did my last Lightwave upgrade, especially since my ONLYphone I had available was my cell phone, and it was on a short charger cord while I was trying to deal with being on hold for 20 minutes each time! LOL!
Course that's nothing compared with my HP "customer service" (and I use the term loosely) last year.
I HATE outsourced technical support with troubleshooting flow chart books, with no actual clue.
ratscloset posted Wed, 09 July 2008 at 10:53 PM
We all have days like that... the good thing is when those days are over! LOL (the bad thing is when the bad day starts on Monday and it is over on Thursday!)
ratscloset
aka John
Gareee posted Wed, 09 July 2008 at 10:57 PM
Actually it;'s GREAT they did this today, because it means they won't be gone for a VERY long weekend before being able to resolve the situation.... ;)
Greywolf Starkiller posted Wed, 09 July 2008 at 11:11 PM
True, I got a reply that my serial was missing two characters. DOH.
Unfortunately, the full number still generated the error. Odd, since they
confirmed that I was registered. Well, no hurry, they'll figure it out. It was
whether I was registered with them or not, that was worrying me. :)
Greywolf
Tashar59 posted Thu, 10 July 2008 at 12:14 AM
My SN doesn't work either. Did last time i used it. It works at CP too.
I take it will be a while before we get a P7Pro SR?
ssgbryan posted Thu, 10 July 2008 at 1:10 AM
Well I sent them an email about an hour ago.
According to the nice gentleman at the other end, there is an issue with a block of Serial numbers. They will be fixed in the morning.
BUT, he did hook me up.
Got the download & am installing now (crossing my fingers!)
jartz posted Thu, 10 July 2008 at 1:44 AM
I went to site and did everything as told by efStarlet when the thread was posted. Went to SM's site which was a lot of leaps and bounds, then went back here to click on the link to SM's Poser page and did the SN of my product, only mistake I made was forgetting my own e-mail address. On top of that no problems, d/l the SR3, installed and the only thing I found different was that there's no e-f, just SM's logo with the same P7 splash screen.
Hadn't played around it a bit, but hope it would run smoothly tomorrow. Unlike the others, I'll keep my finger's crossed on this new update.
JB
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
smallspace posted Thu, 10 July 2008 at 2:01 AM
Well, at least it loads faster...that's nice.
I'd rather stay in my lane than lay in my stain!
Marque posted Thu, 10 July 2008 at 4:20 AM
Mine isn't working either and taking it directly off the email they sent with the sn when I bought it. What a load of crap, how hard is it to put the numbers in when you register a program? Give me a break. And yes I have personal issues with this, tired of all the screwups with this company.
cherokee69 posted Thu, 10 July 2008 at 6:01 AM
I didn't have any problems with the serial number last night. I opened the email they had originally sent me when I bought the P7 upgrade back in 2006 and copied the number from that. Then I went to SM and pasted it in there and it accepted it with no problem. File downloaded without a hitch but I haven't installed it yet.
mwafarmer posted Thu, 10 July 2008 at 6:26 AM
Quote - I didn't have any problems with the serial number last night. I opened the email they had originally sent me when I bought the P7 upgrade back in 2006 and copied the number from that. Then I went to SM and pasted it in there and it accepted it with no problem. File downloaded without a hitch but I haven't installed it yet.
Did the same. I've installed it and have been using it for the last three hours.
Mike
cherokee69 posted Thu, 10 July 2008 at 6:33 AM
Quote - > Quote - I didn't have any problems with the serial number last night. I opened the email they had originally sent me when I bought the P7 upgrade back in 2006 and copied the number from that. Then I went to SM and pasted it in there and it accepted it with no problem. File downloaded without a hitch but I haven't installed it yet.
Mike
Cool, you having any issues or problems with it yet?
Jules53757 posted Thu, 10 July 2008 at 7:09 AM
And when you install, make sure to click on "Create backup of preferences"! With the new logo Smith Micro it starts as if you never used it before in factory state and all external runtimes gone :(
Just use the backup copy of the libraryPrefs.xml from Poser 7 ...Date...Time... into your p 7 preferences folder and it works again.
Ulli
Puntomaus posted Thu, 10 July 2008 at 8:03 AM
Und wo klickt man auf Create backup of preferences? Davon abgesehen kann ich sowieso nichts downloaden, Probleme mit der SN - wieso auch immer. Ich konnte ohne Probleme damit das PPro Upgrade kaufen, aber für einen SR download reichts nicht? seufz
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
BAR-CODE posted Thu, 10 July 2008 at 8:20 AM
Sorry, we had a problem verifying your registration information. Please use the back key to make sure you entered it correctly. UPPER CASE LETTERS ARE REQUIRED. If you continue to get this message,
GREAT UPDATE SITH MICRO !!
now can you fix the problem with the Pre odered Poser 7 Se versions...
I tryed to put it on the CP forums
but i can wait 3 hours before thats Site is loaded ...a other great Sith Micro thing...
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
Puntomaus posted Thu, 10 July 2008 at 8:26 AM
LOL ... same here, BAR-CODE - problem with SN and CP takes forever and a day to load.
Every
Assange
ockham posted Thu, 10 July 2008 at 8:56 AM
Bravo!
SM responded to the email with a good download link.
Installed it, now trying it.
This is the first SR in Poser history that fixes most of the problems I've noticed;
some of which (like the OBJ import bug) have been problems since P4.
Specifically, I thank SM for these fixes and changes:
-[Python OBJ import] Now accepting any type of value <= 0 to disable scaling upon import.
-[Python] Added Scene.Resolution() and Scene.SetResolution() methods.
ockham posted Thu, 10 July 2008 at 9:27 AM
Good job!
MaskimXul posted Thu, 10 July 2008 at 10:16 AM
My serial wouldn't go thru either... I have P7 SE Boxed ordered from CP.
I emailed tech support (techsupport@smithmicro.com) as suggested and got a download link promptly.
Marque posted Thu, 10 July 2008 at 10:17 AM
They sent me a link to their faq about what to do if your sn doesn't work. WTF is up with these people are they running a business or not?
uli_k posted Thu, 10 July 2008 at 10:18 AM
Please only select 'Remove existing preference files' or 'Backup existing preference files' during updater installation if you intend to do that. Yes, those options will return Poser to the factory state, including the runtime library setup.
If you want to continue with your current preferences, please choose 'Use existing preference files' instead.
Marque posted Thu, 10 July 2008 at 10:28 AM
This is what I got from sm. I was very clear and said poser 7 pro. Are they really that friggin dense????????????????????
I apologize for the confusion. There is no Update for Poser Pro. The Update is for Poser 7. If I have misunderstood the issue, please provide the URL of the Update you are trying to aquire.
Marque posted Thu, 10 July 2008 at 10:46 AM
Ok figured out they wanted the sn from poser 7, the OLD poser 7, not the newest one I just bought so which Poser 7 is this release for? They should have just named the newest one poser 8.
Khai posted Thu, 10 July 2008 at 10:48 AM
it's for Poser 7. not Poser Pro. (which is poser PRO not poser 7 or poser 7.5. anyone telling you that is just getting it wrong. it is considered a seperate product for sales and upgrades)
MaskimXul posted Thu, 10 July 2008 at 11:09 AM
Quote - Please only select 'Remove existing preference files' or 'Backup existing preference files' during updater installation if you intend to do that. Yes, those options will return Poser to the factory state, including the runtime library setup.
Crap! I chose 'Backup existing preference files'. Any way to restore it?
Faery_Light posted Thu, 10 July 2008 at 11:34 AM
I kept a copy of the original serial from their site when I first downloaded my P7. I copied and pasted to the upgrade sr3 and no problems downloading. Now for the install, if I don't do something silly...sigh.
Let me introduce you to my multiple personalities. :)
BluEcho...Faery_Light...Faery_Souls.
zollster posted Thu, 10 July 2008 at 12:09 PM
its naffed up occlusion master and unimesh realism kit. thgey both come up with errors and won't run
uli_k posted Thu, 10 July 2008 at 12:22 PM
MaskimXul, what platform are you on? Mac or Windows?
Tyger_purr posted Thu, 10 July 2008 at 12:26 PM
on a windows machine.
go to
c:documents and settings[user name]application data
there should be 2 Poser 7 direcories.
on that just says Poser 7, and one with some numbers after it (its a time and date stamp)
The one with the numbers is the old one, the one that is just Poser 7 is the new one.
copy your files from the old to the new.
put your Dots directory (if you have one) inside the English directory. I think this may be a change in this version and it seems to be the only thing you have to do diffrent in restoring the settings
My Homepage - Free stuff and Galleries
uli_k posted Thu, 10 July 2008 at 12:31 PM
TygerPurr, thanks a lot for the explanation. In case you want to do this under Vista, the location is c:Users[user name]AppDataRoamingPoser 7
Yes, as stated in the readme, some prefs changed their location: "-Memory dots and custom UI preferences now stored in language-specific sub-directory to facilitate concurrent installation of multiple Poser versions."
uli_k posted Thu, 10 July 2008 at 12:42 PM
zollster, there were problems with Tkinter 8.3 that forced us to update that component. Here's a quote from the readme:
-Updated to Tkinter 8.4. (Windows) NOTE: Please contact script developer if compatibility issues with Tkinter are encountered."
It could be that Occlusion Master and Unimesh Realism Kit use this component for their user interface and are affected by the update.
zollster posted Thu, 10 July 2008 at 12:58 PM
MaskimXul posted Thu, 10 July 2008 at 1:05 PM
Quote - MaskimXul, what platform are you on? Mac or Windows?
Windows, Running Vista.
I dug around and figured it out. I think.
In C:UsersUSERAppDataRoaming I found the two folders that Tyger_purr mentioned,
the newly created one, and the old one.
JIC I messed up, I copied the new one elsewhere.
I copied the info from the old to the new, seems to be running ok..
3-DArena posted Thu, 10 July 2008 at 1:20 PM
Quote - I just noticed another long-needed change that isn't listed in the
readme for the SR. The title of the PZ3 now appears on the top
bar of the application, where it's more readable and more expected.Good job!
Uhm I've always had the pz3 name there?
edit, Oh now I see it in your pic on the application window - well that is handy
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
ockham posted Thu, 10 July 2008 at 1:57 PM
I suspect most Poserites don't concentrate on the PZ3, so it's not very important
for them. When I'm doing "serious" stuff, I have to keep lots of PZ3s with names
like "Chapter-2-Lesson-5-Cochlea-Closeup-2-revised.pz3".
Poser's preview window title chopped these off so that I couldn't tell which scene I'm
currently using. The top bar will always show the full filename no matter how long it gets.
moogal posted Thu, 10 July 2008 at 2:02 PM
Hey, they fixed the first bucket render artifact! Maybe they aint such bad folk afterall.
ockham posted Thu, 10 July 2008 at 2:54 PM
By golly, I think you're right. Can't quite prove it, because the artifact was
a slippery and intermittent thing, but I've tried some scenes that I remember
as having weird stuff in the upper left corner, and it's not there now.
bagginsbill posted Thu, 10 July 2008 at 3:23 PM
face_off's stuff is easy to fix, If you're getting an error about an ambiguous parameter name, to do with -col, -column, etc.
There's a line of code that has col=something in a call to the Tk stuff. change it to column=something and it should be fixed.
Darboshanski posted Thu, 10 July 2008 at 3:24 PM
So how is this new SR3 work for Vue users? Is the file system like Poser pro? Vue doesn't play well with poser pro from what I understand.
bagginsbill posted Thu, 10 July 2008 at 3:25 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3257855&ebot_calc_page#message_3257855
The Tk problem showed up in Poser Pro first. Follow the link to see if its the same problem you were having. The linked post has the error message in it. If that's your error message, do the column=0 fix.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
uli_k posted Thu, 10 July 2008 at 3:50 PM
Yes, Poser Pro and Poser 7 SR3 both run on Tkinter 8.4.
Darboshanski posted Thu, 10 July 2008 at 6:12 PM
Quote - Yes, Poser Pro and Poser 7 SR3 both run on Tkinter 8.4.
I am afraid I am a wee bit lost what the blazes is Tkinter 8.4 and how does this relate to Vue?
zollster posted Thu, 10 July 2008 at 6:34 PM
bagginsbill posted Thu, 10 July 2008 at 8:02 PM
Quote - > Quote - Yes, Poser Pro and Poser 7 SR3 both run on Tkinter 8.4.
It doesn't relate - your post got caught in the middle of a thread within the thread, regarding errors with face_off's stuff. Which are now fixed.
Now about Vue .... sorry I don't know nothin' about that :)
Greywolf Starkiller posted Thu, 10 July 2008 at 11:25 PM
Thanks to a quick response, I got the update. :)
I'll hold off installing for the moment though. Just in case.
Greywolf
Tashar59 posted Thu, 10 July 2008 at 11:57 PM
I got it and installed, bit flaky in the material room. Restarted computer and it seems to be running better now. So it might be wise for all to reboot before testing and judging.
I have a dual boot so I have it it installed on both xp32 and xp64. I updated the 32 os. So if there are problems I will still have the good install on my 64 os. LOL Cover my backside more these days than I used to,
sweetpegster posted Fri, 11 July 2008 at 1:51 PM
DefaultGuy posted Fri, 11 July 2008 at 3:05 PM
Hi sweetpegster,
In the Display menu, is Bend Body Parts unchecked? That might be the issue here. Please make sure it's checked and the display issue should go away.
Thanks,
-B
sweetpegster posted Fri, 11 July 2008 at 3:41 PM
Ohhh thank You, thank You. that fixed it. :)
JOELGLAINE posted Fri, 11 July 2008 at 4:07 PM
So far the SR3 is causing my Poser 7 to act weird. The Material room is acting retarded. It's reaction to any clicking is very retarded in time. Before it would respond within 1 to 3 seconds, now it's response is retarded to 15 seconds to 2.5 minutes.
The renders are completely unpredictable. I had a set of renders that I have benchmarked as six hours in Poser 6. The first one ran in about 55 minutes. Hooray for that! The second one, I cut off after 28 hours+ when the progress bar was still at about 80% complete. Boo on that! I removed all the advanced material shaders and it seems to be rendering at some speed now and might actually render in six hours.
Rendering four threads is strange to watch now. Before it would render as normal, now it splits the screen into quarters and render each quarter seperately . Strange but usually gets the job done.
That is ALL the time I've had to experiment with. The renders DO look better, so I can't complain too much so far.
Redoing the preferences was NOT a big deal. Wasn't like rebuilding your house after a flood or something. LOLOLOLOL :lol:
I cannot save the world. Only my little piece of it. If we all act
together, we can save the world.--Nelson Mandela
An inconsistent hobgoblin is
the fool of little minds
Taking "Just do it" to a whole new level!
Conniekat8 posted Fri, 11 July 2008 at 4:16 PM
Hmmm, my P7 has always rendered with screen in quarters... Maybe there's a setting somewhere.
Looks like they fixed one set of render artifacts, and introduced some new ones. Oiii !
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
uli_k posted Fri, 11 July 2008 at 4:41 PM
Quote - So far the SR3 is causing my Poser 7 to act weird. The Material room is acting retarded. It's reaction to any clicking is very retarded in time. Before it would respond within 1 to 3 seconds, now it's response is retarded to 15 seconds to 2.5 minutes.
Do you have an ATI graphics card or chipset? If yes, then please update your graphics driver. If you deleted your preferences during installation of SR3 and the problem appeared, then you might have previously had the workaround for the driver problem enabled that we shipped in SR2.1. You could still do that, but at this point it's better to just get the improved driver from ATI/AMD.
Quote - Rendering four threads is strange to watch now. Before it would render as normal, now it splits the screen into quarters and render each quarter seperately . Strange but usually gets the job done..
Rendering in four threads was always done in four quadrants, no change there. If you had 'Render in separate process' enabled previously, it might have looked like it did it all at once due to how the results are read back.
nruddock posted Fri, 11 July 2008 at 5:10 PM
Quote - Hmmm, my P7 has always rendered with screen in quarters... Maybe there's a setting somewhere.
You have multi-threaded rendering turned on (Edit | General Preferences... | Render tab | Render Process | Number of Threads)
LostinSpaceman posted Fri, 11 July 2008 at 6:02 PM
So Far So Good.
PilotHigh posted Fri, 11 July 2008 at 6:20 PM
Trouble on mac here. Updated to SR3 and renders are crashing where they did not before. Sometimes my undo is greyed out - especially when I really need it! Saving, loading and rendering are all very lonnnnggggg now. It seems to me P7 was like this at the beginning but SR2 fixed it - now we're back to square one.
JOELGLAINE posted Fri, 11 July 2008 at 6:21 PM
NO ATI cards on my render machine. I don't remember if I had ''Render in separate process' checked or not. It overwrote my preferences and didn't back them up.
New problem noted. Random crashes to desktop when deleting props and figures. Sometimes it does crash, sometimes it doesn't. I have yet to determine why the app is crashing when deleting.
My Poser 7 installation had been rock-solid without ANY glitches, or crash to the desktop problems at all. I've read about such from other users, but never EVER had that problem before. I am VERY dismayed to experience such now. As such, I am not a happy customer now. :glare:
akura_ posted Fri, 11 July 2008 at 9:57 PM
Its working great for me as for validating goes. just make sure your not putting in O instead of 0s and use the - to it should work for you guys.
ockham posted Fri, 11 July 2008 at 11:35 PM
Another very important fix that isn't mentioned in the readme:
Posing camera no longer locks up when you change from one figure to another!
ice-boy posted Sat, 12 July 2008 at 12:38 AM
i dont like what i am reading. this service pack should make it better not worse.
Tirjasdyn posted Sat, 12 July 2008 at 1:38 PM
I have the SE version of Poser 7 and my updated downloaded no problem.
Make sure you are using capitols and dashes when you put in the serial code.
mwafarmer posted Sat, 12 July 2008 at 2:42 PM
Quote - i dont like what i am reading. this service pack should make it better not worse.
Don't panic. I downloaded and installed SR3 as soon as it was announced and have been using it heavily with no problems. I'm not sure, but I think it is even rendering faster. If you use face_off's Python scripts, there is a fix for them elsewhere in the forums.
Mike
Greywolf Starkiller posted Sun, 13 July 2008 at 12:36 PM
Hmmm. I think I'll stay away from SR3 for the time being. When I use Poser 7, I use Python
quite a bit. I don't have the time to repair every script that SR3 breaks. Heck, P7 gives me
enough trouble as it is, don't need more. I use it mainly for the Cloth Room, Hair Room and
Rigging. Poser crashes so often and so randomly, especially during renders, I had to shift
to DS just to get renders done. If this was fixed in SR3, that's one big plus, but the Python
thing is a BIG minus, to me anyway. :)
Greywolf
Raindroptheelf posted Sun, 13 July 2008 at 1:15 PM
I had to reinstall Poser after I had installed the SR3.
Suddenly Poser told me that there was an error and it needs to shut down, Textures where not seen, Figure and clothes hair and everyting was just white and only texture was seen after the render.
I have it back now as it was before and all works fine.
Has anyone else this problems after installiing SR3?
Raindroptheelf
ice-boy posted Sun, 13 July 2008 at 1:41 PM
this is the first time in the last 2 years where i read comments like this for SP. to many people ahve problems . this has to be SP problems.
redtiger7 posted Sun, 13 July 2008 at 7:00 PM
Gah! I just installed it and now I can no longer load from the collections folder. WTF??????
Latexluv posted Sun, 13 July 2008 at 7:51 PM
Real Skin Shader python script does not work properly after the update. It now says that there is errors in the python script in several lines. sigh
Weapons of choice:
Tyger_purr posted Sun, 13 July 2008 at 9:30 PM
Quote - Real Skin Shader python script does not work properly after the update. It now says that there is errors in the python script in several lines. sigh
sr3 updated the version of Tkinter.
to fix real skin python, open it up and do a find/replace.
find: col=
replace with: column=
Tkinter is the python user interface that realskin (and several other python programs)
uses. any python script that has buttons and controls similar to realskin may need this same change.
cherokee69 posted Sun, 13 July 2008 at 10:09 PM
I was working on a scene in Poser 7 (stonemason's Backstreets, a couple vehicles, and bagginsbill's shaders). Poser 7 was working fine and rendering with now problems. I downloaded SR3 and installed it...no problems, it kept my preferences and runtimes. I then loaded the scene I was working on and started rendering. Seems slower with SR3 and my processor fan is now running at full speed alot. It didn't do that before I installed SR3.
Anyone have any ideas or thought on this?
Thanks
Latexluv posted Mon, 14 July 2008 at 1:35 AM
**Tyger_purr, okay, I've made that change in the script and resaved it. I'll see if this fixes the problem. Thanks for the suggested fix.
Weapons of choice:
Greebo posted Mon, 14 July 2008 at 2:51 AM
Quote - I had to reinstall Poser after I had installed the SR3.
Suddenly Poser told me that there was an error and it needs to shut down, Textures where not seen, Figure and clothes hair and everyting was just white and only texture was seen after the render.I have it back now as it was before and all works fine.
Raindroptheelf
I had this problem too. The first time it did this I was working on quite a heavy scene so I thought it was maybe too many texture calls. But it happened again on a single clothed v4. The odd thing was that poser loaded all textures -except- the clothing textures on both scenes. I rolled back to 2.1 which has been stable for me.
Raindroptheelf posted Mon, 14 July 2008 at 3:09 AM
Can some one point me to the place at SM to find the 2.1 update?
I want to put it back on, thought I had saved it but had not.
After the SR3 horror I had to reinstall Poser 7 again and need to update.
All I see on SM is the upgrade to Poser 7 pro , the download for SR3 , then update 2.1 but just for Mac. pffffft
Thank you for your help.
Raindroptheelf
Gareee posted Mon, 14 July 2008 at 8:04 AM
Odds are a clean reinstall, and sr3 will get you working perfectly.. and there are a LOT of fixes to things like the hair and cloth room, how poser actually works n such, that are well worth the upgrade hassle.
I've installed the P7sr3 in beta form about 30 times now, and not once had any issues at all.
evilded777 posted Mon, 14 July 2008 at 4:06 PM Online Now!
Anyone else running 64 bit XP?
I have tried to install SR3 twice now, and when trying to use Python scripts I get an ugly application error that says MSVCR71.dll was unable to load.
Methinks it is part of the C++ redistributable, and it doesn't seem to be getting loaded properly.
ockham posted Mon, 14 July 2008 at 4:33 PM
The MSVCR71.dll isn't part of Poser's own install. Looking at the
main directory, Poser uses MSVCR80.dll, with a date that matches
the original Poser 7. If a script specifically calls for MSVCR71, it must
have installed the dll on its own.
You could try to download MSVCR71 from various places on the web,
then put it in the main Poser folder. These DLLs are available free from
lots of places. Google will show you where.....
evilded777 posted Mon, 14 July 2008 at 5:44 PM Online Now!
Hey there Ockham.
I don't ever recall Poser installing a C++ resditstributable before. Daz Studio runs that installer as well, and has a version of that DLL (its the only place it shows up on my machine).
I'm concernced that that might not be the only thing missing.
nruddock posted Mon, 14 July 2008 at 5:57 PM
I'm betting that tcl84.dll and tk84.dll have been compiled against MSVCR71.dll and not MSVCR80.dll, just like the P7SR2.1 and before tcl83.dll and tk83.dll are compiled against msvcrt.dll
This sort of thing can lead to instability, especially with memory allocation (which Python does a lot of).
evilded777 posted Mon, 14 July 2008 at 7:58 PM Online Now!
Well, copying the file from elsewhere on the pc into the runtimepythondlls folder has solved the issue for the moment.
drifterlee posted Mon, 14 July 2008 at 9:41 PM
I had no problem downloading it from S M, but if your read the info, it only works on a fresh install of P7. I am not reinstalling all that content I have so I guess I'll wait until my next major reformat.
uli_k posted Tue, 15 July 2008 at 12:59 AM
Quote - I had no problem downloading it from S M, but if your read the info, it only works on a fresh install of P7. I am not reinstalling all that content I have so I guess I'll wait until my next major reformat.
Poser 7 SR3 does not require re-installing from scratch. While doing so is recommended if you are experiencing difficulties with your installation that can't be resolved by discarding preferences, in most of all cases installing over an existing installation works just fine. Even if you have to re-install the application, that doesn't necessarily mean you have to re-install all 3rd party content.
uli_k posted Tue, 15 July 2008 at 1:45 AM
Quote - Gah! I just installed it and now I can no longer load from the collections folder. WTF??????
Speaking of discarding preferences... one way of resolving this issue is to delete libraryPrefs.xml in your home directory (C:Documents and Settings[user name]Application DataPoser 7 or C:Users[user name]AppDataRoamingPoser 7 respectively).
If you have a lot of external runtime libraries linked in, or don't want to delete your library preferences for another reason, then you can open libraryPrefs.xml in a text editor and change the location of your main runtime from
<ContentFolder folder="Runtimelibraries" index="0" >
to
<ContentFolder folder="C:Program Filese frontierPoser 7Runtimelibraries" index="0" >
(assuming that's where your Poser 7 is installed and main runtime is located). This should resolve the issue without deleting libraryPrefs.xml.
ockham posted Tue, 15 July 2008 at 11:34 AM
@nruddock: Yup, you're right. A quick view of the tk84.dll code shows a reference
to MSVCRT71.
JOELGLAINE posted Tue, 15 July 2008 at 3:21 PM
I'm on a Dell 1.8 Ghz, with 1 gig of RAM. No ATI cards or such and the Firefly render engine is so slow, it's taking days to finish renders that HAD taken 8 to 9 hours to finish. How do I uninstall the SR3 update? I'm through with it. It's crippled my ability to produced fast renders in a timely manner.
Darboshanski posted Tue, 15 July 2008 at 3:49 PM
Quote - I'm on a Dell 1.8 Ghz, with 1 gig of RAM. No ATI cards or such and the Firefly render engine is so slow, it's taking days to finish renders that HAD taken 8 to 9 hours to finish. How do I uninstall the SR3 update? I'm through with it. It's crippled my ability to produced fast renders in a timely manner.
Well unless things have changed with this update for poser you have to totally uninstall P7 and do a fresh install to get rid of SR3. The SR will not show in add/remove programs in the control panel.
bagginsbill posted Tue, 15 July 2008 at 4:04 PM
Just run the SR2 updater.
JOELGLAINE posted Tue, 15 July 2008 at 5:19 PM
The only SR 2.1 I can find are the French and German. If it changes the language, it might not be worth it. If there is NO alternatives, I'll learn GERMAN instead of keeping SR3 as it is!
After rendering for over 36 HOURS it crashed to the desktop only 75% completed! Oh man, I am so POed about this!
Any English SR2.1 floating out there?
uli_k posted Tue, 15 July 2008 at 6:25 PM
Joelglaine, please contact Smith Micro tech support via my.smithmicro.com/support/index.html, describe your problem and provide your scene if possible. Tech support staff might also be able to help you with an earlier service release.
JOELGLAINE posted Tue, 15 July 2008 at 11:57 PM
I've tried several different scenes and only one out of five even rendered. I already contacted customer service. I have never EVER needed to contact Customer Service to get a previous SR to restore function to ANY software before! In that Poser is crippled right now, I would say I am a disgruntled customer. :cursing:
LazyLeopard posted Wed, 16 July 2008 at 5:25 PM
I'm seeing some marked changes in the rendering in SR3, possibly connected with ambient occlusion, maybe? The most obvious effect I've seen where a water surface intersects a skin surface which has had a shader added using this Unimesh Realism Kit.
JOELGLAINE posted Wed, 16 July 2008 at 6:34 PM
According to Smith Micro iin an official tech support response: "One thing you could try is reducing the irradiance caching down to zero. This shouldn't lower your quality, as the SR3 updater has improved the quality of the renders in general."
LazyLeopard--that might be what you see in your renders.
redtiger7 posted Wed, 16 July 2008 at 6:53 PM
Quote - > Quote - I had no problem downloading it from S M, but if your read the info, it only works on a fresh install of P7. I am not reinstalling all that content I have so I guess I'll wait until my next major reformat.
Last time I reinstalled P7 it overwrote my entire library (deleting all previous content) half the geomotries and many of the textures.
LazyLeopard posted Thu, 17 July 2008 at 2:37 AM
Quote - According to Smith Micro iin an official tech support response: "One thing you could try is reducing the irradiance caching down to zero.
Thanks. I had tried reducing it to 50, and looking closely now I can see a very slight reduction in the over-shaded interfaces, but I'd put it back up to 90 because reducing it increased the render time dramatically. I'll give zero a go, and see whether it improves matters while still rendering in a finite length of time.
JOELGLAINE posted Thu, 17 July 2008 at 3:44 AM
I just finished backing up my runtime, deleting poser, and re-installing it, and uploading SR2.1.
I just reloaded my scene and hope to god to render the bastard before I die from frustration! :cursing: This should have finished by LAST SUNDAY DAMMIT!
WIth SR3 it took 28Hr 40Mn and then crashed to the desktop at the 80% mark. I'm going to start it up and see what happens right now!
Wish me luck.:rolleyes:
Raindroptheelf posted Thu, 17 July 2008 at 4:31 AM
I asked Tech Support at SmithMicro Site for help to get SR2.1 , have not heard anything yet though.
I made a fresh install of Poser 7 and waiting.
SR3 really messed up my Poser which was working fine.
They should take the SR3 off their Site and test it before releasing it.
Gareee posted Thu, 17 July 2008 at 11:21 AM
They did test it.. for about 3 or 4 months, but no one can predict every single hardware and software combination out there.
JOELGLAINE posted Thu, 17 July 2008 at 1:30 PM
Just finished my Render that SR3 had at 28Hrs40Mn.
With Sr2.1 installed it was 5Hrs 22Mins. No crashes to the desktop, no hiccups, no monkey bussines!
If your Poser installation is crashing and shaky BEFORE you install SR3, it may fix a lot of problems. If your Installation is already rock-solid and you're not having problems--I recommend holding off on installation until more beta-testing on it is done.
LazyLeopard posted Thu, 17 July 2008 at 3:56 PM
It certainly has some effect, but it's not the whole story. Here's the same (double-sized) render section with the irradiance cache set to 90, 50 and 0 respectively.
ecccoman posted Fri, 18 July 2008 at 5:58 AM
ecccoman posted Fri, 18 July 2008 at 6:10 AM
Right after I installed SR3 my render times deteriorated from about 3-5 minutes to 30-40 minutes. Naturally, I assumed it was due to SR3.
I was wrong.
My problem had to due with a hair prop which I discovered by trial and error. Once I deleted the hair prop by render times went back to the normal 3-5 minutes. I wish I knew the name of the prop, but I changed it when I loaded it and my runtimes are too much of a mess to search. When I come across it again, I will know it.
In the process of researching I got the following input from SmithMicro
- SR3 should facilitate faster loading and about the same render time. That is my experience.
- Number of runtimes loaded to the library bar should have no impact on render time. Impact on load time is an open question. This has been my experience also.
- Increasing the render threads to match the number of cores was a big help.
- Irradiance caching will have no effect on Poser 7 render time. Apparently, it is related to Poser Pro render time.
Gareee posted Fri, 18 July 2008 at 7:06 AM
Yeah, I'm doing a scene with a nasty hair prop as well. My usual render times with everything cranked are a few minutes.. I'm looking at 5-15 minutes now JUST because of that ONE hair figure!
Multiple overlapping transmaps really kills rendertime.
JOELGLAINE posted Fri, 18 July 2008 at 8:01 AM
That is one of the things I found out through experimentation. Some hairs that had been fine to render in SR2,1 were suddenly 'radioactive' under SR3! Since I have a LOT of hair, I almost exclusively use trans-mapped because it usually renders quicker. Under SR3 that is NOT true. Some render the same, some cripple render times.
Same with some nodes. Reflection raytraced is slow, where the gather node seemed to cripple my machine. (Literally. It hit a patch of Gather and always crashed to the desktop!) Ray-traced glass sometimes rendered slow, or crippled speed or caused crashes randomly.
Since I didn't want to try to re-invent the wheel with SR3, I had to roll back to SR2,1. I'm used to what will do which foible in Poser 7 SR2,1, But SR3 in some ways makes Poser act like a different application altogether,IMO.
Gareee posted Fri, 18 July 2008 at 8:36 AM
Yeah.. it's fixed and works properly now. Your solution is much like peopel hanging on to poser 4 for 10 years after it should be dead n buried.
there were some nasty bugs tiny reported to SM as far as hair rendering and developement , and SM worked REALLY HARD to fix trhings properly.
Rather then a roll back, I suggest an additional poser 7 sr3 install, so you can relearn the proper way to do hair in the fixed P7 sr3 hair room?
That way you have all your older hair you worked on, but can take advantage of the new fixes in place as well.
kuroyume0161 posted Fri, 18 July 2008 at 9:43 AM
Ummm, but he said 'trans-mapped hair' - ala helmet hair, hair prop. How does that work in the Hair Room again? ;P
Quote - I almost exclusively use trans-mapped because it usually renders quicker. Under SR3 that is NOT true. Some render the same, some cripple render times.
off.
-- Bjarne
Stroustrup
Gareee posted Fri, 18 July 2008 at 11:09 AM
kuroyume0161 posted Fri, 18 July 2008 at 11:27 AM
But the quoted inference is obvious: trans-mapped hair DOESN'T render quicker under SR3 (than SR2.1). I've read it about ten times, and, yes, that is the inference. :)
off.
-- Bjarne
Stroustrup
Gareee posted Fri, 18 July 2008 at 11:32 AM
Khai posted Fri, 18 July 2008 at 11:43 AM
you'll be hearing from my Lawyers, Bludsucker, A Chaser and Creep forthwith!
redtiger7 posted Fri, 18 July 2008 at 1:22 PM
Interesting? How does one go about doing that?
JQP posted Fri, 18 July 2008 at 5:57 PM
Quote - you'll be hearing from my Lawyers, Bludsucker, A Chaser and Creep forthwith!
Might I recommend the firm of Dewey, Cheatum, and Howe?
Gareee posted Fri, 18 July 2008 at 8:10 PM
Mark@poser posted Sat, 19 July 2008 at 7:39 AM
Maybe someone said it, but you can turn the raytracing for transmapped hair "off" under its properties, and the render time reduces. I usually do that until the final render, but to me I don't see much difference either way. Maybe some improvement around the edges..
Good luck
ice-boy posted Sat, 19 July 2008 at 8:37 AM
Quote - They did test it.. for about 3 or 4 months, but no one can predict every single hardware and software combination out there.
well here people have more problems then not. which means that something is wrong with the SP3.
people are reinstaling poser because of this. something is 100% not right here.
LazyLeopard posted Sat, 19 July 2008 at 9:14 AM
Quote - people are reinstaling poser because of this. something is 100% not right here.
Folks seem to be in a variety of positions, and I can quite understand why going back to SR2 looks like the best solution for some of them.
I've had one or two scenes that fall into the fourth category, but most of mine fall into the third or second. I want to stick with SR3 if I can, but at the moment it's like trying to paint with a brush which squirts inappropriate splodges onto the canvas apparently at random...
SimonWM posted Sat, 19 July 2008 at 9:22 AM
Does Poser Pro physical version includes a new manual?
Gareee posted Sat, 19 July 2008 at 11:06 AM
Quote - > Quote - They did test it.. for about 3 or 4 months, but no one can predict every single hardware and software combination out there.
People that have issues WILL post, because they are seking solutions.
But people without issues are just working as usual, without reason to post. Thee will always be a few people with some issues with any new program update for any program.
As I've said, theres no way any company can test for every single hardware and every single software solution, and there's never a perfect bug free update for any program from any company as a result.
LazyLeopard posted Sat, 19 July 2008 at 3:06 PM
Quote - People that have issues WILL post, because they are seking solutions.
...though it's hard to know where to post to stand a chance of getting a useful answer. When a thread's more than a page or two long it's increasingly difficult to find useful answers, especially when the thread also fills up with meta-conversation like this. Maybe it's time for a new thread specifically about the effects of the changes between SR2 and SR3...
Gareee posted Sat, 19 July 2008 at 3:15 PM
Well, this thread was originally announcing it's release, and was not a torubleshooting thread at all. Thread drift is commonplace, and people with sr3 will most likely find a solution in an associated thread.
LazyLeopard posted Sat, 19 July 2008 at 4:30 PM
Quote - and people with sr3 will most likely find a solution in an associated thread.
...if they're lucky enough to find the right associated thread in the first place. So far this is the only thread I've found here which seems to be dealing specifically with SR2/SR3 issues in any way at all...
Gareee posted Sat, 19 July 2008 at 4:34 PM
There aren't a whole lot of sr3 threads at all, so there aren;t a lot to choose from.. ;)
Plus Smith Micro themselves have also replied here as well.. when you actually have the guys who worked on it replying in a thread, odds are you'll find the info you need here whenever they pop in again. Good reason to stick around, eh?
LostinSpaceman posted Sat, 19 July 2008 at 6:44 PM
If you have a particular issue that hasn't been discussed you have two choices. Post your issue here and hope that the SM people see and answer it or start a new thread specifically for your issue and hope someone who has the answer in the community will have your answer.
Gareee posted Sat, 19 July 2008 at 6:48 PM
3 choices.. also contact SM direct, which is always the smartest option on new releases.
kuroyume0161 posted Sat, 19 July 2008 at 6:51 PM
Well, the first choice should be to contact SM directly. Secondarily, users can inform each other of their experiences which may help others having similar issues. Any time something doesn't work as expected (whether from the source or the user), the dialog between the company and user should help to resolve the issue or at least illuminate it. :)
off.
-- Bjarne
Stroustrup
vilters posted Sun, 20 July 2008 at 6:34 PM
hey, download went fine, installation went fine, but:
AnAn does not work any more ( none of them)
The hip detafches from the figure and places itself about 3" back.
Also the texture goes missing.
Any sugestions? The rest of the figure is OK, and the problem is not solvable.
Thanks, Tony
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
PatraGr338 posted Wed, 23 July 2008 at 8:55 AM
hmm iam gettings render speed problems too after installing SR3.
Mainly even though ive choosen 4 threads only 2 of my procs are used (using alt-ctrl-del) and only at 15% CPU usage!!! (before i was getting a 90% CPU usage from all procs). I tried playing around with the adaption Threshold and memory limit buffer but very little difference. it takes me now almost twice as long to render O.o !!!
jonnybode posted Wed, 23 July 2008 at 10:51 AM
quote/ AnAn does not work any more ( none of them) / end quote
You scared me a bit there, added my Anan runtime when i saw your post (deleted all prefs in the upgrade) and loaded AnAnR2 (new Judy), worked fine for me.
Sorry I cant give you any solution for your problems with AnAn just wanted to say that the character works ok here even with SR3
The only problem I have is that P7 now have troubles identifying some textures as valid jpg's (textures called on when loading some hair models), when i load the same textures in P5 or P6 they work rigth away.
I do however find the application more stable now as the random crashes are almost gone.
Regards / Jonny
DigitalDreamer posted Wed, 23 July 2008 at 12:53 PM
On the validation issue, if anyone is still having problems, I cut and pasted my serial and noticed that it had picked up a space at the end of the number. This would have led to an incorrect serial as far as the validator is concerned as it views a space as a character.
VegasLarry posted Fri, 01 August 2008 at 7:38 PM
Took my serial ncey, got a nice e-mail from them thanking me for registering.
But....................
Where the H*LL is the link for the SR3 dl?
Dazed and confused, as usual....
All these wanna be web desingers that can't
P.S.
Is this somethig I REALLY want to do?
I am actually haveing very few probs with P7
slinger posted Fri, 01 August 2008 at 7:45 PM
Here's the link to the Smith Micro downloads page, updates are on the right....
http://my.smithmicro.com/downloads/index.html
The liver is evil - It must be punished.
LazyLeopard posted Sun, 03 August 2008 at 3:57 PM
Quote - > Quote - According to Smith Micro iin an official tech support response: "One thing you could try is reducing the irradiance caching down to zero.
Further experimentation has resulted in some improvement. I also learned a few things:- It is entirely possible that the Ambient Occlusion wasn't actually being affected by some surfaces in Poser 7 SR2. That would be consistent with what I say on this image. When it started to work properly in SR3...
Tomsde posted Tue, 05 August 2008 at 7:54 PM
Poser 7 slowed to a crawl with open GL enabled after the update. I did as suggested and updated my ATI video card driver. Now the Poser room works fine, but I'm still having issues with the materials room being very slow unless I switch to SCreed. Anyone else having this problem?
