Philywebrider opened this issue on Jul 31, 2008 · 4 posts
Philywebrider posted Thu, 31 July 2008 at 9:50 PM
I downloaded some actions that were for CS2. I have CS3 extended. When I yry to play I get a window that says it can find "curves" or whatever operation is required, then stops. What am I doing wrong. Won't CS2 actions run in CS# extended?
retrocity posted Sun, 03 August 2008 at 11:52 PM
they should work but if the menu choice has changed places it will get confused.
step through the action and try to bypass the offending step...
Philywebrider posted Mon, 04 August 2008 at 8:12 AM
I tried that, as I went through each steo, awindow poped up and said it couldn't find each and every step.
dreamer101 posted Mon, 04 August 2008 at 9:16 AM
A good action would have proper warning popups. Many actions require you to make a selection first. If you didn't make a selection it would cause all the rest of action to fail. Something like this could be the problem.
