bwtr opened this issue on Sep 02, 2008 · 6 posts
bwtr posted Tue, 02 September 2008 at 2:05 AM
Any help appreciated.(I have advised DAZ)
Brian
bwtr
bwtr posted Tue, 02 September 2008 at 2:12 AM
bwtr
faba posted Tue, 02 September 2008 at 3:51 AM
Hi Brian,
I am sure you already tried the usual things like
What happens when you change Carrara to Window Mode and then change the size of it's window to very small, so the tool bars are forced to be rearranged?
I guess the black line is the handle of the VM selection tool bar.
What happens when you drag it somewhere else?
bwtr posted Tue, 02 September 2008 at 7:54 PM
Thanks Faba
Yes, I had tried all those things.
That "remains" of thw VM selection tools won't accempt clicking on or moving.
Brian
bwtr
bwtr posted Wed, 03 September 2008 at 9:06 PM
faba
All fixed
Thanks for the help.
I had not tried the reset preferences in the the reload.
It worked!
No idea why it should not have worked originally?
Brian
bwtr
fpfrdn3 posted Tue, 09 September 2008 at 2:14 AM
Hi bwtr,...Im guessing the "Motion Path" function icons are conflicting with the Modeling Room VM selection modes icons.
When shutting Carrara down after using a Motion Path object, then running Carrara again, the VM selection modes icons display wrong or go partially missing. The VM selection modes icons and Motion Path icons, seem to be the same movable area.
The only way I can get them back is to Reset Preferences,...or as a workaround, move(or undock) the icons prior to the issue, then shutdown Carrara(but have the preferences written down somewhere just in case). Im guessing this is a bug with the icons preferences maybe? Anyone else?
