Forum: Carrara
Subject: Big Toon! Pro update
ewinemiller opened this issue on Sep 20, 2008 · 9 posts
ewinemiller posted Sat, 20 September 2008 at 3:22 PM
Hi folks,
The big Toon! Pro update is live. The update is free for existing Toon! Pro or Shader Style customers. Just download from the Toon! Pro product page
http://www.digitalcarversguild.com/plugin.php?ProductId=15
or the links below
Carrara 6.2
PC
http://digitalcarversguild.com/downloads/c6/toonpro.zip
Mac OSX
http://digitalcarversguild.com/downloads/c6/toonproub.zip
Carrara 5.1
PC
http://digitalcarversguild.com/downloads/c5/toonpro.zip
Mac OSX Power PC
http://digitalcarversguild.com/downloads/c5/toonpro.sit
Mac OSX Universal Binary
http://digitalcarversguild.com/downloads/c5/toonproub.zip
Carrara 4.1.1
PC
http://digitalcarversguild.com/downloads/c4/toonpro.zip
Mac OSX
http://digitalcarversguild.com/downloads/c4/toonpro.sit
Here's what's new!
  1. Massive reduction in memory usage, especially for large oversampling/high resolution images.
  2. Control line settings down to the shading domain level.
  3. Apply cel shading to objects with lots of shading domains using just a few clicks.
  4. Draw lines on shading domain boundaries.
  5. Fixed performance issues and bad rendering for lines that extended way off camera.
  6. Render Toon! Pro lines to the alpha channel.
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara and LightWave plug-ins
Miss Nancy posted Sat, 20 September 2008 at 4:48 PM
o.k., thx fr the info, eric.  puting the linework in a separate layer (channel/mask) is definitely
a time-saver IMVHO.
MarkBremmer posted Sat, 20 September 2008 at 7:46 PM
 Nice update Eric. Thanks!
GKDantas posted Sat, 20 September 2008 at 8:33 PM
Well done again Eric!
Follow me at euQfiz Digital
Hoofdcommissaris posted Sun, 21 September 2008 at 8:02 AM
Thanks for the continuing development on your stuff Eric!
Hoofdcommissaris posted Sun, 21 September 2008 at 2:17 PM
Oops. Maybe a bit of development ahead. At home I use Mac OS X 10.5.5 and Carrara 6.2.1
I learn that the ToonPro.mcx file 'failed to load', and after that Carrara crashes. Of course TimeMachine bailed me out and I put the original files back from a couple of hours ago (and works fine again), but something seems not right with the new mcx file...
I hope you can find what could be wrong!
The update sounds like something I'd really like to use!
Kind regards!
Hoof
ewinemiller posted Sun, 21 September 2008 at 2:48 PM
Hoofdcommissaris,
I just double checked the download and it seems to be working here. Can you try downloading and installing it again. The link for OSX and 6.2.1 is
www.digitalcarversguild.com/downloads/c6/toonproub.zip
Make sure you copy the ToonPro.mcx, ToonPro.dat, and ToonPro.txt files to the extensions folder. If that doesn't help, please contact me off list and we'll dig deeper.
Thanks,
Eric Winemiller
whkguamusa posted Sun, 21 September 2008 at 8:49 PM
Thanks for the update Eric.
wayne k
guam usa
Hoofdcommissaris posted Mon, 22 September 2008 at 2:30 AM
Thanks for the respons Eric, I will try again tonight at home!
Maybe I did tick the wrong link and was I screwing up your good work myself...
