Forum: Carrara
Subject: Need help with mechanical animation
tkane18 opened this issue on Aug 01, 2008 · 10 posts
tkane18 posted Fri, 01 August 2008 at 11:28 AM
I am trying to put together a small animation of some linked mechanical parts but I don't know where to start in terms of the animation tools that should be used.
To start off simple, I want to take a disc (or gear) that rotates and has a vertical shaft attached.  The shaft should raise and lower as the disc rotates.
I just need someone to point me in the right direction.
Thanks.
noviski posted Fri, 01 August 2008 at 11:33 AM
May I suggest the Cognito plugin, from DCG:
http://www.digitalcarversguild.com/plugin.php?ProductId=6
Cheers.
MarkBremmer posted Fri, 01 August 2008 at 12:08 PM
 If you want direct, mechanical interactions, Cognito will prevent you dying a slow death by keyframing.
faba posted Fri, 01 August 2008 at 1:07 PM
Hi Tkane,
would something like this be enough? It's set without any plugin.
For a simple animation like this it's OK, but if you have something more complex
I think the setting will be much harder.
tkane18 posted Fri, 01 August 2008 at 1:24 PM
Thanks for the input, guys.
Faba,
That's exactly what I was trying to do.
So what's the secret?
50parsecs posted Fri, 01 August 2008 at 1:40 PM
That's a pretty good mechanical linkage you've got going there Faba. You could probably even use something similar for a very basic steam locomotive animation. Cognito does make life a lot easier for rigging up more complex linkages.
faba posted Fri, 01 August 2008 at 1:42 PM
Another more simple example, I'll upload the file, so you can see it on your own.
Basically it's 2 chains that are connected at the white and the black objects.
I'll name the objects with their colors, because I think it makes it easier to understand:
Orange = rotating disk with spin modifier
White = parented to orange
Green-Blue-Black = IK-chain
Green = Slider, free in the z-axis, locked in x and y-axis
Blue = parented to Green, Ball joint with only 1 free axis (y)
Black = parented to blue, tracking white - full constraint (it's just there to follow white)
Here is the file:
www.evajoe.homepage.t-online.de/mechanics2.rar
Edit: typo
bwtr posted Fri, 01 August 2008 at 9:25 PM
http://www.sparrowhawke3d.com/Sparrowhawke3DPlugins.html
Some free plugins here that can add to workflow abilities also.
bwtr
Miss Nancy posted Sat, 02 August 2008 at 2:45 PM
excellent work, faba!
tkane18 posted Tue, 05 August 2008 at 8:33 AM
Thanks everyone.
