nikkio3000 opened this issue on Jul 27, 2008 · 8 posts
nikkio3000 posted Sun, 27 July 2008 at 11:23 PM
Deep Futomaki pants for V3 to fit on A4 correctly. i tried colthes converter 3.2(the latest one) and it sorta did the job pretty good , i followed a tutorial called : Tutorial: Converting Clothes to Aiko4 using Clothes Converter which was awesome but the author used Victoria 4.2 for the example , so my final result after trying that is major gaps around the entire waist line and poke thru in the back , and even though the bottom of the pants legs are long sigh i love them they are a little too long for A4 legs, i tried to manually tweak it with the Poser's taper and various scaling etc , i just can't get it ..........and i am stll a novice does anyone know any clothes coverter settings to fix this and any other info is sooooo welcomed :-)
Paloth posted Sun, 27 July 2008 at 11:52 PM
Why not buy Wardrobe Wizard? It can put the figure morphs into the clothing files along with 'adjustment morphs" that can shorten the legs or fix poke through.
nikkio3000 posted Mon, 28 July 2008 at 12:00 AM
cool! i wish i had tried that first will look into it :-) thankie! ops do u have a link to it?
Paloth posted Mon, 28 July 2008 at 12:07 AM
Click here
nikkio3000 posted Mon, 28 July 2008 at 12:46 AM
hmmmm a bit pricey for me right now it's like 59 dollars :-0 Anyone have ay other suggestions?
modus0 posted Mon, 28 July 2008 at 4:20 AM
Attached Link: CrossDresser
You could try CrossDresser. The base program is free (and allows converting *from* any figure), while you only buy modules for figures you want to convert to.Haven't tried it myself (got Wardrobe Wizard 2, does a good enough job in 90% of the cases), but the gallery of converted clothing for CrossDresser looks pretty good.
dlfurman posted Mon, 28 July 2008 at 9:33 AM
Uh....you could try two conversions.
V3 to V4.2, then V4.2 to A4.
space
dbowers22 posted Mon, 28 July 2008 at 11:51 AM
Quote - hmmmm a bit pricey for me right now it's like 59 dollars :-0 Anyone have ay other suggestions?
I've been using Crossdresser 3.0 and it works great.
The clothes fit right and it transfers all the morphs,
or just the morphs you want transfered.
The base program is free. It will convert any
clothing item from any figure, but to convert to
a figure you need to buy a module for that figure
Each module is $9.00 (US). So if you only want
to convert to Aiko 4.0, you only need to buy that
module, and you can convert any clothing item
from any character to fit Aiko 4.0.
