Forum: Vue
Subject: Aircraft Metal Shader in Vue.
PowerJet opened this issue on Sep 06, 2008 ยท 4 posts
PowerJet posted Sat, 06 September 2008 at 9:31 PM
Hi Friends,
I have modeled a Spitfire and painted the textures but I am strugling with metal shader in Vue,with all my attemts I am unable to get a good metal shader material settings?any help or metal available for download or suggestions?
Thanks for the help!
Xpleet posted Sat, 06 September 2008 at 9:41 PM
To create the illusion of metal, make the material about 5-10% reflective and use a high percentage of highlights, you could also create ripples as a bump to make it look like it's been long used.
There are a couple of pre-set metals.
bruno021 posted Sun, 07 September 2008 at 2:17 AM
You can also add a varnish layer on top of your textures, this will simulate fresnel reflections. The varnish material can be found in your "material layers" collection.
timspfd posted Mon, 08 September 2008 at 1:45 PM
There's a slider in the Effects tab for Colors Reflected Light that you will want to play with if you haven't yet.
