Subject: Prop question -
arrowhead42 opened this issue on Oct 09, 2008 · 11 posts
arrowhead42 posted Thu, 09 October 2008 at 9:00 PM
Hi everyone,
I'm just curious about something. I'm in the process of making a poseable prop of a semi-automatic handgun. The one part that will move on this prop will be the top slide, and it'll move left-to-right along the X-Translate dial. Is there a way to make it so the slide can move, but no more than a certain distance left or right?I'd like it to stay attached to the body of the gun, but still be slide back and forth. Any advice would be much appreciated.
Thanks -
Here's the link to my freebies:   https://www.renderosity.com/mod/freestuff/?uid=493127
My cousin Jack can speak to beans. That's right.... Jack and the beans talk
wdupre posted Thu, 09 October 2008 at 9:32 PM
yep just set limits, since its the only part and its moving in a straight direction and back I would do it with a morph, set to 1 will be all the way out and 0 will be all the way back, and you can set the limits to not exceed 1 or be less than 0
arrowhead42 posted Thu, 09 October 2008 at 10:03 PM
I'm not quite sure how to do that. Is it difficult?
arrowhead42 posted Thu, 09 October 2008 at 10:10 PM
Y'know, I was just messing around with it, and I figured it out - thanks for the help!
arrowhead42 posted Thu, 09 October 2008 at 10:18 PM
Ok, I take that back... I double-clicked on the x-tran dial, set the min limit at 0 and the max limit at .275, then changed the name.
But when I roll the dial down to a negative number, the slide still moves off the body of the gun. I want the slide to stop at the 0 value and not move back any further.
wdupre posted Thu, 09 October 2008 at 10:34 PM
you need to actually go into the pp2 or cr2 using a text editor and  find the xtran and where it says forceLimits 0 change the 0 to 1
arrowhead42 posted Thu, 09 October 2008 at 10:57 PM
Oooooo.... sounds complicated, but I'll give it a go
wdupre posted Fri, 10 October 2008 at 1:42 AM
Attached Link: http://www.renderosity.com/mod/bcs/index.php?ViewProduct=62322&vendor=288865
Its easier if you have a cr2 editor, they organize poser files into easy to understand hierarchies.  Dimension 3Ds Poser File Editor here at Rendo is a really good tool chock full of useful features. and if you plan on building much content its definitely a good investment.
If you want to go on the Cheap and don't mind less features you can use CR2 Builder, or CR2 Editor,  both free cr2 editors, You can find them fairly easily by googling them.
hborre posted Fri, 10 October 2008 at 6:19 AM
Also be aware that CR2's can be opened with notepad.  Just be careful not to create an association.
nickedshield posted Fri, 10 October 2008 at 9:26 AM
Also, do not forget to set the ForceLimits to 4.
wdupre posted Fri, 10 October 2008 at 12:30 PM
Quote - Also, do not forget to set the ForceLimits to 4.
I told him to set the forcelimits already, I said 1 but 4 will work as well, poser doesn't seem to care as long as it's not 0
