billythekid opened this issue on Aug 17, 2008 · 12 posts
billythekid posted Sun, 17 August 2008 at 11:55 AM
is it possible to render two sides of clothing, for example, using only the preview renderer.
HOW DO I GET DOUBLE-SIDED RENDERS IN PREVIEW using poser 6?
Is it possible...I thought I did it in the past reversing the normals but can't remember what I did.
thanks in antisipation....billythekid
ockham posted Sun, 17 August 2008 at 12:01 PM
If you need to see both sides for adjustment and setup, try using one
of the Wireframe display modes.
billythekid posted Sun, 17 August 2008 at 12:36 PM
not for adjustment okham..I want the inside of the tunic rendered.
billythekid posted Sun, 17 August 2008 at 12:41 PM
skirts and tunics etc
billythekid posted Sun, 17 August 2008 at 12:51 PM
I am trying to attach a picture but..... no joy
billythekid posted Sun, 17 August 2008 at 1:08 PM
Conniekat8 posted Sun, 17 August 2008 at 1:45 PM
Poser does not have the ability to display back faces in preview. It'll render them in final renderings, but will not display them in preview.
Is there a specific reson you want to see them in a preview, other then it being very annoying to not see the back sides?
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
billythekid posted Mon, 18 August 2008 at 9:17 AM
I think personally that the preview renders have a freshness all of their own and also it's the speed.
Pity their render wasn't as good as Max. I use both and I find it a pain as I usually build the same models in each program for different reasons.
Max for adjusting vertices and renders and poser for speech, expression, model manipulation, clothing and all Daz has to offer.
I wish there was a program that encompassed all of these........You don't know of one do you?
Cheers billythekid
billythekid posted Mon, 18 August 2008 at 9:33 AM
walla
billythekid
crocodilian posted Mon, 18 August 2008 at 1:37 PM
Quote - I just found a way to do it.......... 1 I opened another (cuirass) tunic
2 hid the parts I didn't want.
3 reversed the normals
4 conformed itwalla
billythekid
This is a very useful trick. Poser's Preview Renderer is now very good, IMO, it often gives me what I need. Just remember that you can texture the reversed surface differently-- this will give you a cloak interior which is different than the cloak exterior; in the case of the Roman tunic, it looks like you're getting interior textures correctly from the UV mapping, but this won't always be the case
billythekid posted Tue, 19 August 2008 at 4:08 AM
What is the other way crocodilian?.......I'm very interested.........as I might also use a cloak.
Billythekid.
Conniekat8 posted Wed, 20 August 2008 at 1:14 PM
Quote - I think personally that the preview renders have a freshness all of their own and also it's the speed.
Pity their render wasn't as good as Max. I use both and I find it a pain as I usually build the same models in each program for different reasons.Max for adjusting vertices and renders and poser for speech, expression, model manipulation, clothing and all Daz has to offer.
I wish there was a program that encompassed all of these........You don't know of one do you?Cheers billythekid
I can't tell for sure if it has everything you ae looking for, but have you tried cararra?
Clever cheat on the backfacing issue!
yurs?
BadKittehCo
and product support
