darman42 opened this issue on Oct 10, 2008 · 7 posts
darman42 posted Fri, 10 October 2008 at 1:24 PM
can anyone tell me how to get a polished wooden floor look in my renders?
any link to a tutorial would also be appreciated
Akhbour posted Fri, 10 October 2008 at 5:16 PM
Do you want to use it on a prop or do you want to create a polished floor?
Ift you have the prop, use a glossiness of 70% and add some reflection, about 10%.
If you want to create it google for a wooden floor texture, create a plane apply the texture and apply glossines and reflection.
JackieD posted Fri, 10 October 2008 at 6:36 PM
This free software creates wood textures:
http://www.spiralgraphics.biz/ww_overview.htm
I found it diffiuclt to get the correct tiling proportions on the plane to make it look real.
For added realism try creating a greyscale bump or displacement map.
darman42 posted Sat, 11 October 2008 at 6:42 PM
thanks
darman42 posted Sat, 11 October 2008 at 9:45 PM
sorry for the double post but:
im trying to get a mirror to work in a render. Unfortunately, it wont work.
what are the surface settings to get a mirror to work, and what lights might i nee to put on it?
RHaseltine posted Sun, 12 October 2008 at 8:36 AM
The mirror doesn't need lights, the objects being reflected need to be lit on the side you will see in the mirror. Are you rendering in 3Delight or OpenGL? Mirrors need 3delight/Software rendering. Reflection strength should be non-zero, with no map applied to the colour.
darman42 posted Sun, 12 October 2008 at 12:24 PM
ahhh, so the light needs to be on the reflected side, thanks
