hijend opened this issue on Aug 16, 2008 · 4 posts
hijend posted Sat, 16 August 2008 at 10:09 AM
**Is there away to make the limitations default?
for example.. if I try to use a dial on Vicki 4 head.. (mouth size) and I use the dial.. it always goes back a default max.
anyway of making no limitation?**
dorelia posted Sat, 16 August 2008 at 10:26 AM
Don't know a way that works for all morphs at once, but you can adjust single morphs.
Click the arrow on the right next to the morph you want to change. Choose settings... and adjust the Max Limit.
ockham posted Sat, 16 August 2008 at 10:32 AM
These changes will not be permanent. If you want the figure to have
increased max permanently, you'll have to resave the figure under a new name.
hijend posted Sat, 16 August 2008 at 10:45 AM
Ok thank you very much.. greatly appreciated.
