jt411 opened this issue on Oct 08, 2008 · 9 posts
jt411 posted Wed, 08 October 2008 at 12:11 PM
sparrownightmare posted Wed, 08 October 2008 at 12:45 PM
You could do it in4 pieces with the spline modeler. Then duplicate the pieces. The corner piece, the side outer piece, the flat square inner piece, and the inner disk piece.
pauljs75 posted Wed, 08 October 2008 at 4:37 PM
I'd say that would be almost too easy with Wings 3D's new (0.99.04) toolset changes, and then just importing the .obj into Carrara. :tt2: But if you must insist on doing it in Carrara, I'm sure someone will eventually come around to show you the way.
sparrownightmare posted Wed, 08 October 2008 at 4:41 PM
I was able to duplicate that cube in about 10 minutes in C6 Pro. Create separate objects for the side edges, the corner, the inner cubes and the round item. Then just duplicate as many pieces as needed and assemble it. The spline modeler works fine for it.
jt411 posted Wed, 08 October 2008 at 5:29 PM
Thanks for the input guys! I was definitely going about this all wrong; In Max my first attempt was to make it out of a single cube primitive with some extrusions and Boolean operations. What I ended up with was way in the hell too messy and heavy for what I need.
Sparrownightmare-If you get the chance I'd love to see some screens of your method.
Thanks everybody :)
sparrownightmare posted Wed, 08 October 2008 at 5:31 PM
I zapped the file. But I will redo it when I get a chance, and put up a small render.
pauljs75 posted Thu, 09 October 2008 at 6:54 PM
jt411 posted Thu, 09 October 2008 at 7:53 PM
Mess Schmessy, great job Paul! I'm amazed that you did this in Wings, I haven't thought about that app. in years. I think all the fancy tools I'm accustomed to in Max made me forget the beauty of actually having some modeling skills. If that makes any sense :)
pauljs75 posted Thu, 09 October 2008 at 11:02 PM
