Subject: Looking like a marble statue?
ockham opened this issue on Jul 21, 2008 · 32 posts
ockham posted Mon, 21 July 2008 at 9:10 AM
Any good tips for making a figure look like a statue?
Specifically the eyes and hair need special treatment, I think ....
the rest is just a matter of color and deleting bump maps.
My python page
My ShareCG freebies
Gareee posted Mon, 21 July 2008 at 9:19 AM
I think RDNA had some great free marble shaders.. grab them and apply them instead of actual character maps.
Load the hair, and then apply the marble shaders to that as well.
if you can grab a freebie pedistal or such, that';ll help sell the "statue" idea as well.
ima70 posted Mon, 21 July 2008 at 9:23 AM
In most cases the stock P4 ugly hairs will look better in statues
markschum posted Mon, 21 July 2008 at 9:30 AM
Remember you will get a break in the texture at each body part. I either use the python demo for unimesh, or export the figure and reload it as a single group . That way the texture flows as though carved from one piece. More important for marble than brass.
ockham posted Mon, 21 July 2008 at 9:35 AM
Exporting and reloading as single group!  Sounds like a good hint.
I've noticed the need to smooth some joints, and that will be
also be easier with the posed model as a single object.
Already decided on a P4 'plastic' hair.
My python page
My ShareCG freebies
Gareee posted Mon, 21 July 2008 at 10:21 AM
and don't forget, in poser you can just adjust the smoothing angle.. try 120%, and work up from there...
bagginsbill posted Mon, 21 July 2008 at 10:46 AM
Do you like this marble? (Click to see full size without jaggies.)
bagginsbill posted Mon, 21 July 2008 at 10:55 AM
Slight different - this time with some Fresnel reflection. Takes longer to render. Which do you want?
ockham posted Mon, 21 July 2008 at 11:04 AM
Can't see much difference ... maybe the first one is better.
My python page
My ShareCG freebies
Khai posted Mon, 21 July 2008 at 11:04 AM
it's not bad, but you may want to put in a control to lessen the amount of veining - if you look at Michelangelo's David, (which is carved from Carrara Marble), you see almost no veining at all.
Acadia posted Mon, 21 July 2008 at 11:31 AM
Mapps has a statue texture for V2 on his site.
http://www.freewebs.com/mapps/
I've been using V3 and the marble texture from this set:
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=2259&_m=d
Here is what that looks like:
http://www.renderosity.com/mod/gallery/index.php?image_id=1681681
bagginsbill posted Mon, 21 July 2008 at 12:15 PM
OK - Of course the colors are adjustable by you, but is this better?
Khai posted Mon, 21 July 2008 at 12:20 PM
getting there.. very much so.. just need to work on the shine now...
I used to work at a marble and granite warehouse.. the shine that most ppl think marble and granite have is infact coatings and polish applied to finish counter tops etc. in it's natural state, it's actually quite matte.. most statues (david etc) are this matte texture.
bagginsbill posted Mon, 21 July 2008 at 12:27 PM
Wasn't sure if we wanted new polished or old rough marble.
Tweaked the Blinn way down and broad now. How's this?
Khai posted Mon, 21 July 2008 at 12:31 PM
oh that's near perfect. the only thing you'd need is some subsurface (Marble is slightly translucent)  but we know how good poser is on that.... I'd stick a fork in that shader and all it done :)
bagginsbill posted Mon, 21 July 2008 at 12:38 PM
I have some SSS in there - I can turn it up. Is the SSS in marble kind of brown like milk does, or is it white?
Khai posted Mon, 21 July 2008 at 12:48 PM
it's white in nature, we're not talking massive amounts tho
bagginsbill posted Mon, 21 July 2008 at 12:59 PM
OK Here's slightly more SSS. SSS removes some of the detail - should I add back in a bit more veining?
obm890 posted Mon, 21 July 2008 at 1:05 PM
Looking good! You might want to pull her eyelashes in with a morph or a magnet. P4 cow-turd hair will look great on this.
ockham posted Mon, 21 July 2008 at 1:18 PM
Sort of like a Geico ad.  Bagginsbill is a Real Shader Expert, so we'll
bring in a Real Marble Man to help.
Nice thing about these forums........
My python page
My ShareCG freebies
bagginsbill posted Mon, 21 July 2008 at 1:36 PM
Cow poop Poser 4 hair, and a real Venus de Milo.
There's AO in the shader, and I got an artifact on the statue. You may have to mess with ray bias.
I'll upload the shader shortly.
bagginsbill posted Mon, 21 July 2008 at 1:44 PM
Attached Link: Marble Shader
Here ya go.
ockham posted Mon, 21 July 2008 at 2:23 PM
Thanks!  Got it DL'd, will give it a try.
My python page
My ShareCG freebies
pakled posted Mon, 21 July 2008 at 2:55 PM
here's an alternate.
Download the Free Bryce
Go into Poser. Export whatever character you have, into Bryce.
Start up Bryce
Import object
Ignore all requests for textures.
Use Bryce mats...;)
well, it would work...;)
Jules53757 posted Mon, 21 July 2008 at 3:19 PM
But whats about the way back to Poser?
Ulli
Acadia posted Mon, 21 July 2008 at 4:01 PM
Whee! Thanks!
geoegress posted Mon, 21 July 2008 at 5:35 PM
My statue pic. (full size is clearer)
http://www.renderosity.com/mod/gallery/index.php?image_id=1502150
ockham posted Mon, 21 July 2008 at 10:22 PM
Finally, here's my result.  The pose was rather tricky, because Judy's shoulders made an unnatural crease; had to 'objectify' the figure and then partly rebuild the shoulder area.   It's fairly satisfactory now, but still wants more tweaking.
This image is with the default 'dull white' marble texture.
My python page
My ShareCG freebies
ockham posted Mon, 21 July 2008 at 10:23 PM
And this image, from a different angle, is with Bagginsbill's veined marble.
My python page
My ShareCG freebies
ockham posted Mon, 21 July 2008 at 10:35 PM
And here she is in a proper setting.
My python page
My ShareCG freebies
Winterclaw posted Tue, 22 July 2008 at 1:45 AM
Not bad, that's kind of nice.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Porthos posted Tue, 22 July 2008 at 12:13 PM
Thanks for sharing the shaders BB! :)
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
