vxg139 opened this issue on Aug 21, 2008 · 11 posts
vxg139 posted Thu, 21 August 2008 at 7:16 PM
Also, whilst on the subject, would you guys recommend using V3 or V4? I ugess what I am gettign at is everything being equal (body morphs and textures to be more specific) which model uses more memory?
as always... thank you for your help and insight.... :c)
Cheers
vxg139
lesbentley posted Thu, 21 August 2008 at 10:03 PM
Try this pose file. It should unhide the scale dials for the currently selected actor. After applying the pose you will probably need to select something else then reselect the actor in order to refresh the parameters pallet.
//ShowScaleCURRENT.pz2
version
number 5
actor $CURRENT
channels
propagatingScale scale
hidden 0
propagatingScaleX xScale
hidden 0
propagatingScaleY yScale
hidden 0
propagatingScaleZ zScale
hidden 0
scale Scale
hidden 0
scaleX xScale
hidden 0
scaleY yScale
hidden 0
scaleZ zScale
hidden 0
P.S. A few weeks ago I had a pose file to unhide all the scale dials in V4, but a HDD crash wiped it out, and I haven't had time to remake it :(
vxg139 posted Sun, 19 July 2009 at 7:47 PM
**A while back, lesbentley developed this cool pose file that would unhide scale dials for V4.... Would you happen to know if there is a simialr code that would unhide "Trans x, Trans y and Trans z" dials? when I select the V4 Eyes (e.g. reye)... I don't see the Trans. dials...
Thanks for your help...
Cheers
vxg139
DarkEdge posted Sun, 19 July 2009 at 10:26 PM
Open the CR2 with WordPad and work your way to the eye actors, then change hidden to 0.
vxg139 posted Sun, 19 July 2009 at 10:37 PM
DarkEdge,
thank you for the heads up.... will try it now....
Cheers
vxg139
vxg139 posted Sun, 19 July 2009 at 11:47 PM
It looks like editing the cr2 file does the trick..... Unfortunately, it seems to be character specific... Would you (or perhpas one of the forrum members) happen to have such a pz2 file that unhides trans dials...?
Cheers
vxg139
vxg139 posted Mon, 20 July 2009 at 12:54 AM
never mind, just edited the original PZ2 file and seems to work!! For those of you who might be interested, here is the file...THe original credit goes to lesbentley of course for being such a wizard.... :c)
version
number 5
actor $CURRENT
channels
translate Tran
hidden 0
translateX xTran
hidden 0
translateY ytran
hidden 0
translateZ ztran
hidden 0
DarkEdge posted Mon, 20 July 2009 at 6:08 PM
Shhhhh!
Don't say that about Mr. Bentley, the demons of Mordor will find him!
vxg139 posted Mon, 20 July 2009 at 6:57 PM
LesBentley, is definitely one of my old time HEROES!! :c)... There I said it!! :c)
lesbentley posted Sat, 22 August 2009 at 6:19 PM
Quote - LesBentley, is definitely one of my old time HEROES!! :c)... There I said it!! :c)
LES PUFFS OUT CHEST, STICKS NOSE IN AIR, TRIPS OVER CARPET
I now have a freebie at sharecg.com that reveals the translate dials in V4's eyes, in the eyeBrow actor, and reveals all the scale dials.
vxg139 posted Sat, 22 August 2009 at 7:56 PM
Thanks for the heads up THE "lesbentley"!!! :c) .... just downloaded the file.... :c)
you are truly a wizard.... and can't thank enough for your pz2 file..... it has opened up endless opportunities for me to test out.... :c)
Cheers
vxg139
