Forum: Community Center
Subject: SQL errors when posting recently
Winterclaw opened this issue on Oct 13, 2008 · 6 posts
Winterclaw posted Mon, 13 October 2008 at 2:38 PM
Recently I've noticed that I've been getting a lot of sql errors when I try to post.  Below is the error message.  Note that this doesn't prevent the post from happening, but it shows up instead of taking me back to the forums.
[quote]
MySQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-31,30' at line 3, occured in query: "SELECT SQL_CALC_FOUND_ROWS t.* FROM forumpro_message t WHERE t.thread_id='2752435' AND t.status = 'active' ORDER BY post_date LIMIT -31,30;".
[/quote]
Is anyone else seeing this?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
StaceyG posted Mon, 13 October 2008 at 3:50 PM
Hi,
I fixed this for you. This was due to something in your forum options that needed to be changed. The programmers are aware of this issue and they are looking into it but for now I've manually fixed your problem so you shouldn't see that error any longer when posting:)
williamsn posted Mon, 13 October 2008 at 5:33 PM
Testing
-Nicholas
williamsn posted Mon, 13 October 2008 at 5:57 PM
Test again.
-Nicholas
There we go. :)
-Nicholas
StaceyG posted Tue, 14 October 2008 at 9:56 AM
Thank you:)
