DigitalDreamsDS opened this issue on Oct 14, 2008 · 7 posts
DigitalDreamsDS posted Tue, 14 October 2008 at 10:26 PM
nickedshield posted Tue, 14 October 2008 at 10:41 PM
Parent them to the head, for the earrings and neck for the choker then save each individual to the prop library. When you save you should have a message asking to save as a smart prop.
DigitalDreamsDS posted Tue, 14 October 2008 at 11:09 PM
ockham posted Tue, 14 October 2008 at 11:30 PM
That isn't surprising. The neck is a flexible 'soft' surface, and the choker
is a 'hard' object. When the neck bends, the choker isn't going to expand
and contract automatically.
Easiest solution, I think, would be a little less choke. In other
words, increase the X and Z scale on the choker until it looks good at
various non-extreme neck positions.
Alternatively you could build the choker as a conforming figure, but
that would be a LOT of work.
DigitalDreamsDS posted Tue, 14 October 2008 at 11:53 PM
hmm..
well i have auto group editor...
and I'm ok at rigging.
This is not an extreme pose... thats why it confuses me.
EnglishBob posted Wed, 15 October 2008 at 4:20 AM
All the same, the neck will change shape when it bends, and the choker will not. This is a problem with Poser, that at present although the body can affect the clothing, the clothing cannot affect the body.
If the choker is supposed to be hard and unyielding, then you either have to make it larger, or use a magnet to squeeze Vicki's neck.
If the choker can be elastic, then check "inherit bends of parent" when you parent it. This will avoid having to make a conforming figure - very useful for cases like this, were the prop covers only one body part.
Fazzel posted Wed, 15 October 2008 at 2:17 PM
Another thing you might want to try is to take the choker into the cloth room.
