adh3d opened this issue on Apr 17, 2001 ยท 4 posts
adh3d posted Tue, 17 April 2001 at 3:13 PM
I make an object in Truespace, import it to bryce and put in it the texture, then, i have an object in bryce with textures, Can i export that object to use it in other 3d programs? I think no, but ....
Flickerstreak posted Tue, 17 April 2001 at 6:35 PM
Nope. Bryce will export geometry only for imported models. You can export a textured terrain or lattice, though.
EricofSD posted Tue, 17 April 2001 at 10:54 PM
You can save that object in your object direcory as an .obj and then export it as a single .obj However, unless you find a program that recoginzes Bryce proprietary obj's, you're out of luck.
Flickerstreak posted Wed, 18 April 2001 at 3:29 PM
those are not .obj models: they are .obp Bryce preset files, and no other program can read them. They are only used for transferring objects between Bryce files, and storing libraries of objects for use within Bryce only. The specification for those files is not published, so no one can read them.
