bigdave1960 opened this issue on Sep 26, 2008 · 7 posts
bigdave1960 posted Fri, 26 September 2008 at 3:31 PM
having amassed quite a lot of content in poser 7 (some of it abit messy in side poser folder) i was wondering if it is possible to easily transfer the content from poser 7 to poser pro. Or even just make it so that poser pro could access the stuff in poser 7 with out having to keep searching for everything
Khai posted Fri, 26 September 2008 at 3:33 PM
just link the P7 runtime to the PP one as an external
bigdave1960 posted Fri, 26 September 2008 at 3:36 PM
forgive my ignorance but how do i do that
IsaoShi posted Fri, 26 September 2008 at 4:00 PM
Go to the top level of your Library, click the + button (down the bottom) to add a new Library, and then select the Poser 7 folder which contains the Runtime with all your content.
Izi
what I should be."
Murakami)
nghayward posted Fri, 26 September 2008 at 4:02 PM
Go down the folders in the library until you get to the poserpro and download runtimes showing
Click the + button at the bottom of the library.
Browse to and select the Poser 7 folder (program files/ efrontier/poser7 I think)
You then have an extra runtime called poser 7 to use
bigdave1960 posted Fri, 26 September 2008 at 4:06 PM
thanks very much that works so easy when you know how thanks again
