Subject: conforming hair from other figures on V4?
blaack-widow opened this issue on Aug 31, 2008 · 20 posts
blaack-widow posted Sun, 31 August 2008 at 11:05 PM
anyone know if it is possible to use Sydney_Style2 G2 hair on Vicki 4? try as I may it wont conform correctly. and setting head as the parent also doesnt work. conforming seems to work but when you move vicki the hair doesnt follow so well. I love this hairstyle so I am trying to find a way.
anyone?
thank you in advance!
Acadia posted Sun, 31 August 2008 at 11:35 PM
Try using "Object" in the top menu and "Change Parent" and pick V4's head.
shuy posted Mon, 01 September 2008 at 3:21 AM
Most Sydney conforming hairs have mesh on neck bone and head is empty bone without any obj.
It works best when you open hairs from library, open joint editor window and copy center setting from V4 neck and head bones to hairs bones.
Later using grouping tools "select all" hairs and create prop. Fit this prop as well as possible to Victoria head. If looks good, select hairs with fixed joints, select neck (or head if hairs are on head bone) and "replace body part with prop"
Acadia posted Mon, 01 September 2008 at 10:25 AM
Huh?:blink:
elzoejam posted Mon, 01 September 2008 at 11:06 AM
Hair is easy to refit. Don't conform! Bring hair in, use the x-y-z dials to move it into the right spot and resize it, then parent.  Does that help?
-Sarah
blaack-widow posted Mon, 01 September 2008 at 2:25 PM
conform does nothing. and parenting doesnt work right. it still floats off the head slowly as you move vicki. the neck and hair post sounded true but confused the heck outta me lol.
shuy posted Mon, 01 September 2008 at 4:38 PM
:) Sorry for my English I'll try to explain with pictures. I'm not sure what Sydney hairs you use and here I use Jessi Kozaburo hairs.
  1. Load Hairs and Vicky - do not conform any figures atm.
shuy posted Mon, 01 September 2008 at 4:45 PM
2. Using scale, translate and morphs fit hairs to Vicky head and shoulders. Translate y, z must be use on "body", because neck and head have this parameters hidden.
shuy posted Mon, 01 September 2008 at 4:52 PM
3. Select hairs - in the window you should notice that "neck" is selected. Using grouping tool create prop. Hide it for a while switching off "visible" option.
shuy posted Mon, 01 September 2008 at 4:58 PM
4. Adjust hair figure bones to Vicky bones. Use joint editor window.
shuy posted Mon, 01 September 2008 at 5:01 PM
5. All body parts must have the same parameters as Vicky body parts. Hidden parts as chest, collars and head MUST be adjusted as well.
shuy posted Mon, 01 September 2008 at 5:05 PM
6. Make generated prop visible and replace "neck" with this prop. On picture original hairs are texture shaded, figure is restored to default, but body parts are adjusted to V4. Prop is visible as a wireframe
shuy posted Mon, 01 September 2008 at 5:11 PM
7. Conform hairs to figure. If they are deformed it means that unvisible body (for example chest) part was not adjusted well. This kind of hairs still have all morphs as original hairs. If you are not satisfied with results come back to pt. 4 and 5 and adjust bend, side-side and twist parameters as well, remember about inner and outer mat spheres and bulges. Good luck
jartz posted Mon, 01 September 2008 at 7:01 PM
Bookmark.
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Jestertjuuh posted Mon, 01 September 2008 at 7:08 PM
and marking the book.....aka.....bookmark
I am not a complete idiot, some parts are missing :)
To go to my home page, click the banner below.
Check my freebies on a regular base, click the banner below.
kobaltkween posted Tue, 02 September 2008 at 8:52 AM
pardon, but how do you find out the figure's JP settings?
chriscox posted Tue, 02 September 2008 at 12:24 PM
Quote - pardon, but how do you find out the figure's JP settings?
To open the Joint Editor select Window from the Main Menu then select Joint Editor.
Chris Cox
blaack-widow posted Tue, 02 September 2008 at 8:54 PM
drapak12
it worked perfect! thank you so much for taking the time to explain as you did.
many thanks again!
vholf posted Sun, 14 December 2008 at 11:10 PM
Thanks!
bookmark
blaack-widow posted Mon, 15 December 2008 at 4:45 PM
yes thank you ONCE AGAIN! you provided the first instructions I had that worked for me before **drapak12.
thanks to you again for taking the time to post this again, looks like you helped more then just me =)
