Subject: store mannequin
WiNC opened this issue on Sep 20, 2008 · 11 posts
WiNC posted Sat, 20 September 2008 at 10:34 PM
Hi,
I'm trying to find either models, or textures that can make store mannequins. Okay, you would think that while most are trying to make realistic type figures, I'm trying to make realistic looking mannequins and having no luck whatsoever!
I have tried to make my own textures, but not been able to get them working correctly, seem to never be able to get the seemlines matching up correctly.
I know there is the Ball Joint Doll (this isn't what I am looking for however). Basically what I'm trying to do is a store front with mannequins which look at least like mannequins and not just Poser models which have a plastic like texture (ie - seems, and body parts missing etc)
Hopefully someone has either seen a model/texture/or even tutorial around on how to do it succesfully.
Thanks
hborre posted Sun, 21 September 2008 at 7:14 AM
SnowSultan has put out seam guides for much of the DAZ figures.  It's a free download, just visit the site and go to the base figures webpage.  Somewhere on the bottom you'll find the download link.
WiNC posted Mon, 22 September 2008 at 12:56 AM
That is what I was using but still couldn't get the lines for the bump map to work - was trying to do a bump or displacement map which would add the seems in certain locations, but that didn't seem to work - the lines never appeared correctly on the arms of the figures.
I am kinda thinking that maybe a new model might be required where I break off the pieces of the body and then rig them back together...
Thanks for the suggestion.
Cheers
nyguy posted Mon, 22 September 2008 at 7:40 AM
Predatron3DA Had a Free Dress Mannequin over at CP but no longer offered. I would try to contact them from their website. The dress Mannequin was the old kind that you would see up in your grandma's attic
Poserverse The New Home for NYGUY's Freebies
bopperthijs posted Fri, 26 September 2008 at 6:54 PM
There is  Mannequin morph for V4 at RDNA. by Mindvision.
Bopper
-How can you improve things when you don't make mistakes?
WiNC posted Fri, 26 September 2008 at 7:51 PM
That is perfect! Thank you - I totally missed that one and it looks just how I need it to look for the scene!
Thanks!!
WiNC posted Tue, 30 September 2008 at 11:36 PM
Well I looked at it - bought it - and it is pretty good though I am a little disappointed with some of the morphing. But over all, nice work and certainly made me realise that some other things I can do.
Thanks for pointing that out - now I just need to figure out how to do more realistic plastic/plaster type look of the body.
Overall, good buy if you want shop mannequin type stuff.
Certainly will now make the shop fronts look more realistic for the stuff I'm doing.
(btw - I am doing some mock up shop fronts for a friend of mine who has given me a photo of the shop front, which I can then add the mannequins to... and she can then give them to her boss as possible options for a competation. Kinda fun... Trying to make them look at little more realistic for the pictures so it is easier for the boss to "visualise")
Thanks again. If anyone has any idea for plastic etc - that would be great also :)
Tracesl posted Thu, 02 October 2008 at 10:08 AM
You may want to check out the Material Room of Poser, I think but can't remember if there is a plastic material available but you should be able to generate one there.
WiNC posted Fri, 03 October 2008 at 12:02 AM
Been working on it - the big problem is with Mannequin Plastic is that in fact it has very little reflectiveness and does something strange to the light when it hits... Been looking over the real ones and getting something close is proving to be a little on the insane side.
The purchased Mannequin morphs only uses a base colour - but that doesn't really make it look very real against IBL and image.
Still working on it - and will admit after this - I never want to see a mannequin again :D
JOELGLAINE posted Fri, 03 October 2008 at 6:38 AM
Remember to kill the specular in the eyes to convey the lifeless look.
It's easier to take a sample in photoshop  or such and create a mannequin texture by simply using the fill tool and making it square. Apply it and specular,too at 25% or so. Instant plaster painted texture. Plaster doesn't look like skin for one simple reason--it's not translucent, like flesh. It's a solid color.
When you get it they way you want, save it to your materials list and name it as you will, and re-use at will!
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
WiNC posted Fri, 03 October 2008 at 1:57 PM
Okay thanks - I hadn't been using a skin texture and instead was trying to get a material to do what I was trying to do... funny that I hadn't even thought about doing it through a texture.
Will give that a shot instead of playing with Material nodes :) Thanks
