Subject: Help with joint zones.
nyguy opened this issue on Oct 13, 2008 · 6 posts
nyguy posted Mon, 13 October 2008 at 7:30 AM
This is what my figure looks like zeroed.
This is what it looks like posed. I have tried adjusting the joint zones for all aspects of the shoulders (close to 6 hours) and I am getting no place fast. As you can see the underarms the fold in and on the shoulder in the front, there is poke thru. I had even scaled the model to 102% (makes it looks like she should be wearing football pads under it) and the same issue is there. What am I doing wrong? Can anyone please help?
Poserverse The New Home for NYGUY's Freebies
PhilC posted Mon, 13 October 2008 at 7:41 AM
Yes these areas are always tricky. I you would like to send me the files I'll be happy to take a look.
nyguy posted Mon, 13 October 2008 at 7:59 AM
Sending you a PM on your website with the file location
hborre posted Mon, 13 October 2008 at 8:36 AM
A quick fix would be to make that body part invisible if it does not affect the areas exposed above the v-neck.
PhilC posted Mon, 13 October 2008 at 9:26 AM
Did you "Magnetize" the clothing? I've just conformed what you sent me and provided I use the correct Magnetize V4 pose I do not see any poke through.
nyguy posted Mon, 13 October 2008 at 9:32 AM
Yes I "Magnetize" the clothing. The issue that I am see is the underarms no matter what magnets I use the underarms don't look right. Used used your Obj2Cr2 to create the clothing figure.
