Subject: Ultimate Wings help
hazawak opened this issue on Aug 16, 2008 · 6 posts
hazawak posted Sat, 16 August 2008 at 8:03 PM
Hi all;
I have a dilemma with Sharky's Ultimate wings. I wrote Sharky about it weeks ago, but have not heard back. I'm hoping someone knows a fix so I can get back on track and effect such repairs in the future if  this weird problem with any other figure/ prop happens again.
The problem is that the feathers on one side, lets say the left side will be bright as if I have a light on it, but the lower feathers are dark. And on the right wing, the opposite is true, the most of the feathers will be dark but the bottom row will be bright.
I've experienced it in Poser 6, 7 and Pro. I'm using this in an animation, so post work is not much of an option. Hopefully a sample picture is attached. These wings pose great and I like them more than the Angelya series. But if I can't get color consistency, I need to move on to something else.  I've tryed adding in lots of lights which, of course, wrecks the scene a bit. And I've played with swapping UV and VU in the properties. I'm not sure what they do actually, but I was testing for a way to invert the map in a vain attempt to understand how the feather groups are being illuminated/ shaded.
So, is there something I can do to the CR file? I'm just above a novice at Poser but always willing to get under the hood.
I am open to very good wings that can be posed with multiple verticies, as I don't want to create a flat looking flap.
Many thanks for any insight you can offer.
-patrick
Acadia posted Sat, 16 August 2008 at 8:27 PM
It's probably a "normals forward" issue.  We had a similar thread about Angelyna Wings
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2497498&page=1
If  you use Poser 6 or Poser 7, you can easily turn on normals forward in the material room. Just click on the material room tab, and in the large "Poser Surface Node" put a check mark in the box at the bottom that says "normals forward".  Do that for each material zone of the wings.
If you use Poser 5, the method is a bit more complicated in that you have to do it manually instead of just checking a box.  The details of how to do that can be found in the thread above.
hazawak posted Sun, 17 August 2008 at 1:15 PM
Acadia, you are MAGNIFICENT! A true miracle worker. That worked. I've been trying on and off for months to fix this issue (including trying to analyze the CR files to dicern the problem. You've saved me huge headaches, as I already have a few animations samples using the wings and I really wanted to keep using them.
I'm having trouble posting in the pictures to show the difference, but I can at least get 1 snapshot in.
In Poser Pro, it was very much as how you said it was in the other thread for Angelya wings. For anyone else who lands on this thread, here is the process.
  1. Select the Ultimate Wing(s) and go into the Materials Room.
  2. Make sure you are in the Advanced tab.
  3. At the bottom, just above the feathers picture, you will see a Normal_Forward option with a checkbox. You'll need to go into every feather group and check this Normal_Forward option.
  4. Make sure to do this for both the left and right wings.
And viola, the wings will look as they are supposed to!
hazawak posted Sun, 17 August 2008 at 1:16 PM
Before Normals forward
hazawak posted Sun, 17 August 2008 at 1:17 PM
After Normals forward
Acadia posted Sun, 17 August 2008 at 5:11 PM
Glad that was the solution :)
Here is a script for Poser 6 that allows you to turn on normals forward for all material zones in the scene with just the click of a button.
I usually turn it on regardless of whether it's needed or not.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3171627&ebot_calc_page#message_3171627
