Forum: Vue
Subject: Strange hair render
Stan57 opened this issue on Aug 22, 2008 · 5 posts
Stan57 posted Fri, 22 August 2008 at 11:22 AM
I an useing the render studio for vue 6 all default setting rendered on superior,1024X768 and the hair is comming out like below. Any suggestions?
Thanks in advance
Stan57
Jack Of All Trades Master Of None
bruno021 posted Fri, 22 August 2008 at 1:34 PM
Looks like the hair material has reflections applied, can you check? If so, take it back to zero and see if it gets better. I assume this is not dynamic hair, otherwise, the fix is different.
garyandcatherine posted Sat, 23 August 2008 at 2:26 AM
Well from the postage stamp sized render, it either looks like a: you have reflection added, b: too much highlights, or c: no trans mapping.  It's soooo hard to tell.
-Timberwolf- posted Sat, 23 August 2008 at 9:05 AM
I know this from Cinema4D .I fix it there in the material manager by changing from "anti 1" to "mip mapping". Maybe you will find something similare in vue.
AboranTouristCouncil posted Mon, 01 September 2008 at 7:23 AM
I use the settings pretty much as suggested by this site: http://www.phg-art.ch/?lang=en&page=tutorialshow&tutorial=vue6instyle
Really does a good job with Poser Hair
...Insert some witty or thought provoking comment here...
