Forum: Carrara
Subject: Easy underwater scene set-up
MarkBremmer opened this issue on Sep 05, 2008 · 18 posts
MarkBremmer posted Fri, 05 September 2008 at 6:26 AM
 Hi everyone,
Creating underwater environments is really easy in Carrara. However, the questions about how to do it pop up regularly. I've put together  a video tutorial about how to do it here
Have fun!
Mark
GKDantas posted Fri, 05 September 2008 at 7:21 AM
You did again!! Thanks Mark!
Follow me at euQfiz Digital
bwtr posted Fri, 05 September 2008 at 7:54 AM
Brilliant Mark. Thanks. Brian
bwtr
hardtwist posted Fri, 05 September 2008 at 11:29 AM
Thanks Mr Bremmer. Excellent.
Jim
50parsecs posted Fri, 05 September 2008 at 1:51 PM
Sweet! This is great timing Mark; I was just working on a coral reef scene and any information to make it better is much appreciated.
SimonWM posted Fri, 05 September 2008 at 3:30 PM
Thank you so much as a Carrara newbie I found your tutorials very helpful. May I suggest a tutorial on setting up IK on a generation 3 DAZ model and making a walk cycle and saving it as a nonlinear animation clip. I'd be interested in that.
Xerxes0002 posted Fri, 05 September 2008 at 6:14 PM
Thank you very much!
Milo
bwtr posted Fri, 05 September 2008 at 8:41 PM
Simon
Have a look at Marks Carrarra 5 or6 tutes----
http://www.markbremmer.com/3Bpages/carrara6Pro.html
Brian
bwtr
SimonWM posted Sat, 06 September 2008 at 5:00 AM
Thanks Brian. I have the Lynda.com Carrara 5 tutorials but they don't go that deep (walk cycles) nor they use the DAZ human figures which is what I'm interested in animating in Carrara.
Miss Nancy posted Sat, 06 September 2008 at 12:10 PM
o.k., thx fr the excellent tutorial, mark.  after the last step I couldn't
see the floaters on my monitor, but I reckon they'd be easy to see in full-res.
MarkBremmer posted Sat, 06 September 2008 at 3:13 PM
 Here's a render from the file I was using. Floating junk!
bwtr posted Sat, 06 September 2008 at 8:01 PM
Simon
Marks tutorials are different to any from Linda.com ones!
Between Marks tutorials, and the now excellent  Carrara Help manual, you should find animation of stuff pretty simple---well as much as it can be..
Brian
bwtr
ren_mem posted Sat, 06 September 2008 at 10:03 PM
You may find these also useful.
http://forums.polyloop.net/carrara-tutorials/15432-basic-nla-c6.html
http://forums.polyloop.net/carrara-tutorials/5004-c5-rigging-skinning-bones-setup.html
No need to think outside the box....
    Just make it invisible.
hardtwist posted Sat, 06 September 2008 at 10:43 PM
This was done with C6 Pro (ocean prop) version. Can this be done with the none Pro C6?
Jim
50parsecs posted Sat, 06 September 2008 at 11:12 PM
Maybe a displacement map applied to a plane could substitute for the ocean primitive.
bwtr posted Sun, 07 September 2008 at 12:03 AM
There was a movie tute that used to come with Carrara (3?--4?)  (A fish swimming around?)and there WAS a tute, ? by Mark either on the Eovia site or in one of the 3dXtract enzines!
Brian
bwtr
noviski posted Fri, 12 September 2008 at 1:55 PM
SWEEEEET! Thanks, Master Bremmer! :D
For those who wants a caustics maps, here's a very usefull and free old app:
http://www.dualheights.se/caustics/
Caustics Generatos can create even a animated sequence, maybe could create some displacement map also.
Cheers! ;)
50parsecs posted Fri, 12 September 2008 at 2:13 PM
Yup, you can use the caustic generator to make a looped animated gel, and it works pretty well for making an animated displacement map too!
