Subject: Help: Using Seamless Textures in Poser!
ajmarti opened this issue on Oct 12, 2008 ยท 4 posts
ajmarti posted Sun, 12 October 2008 at 6:24 AM
Hi guys!
I found these wonderful textures among many other, can i use these textures in PoserPro for let's say change the original textures on a prop? like a column or a building?
If so, how do i load it? Using the material room? The seamless term confuses me a little... and im looking a beautiful rock textures like this
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=56883
I really appreciate your help!! Thanks take good care!!
AJ
Artist @ajmarti.com
vincebagna posted Sun, 12 October 2008 at 6:39 AM
Seamless means if you put two of the same pics side by side, they will appear as a bigger one without any seams to show the pics limits.
Sure you can use them via the material room. You only have to play with the U_Scale and V_Scale on the Texture map node. Though the way they will appear on your prop highly depends of the prop UV.
PhilC posted Sun, 12 October 2008 at 6:42 AM
In the Material room set the U and V values of your texture to a value less than one. The texture will be tiled accordingly. For example if you set each value to 0.5 the texture would be repeated twice along the length and twice along the height. Four tiles.
ajmarti posted Sun, 12 October 2008 at 7:06 AM
Hi V**incebagna!! Thanks so much for your help! Now i get it!.. Thanks!
Mr. PhilC** **that is fantastic. Finally i have no doubt about using these. Thanks so much for your help and your valuable time!!
Many thanks!!****
AJ
Artist @ajmarti.com
