Forum: Poser Technical
Subject: Adding morphs to alternate geometry?
maclean opened this issue on Sep 13, 2008 · 3 posts
maclean posted Sat, 13 September 2008 at 10:59 AM
I have a drainpipe prop which uses alternate geometry and I've added 2 sets of morphs to it - 1 set for the regular geometry and 1 set for the alternate geometry. In poser, everything works until I try to resave the prop. If I've used the alt geom dial on the prop, then instead of saving this
prop drainpipe_1
      storageOffset 0 0 0
      objFileGeom 0 0 :Runtime:Geometries:maclean:room creator:drainpipe.obj
it saves this
prop drainpipe_1
      storageOffset 0 0 0
      objFileGeom 0 0
In other words, the geometry reference pointer disappears. This only happens if I've actually used the alt geom dial. If I don't touch it, the prop saves normally.
The alt geom code is fine, and I've changed the order of the channels, placing the alt geom channel above the morphs, among them and below them, with no success.
Any bright ideas?
TIA
mac
